Question about Beko Washing Machines
HOSE UNDER MACHINE SHOULD IT BE STICKING OUT
WM81275 8KG
    Top Expert:
  • Beko Master
  • 52,123 Answers
If it didn't have one sticking out where would it drain
Posted on Mar 31, 2015
Whirlpool dishwasher
The float valve may be sticking or defective.
Feb 19, 2017 | Whirlpool Dishwashers
Air hose by transmission 02 trailblazer
it mabe the breather hose for transfer case
Dec 10, 2016 | Cars & Trucks
My LG WT-h650 washer has got a problem, the cold water while filling is only dripping out. Have cleaned the filters at the end of each hose
There may be a filter on the inlet connection on the machine. Take the hose off and look for a screen on the machine side. If this is not the problem then it could be the valve on the machine is not opening enough or it is sticking from debris, has the wrong voltage sent to it or there is a crease on the hose inside the machine.
Apr 02, 2016 | LG Washing Machines
Belt sticking when running, is it me or the machine????
it could be the belt sticking under foot on the slide plate
ask the sports shops if there is a lubricant that you can used under the belt
check to see if the belt is correctly adjusted
Jun 20, 2015 | Confidence TXI Heavy Duty Motorized...
WE don't have a hose attached but water keeps coming out continuous drain hole instead of bucket. Sometimes the bucket will fill however we can't ever be sure
was machine ever converted to use a drain hose ? reason I ask if it has , some models are not backwards convertible , as ports and holes inside the machine have been knocked out to allow for use with a hose , , if your machine has a hose port sticking out im betting this has been already done , as I've not seen units come from factory with them already installed , but do include conversion kit inside package with instructions
May 17, 2015 | Dehumidifiers
Kenmore series 80 washer. Will not stop filling. Water shuts off when machine is unplugged. Will drain water on spin cycle as it should. I would appreciate some pictures/diagrams to accompany any help you...
Hello lonestar,
firstly i would like to thank you for writing a well written question it helps me to pinpoint the exact problem with your washer!!
Since the water stops as soon as power is removed to the machine the problem is that the water level switch is shorted out.
it could have been the water inlet valve sticking but with the power off if the valve were sticking it would continue to fill with power off
Un fortunitly with just "series 80" i could not pull up any pictures to show you the water level switch,reply with complete model number as found on a label under the lid near the fill spout on the rear of lid opening
Gene
Jul 26, 2011 | Washing Machines
My washing machine water overflows tub it wont stop filling up, i changed the water inlet valve
Sounds like a sticking water level switch.
Locate thin plastic or rubber hose going from the bottom of the washer to the water leel switch at the top, remove and clean hose and the chamber at the bottom where the hose fits.
Nov 11, 2010 | Whirlpool Washing Machines
My machine flashing up f-05 any ideas?
F05 indicates water level switch is sticking, possibly due to a blocked filter.
Remove lower rear panel of washer.
Remove large black hose connected to the bottom of the drum.
Remove and clean plastic filter inside hose.
Refit and test.
Mar 30, 2010 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
