Question about Tablets & eReaders
Hello i have been trying to go onto my table but it keeps saying rstech-knile has stopped working, what does this mean and how can it be repaired.
My samsung galaxy 2 tablet system ui keeps on stop working how do i fix it
If you mean it shuts down then the battery is most likely failing, if you mean the programs stop running then try doing a memory dump, get rid of all the old data files you can. Transferring as much data to a SD memory card helps as well
Jan 24, 2017 | Samsung Tablets & eReaders
I'm trying to download the wwe app on my tablet. It keeps coming back saying that the app isn't compatible with this device. What do i need to do?
Only thing you can try to do is to find inline older version of that app and see if it would load on your tabled. Looks like currently offered in play store is not compatible with your unit and chances are that either there is hardware limitations or app requires higher android version in order to work. Check tabket manufacturer for updates
Oct 15, 2016 | Tablets & eReaders
Grandson sat on table and cracked the screen. Where can we get it repaired please.
Google laptop repair in your area. I'm guessing you mean tablet instead of table?
Screens aren't that bad to do yourself depending on the model, something to think about.
Jan 19, 2016 | Tablets & eReaders
Why can't i get the table to start get a message saying the PC didn't start correctly.
there is a pin hole on the side, stick a straighten paper clip into the hole and repower up, this will reflash it, if not, take for repair
Dec 31, 2015 | Tablets & eReaders
Trio STEALTH-G4 10.1 cracked screen, will start, touch screen not responding, how can i reset to see if it works or not. Is it repairable?
Contact a local electronics repair facility. If you cannot locate one in the phone book or online, stop by a table or phone sales point, and ask for recommendations.
My repaired table works as well as new.
Mar 03, 2015 | Tablets & eReaders
No, I tried holding the power button to no avail just keeps saying powering off, but never does
This could mean the power button is defect. Or a cable inside the tablet. Perhaps you better visit a phone repair store, and let them check. Before you let them repair, ask what it will cost you!!!!!!
Jan 16, 2015 | Tablets & eReaders
Why wont my camera work on my brand new zeepad 7.0???
it means just that, it stopped working, it broke itself. try using a different app that does the same thing.
Dec 28, 2013 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
When I turn on the computer,I get amessage that read's Invalid partition table. What is this & how do I repair it?
PC repair will fix PC issues and Driver solution will get the right drivers for your PC. I use these tools and costumers almost never contact me saying they have a problem.
Dec 19, 2011 | Samsung Q1 Tablet PC
The screen stopped rotating. what can I do?
You will have to do a factory reset, which will restore the default settings on your device.
1) With the device powered off, press and hold the Volume Up and Power buttons at the same time.
2) When you see the Samsung logo, release the Power button, but continue to hold Volume Up until the recovery screen appears.
3) Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4) Press Volume Up to continue.
Mar 14, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
103 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
