How can i use kelvinator kl75cm when the catch is broken
Giving E02
  • 794 Answers
According to the owner's / user's manual: try closing the door well; make sure there are no obstructions
Unplug the washer- and wait 1/2 hour; plug it back in; if you still get the error, unplug it and call the after-sales service center...
0860 234 481 (South Africa Customers0
+27-11-579-0800 (International Customers)
Posted on Mar 31, 2015
Bosch washer giving E02 error, drum has excessive water in it, takes 3 manual drain cycles to empty drum
E02 error code is either water supply side not enough (kinked hose) or more likely in your case clogged drain [hose] or particle filter.
Dec 10, 2017 | Bosch Washing Machines
Broken catch kl75cm
HI THERE,MY CATCH HAS GONE TOO,WHAT I DO IS GET A LENGTH OF WOOD,SAY 2 BY 1 OR 2 BY 2,PUT ONE END ON MACHINE DOOR HANDLE,AND WEDGE THE OTHER END AGAINST THE OPPOSITE WALL A LITTLE DAMP CLOTH AT BOTH ENDS OF WOOD WILL HELP AGAINST SLIIPPAGE.WORKS A TREAT.
ONE IM USING AT THE MO IS PLACE A STRONGBOX IN FRONT OF MACHINE NICE AND CLOSE,THEN PLACE A RATHER LARGE CONCRETE GARDEN GNOME ON BOX.ALSO WORKS EVERY TIME,I KID YOU NOT..GOOD LUCK...MARK IN SWANSEA
Mar 31, 2015 | Washing Machines
How to open the door of a kelvinator kl75cm washmachine
Try unplugging the unit for 30min. Sometimes this will reset the washer. My washer also has directions in the owners manual how to open when this happens.
Apr 12, 2014 | Washing Machines
E02 in canon Np 160
I believe a E02 deals with the scanner. Your copier is very old. It has been a long time scine I've worked on one. Have you checked that the exposure lamp has continuiy? If so, you may have a blown thermal fuse for the scanning lamp. Also, dose the scanning lamp turn "ON"? You may have a broken scanner lamp power cable. You should be able to order the parts on line.. Good Luck...
Dec 27, 2009 | Office Equipment & Supplies
Oven does not get warm, suspect it is a fuses but cant locate it
It is probably due to a broken heating element in the oven. These are relatively easy to replace. You can test it with an ohmmeter. It should measure low ohms. If it is open circuit then it is broken.
Jul 25, 2009 | Stoves 1100DFSID Kitchen Range
Panasonic Workio DP-1820P
E02-01 means the cassette lifiting motor unit, mostly it is broken and some times can be repaired, otherwise, you have to change it, and to open the back cover and reach that)
Part no is (DZTY000357 assembly, lift up drive)
Bassam
Jun 19, 2008 | Office Equipment & Supplies
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
