Broken catch kl75cm
How do i use the using machine without a door catch
    Habit-Forming:
    New Friend:
  • 7 Answers
HI THERE,MY CATCH HAS GONE TOO,WHAT I DO IS GET A LENGTH OF WOOD,SAY 2 BY 1 OR 2 BY 2,PUT ONE END ON MACHINE DOOR HANDLE,AND WEDGE THE OTHER END AGAINST THE OPPOSITE WALL A LITTLE DAMP CLOTH AT BOTH ENDS OF WOOD WILL HELP AGAINST SLIIPPAGE.WORKS A TREAT.
ONE IM USING AT THE MO IS PLACE A STRONGBOX IN FRONT OF MACHINE NICE AND CLOSE,THEN PLACE A RATHER LARGE CONCRETE GARDEN GNOME ON BOX.ALSO WORKS EVERY TIME,I KID YOU NOT..GOOD LUCK...MARK IN SWANSEA
Posted on Mar 31, 2015
How can i use kelvinator kl75cm when the catch is broken
According to the owner's / user's manual: try closing the door well; make sure there are no obstructions
Unplug the washer- and wait 1/2 hour; plug it back in; if you still get the error, unplug it and call the after-sales service center...
0860 234 481 (South Africa Customers0
+27-11-579-0800 (International Customers)
Mar 31, 2015 | Washing Machines
How to open the door of a kelvinator kl75cm washmachine
Try unplugging the unit for 30min. Sometimes this will reset the washer. My washer also has directions in the owners manual how to open when this happens.
Apr 12, 2014 | Washing Machines
How Do I Access Door Catch Inside Machine Body
Hi Steve
Having taken off the top and runners you will need to take off the front control panel then the main front of the machine.
There are two screws on the top, two on the bottom and four on the front (one may be hidden behind the appliance sticker.
There then should be enough room to access the couping without removing the door.
Give it a play first as it probably will just need resetting and you will save yourself a tenner on a new part.
Good luck
Cheers
ian
Co
Nov 14, 2011 | Hoover VHC391 T-80 Dryer
My hotpoint ultima wt761 door catch has broken how can i open the door
If you have a broken door catch you can get the door open by feeding some garden wire around the right hand outside of the door (between the door and the metal casing of the washing machine).
Once you've fed it in round the top right and bottom right curved corners pull the two ends of the wire to the left, so that the wire pulls against the lock mechanism, and the catch should release.
Feb 26, 2011 | Washing Machines
The door catch on my easi logic 1200 washing machine has broken
The door catch will have to be replaced, depending on model you can buy these from a repair shop for a few pounds.
You will have to open the machine to get to the door catch from inside.
IMPORTANT: THERE ARE LIVE SWITCHES AND MAINS SUPPLIES WHEN THE COVER OF THESE MACHINES ARE REMOVED, DO NOT TOUCH OR TAMPER WITH ANY PART, UNLESS THE POWER IS OFF AND THE PLUG REMOVED FROM MAINS SOCKET.
Remove the power supply as mentioned above, remove the top cover reach down inside and try to open the door, (BE SURE THAT THE DRUM IS TOTALLY EMPTY OR YOU WILL FLOOD THE FLOOR)
I can't advise exactly how to open the door from the inside, beacuse I do not know the make or model No.
If you are successful in getting the door open, the screws to remove the broken catch should be visible just inside the door.
Best of Luck!!
Jul 04, 2009 | Kenmore 4292x Front Load Washer
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius 1000wm 20 I have to bash front door to start
I do not think it is the door lock that is faulty, more likely to be a weak or broken door spring or broken door catch.
I would replace these first,and then if it is still the same, then replace the door lock.
To replace the spring and or handle catch, undo all the screws that secure the 2 halves of the door, and prize apart the 2 halves,
Replace the spring and catch, reassemble the door.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius w.machine door catch broken.
easy way is to cut or break away the handle so the start of the door peg is exposed and use a screwdriver on the peg to lever it out
Aug 30, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Interior Door catch broken
You should open machine's upper panel (release 2 screws in the machine's back and slide the cover out) and then you will have an access to it. You should buy a new door catch and replace the broken one. Be aware that you should disconnect machine's power cable before doing it. Good luck
May 09, 2006 | Zanussi WJD1257S Front Load Washer
Broken interior Door catch
May 09, 2006 | Zanussi WJD1457W Front Load Washer / Dryer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
Top Washing Machines Experts
