Question about Kyocera Office Equipment & Supplies
Kyocera 1620 signal C-4600 - Kyocera Office Equipment & Supplies
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 167 Answers
This is a fuser error. More than likely the fuser lamp has failed.
Posted on Sep 07, 2015
4 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: Copystar/Kyocera 1620 error code: C-6 000
The fuser needs to be reset.
Posted on Mar 04, 2009
  • 215 Answers
SOURCE: kyocera 1620 error code c-4 000
that code, unfortunately, means your laser unit has went south. you definetly have to call a tech on this as it is quite a job to even get to the laser.
hth
razors
Posted on Mar 30, 2009
SOURCE: Kyocera KM-1620 as a printer??
please tell me about km 1620 erorr code 7760
Posted on Mar 08, 2013
How do I fix A-4200 problem on KM - 1620 Kyocera copier
Try the main charge first...if not working Replace the laser unit.
May 28, 2015 | Kyocera Km 1620 Cs 1620 Copiers Copy...
How do I reset my KM 1620 Kyocera copier.
Causes:
1. Unstable power source
2. Low/High voltage
3. Broken thermistor wire
4. Poor contact in the thermistor connector terminals.
5. Heater lamps are broken or not installed correctly.
Before resetting "6XXX" series code, make sure that defective parts have been replaced/repaired.
Reset Procedure:
Enter 1087-1087 (1087 twice) from the keypad.
Enter 163 by using keypad.
Press "Start" (the green button) twice.
The machine will restart automatically.
May 21, 2015 | Kyocera Km 1620 Cs 1620 Copiers Copy...
What make the buttons of my Kyocera Mita KM 1620 stop working
the buttons stop working because the internal pressing are crash and you should replace it or join it by welding. but first of all you may blow the panel it could be some dust.
Sep 18, 2014 | Kyocera Mita KM1620 Black Toner Cartridge...
ALL KYOCERA MITA 1620 ERROR CODES
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Kyocera-Mita&model=KM1620
May 21, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
Kyocera mita 1620 failuire to work due to error message C2000
Drive motor problem
LOCK ALM signal remains high for 1 s, 1
s after the drive motor has turned on.
Poor contact in the
main motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable.
Defective drive
motor rotation control
circuit.
Replace the drive motor.
Defective drive
transmission system.
Check if the rollers and gears rotate
smoothly. If not, grease the bushings and
gears. Check for broken gears and replace if
any.
Call service Code 4600 KYOCERA FS 8520 MFP
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
of the connector cable. If none, replace
the cable.
May 17, 2014 | Kyocera FS-C5030N Led Printer
Error code A3200 for kyocera km 1620
how to repair kyocera km 1620, showing error message "A3" "200"
Mar 31, 2013 | Office Equipment & Supplies
Yes, it can be connected as a printer -- see this page where you can download the print drivers:
http://usa.copystar.com/americas/jsp/Kyocera/download_center.jsp?pid=11917&pcat=10564&rcid=10009&rscid=10007#bottom
However, it may need an optional interface attached. Check the back of the machine to see if there is a USB port (the squarish one). If there is nowhere to plug in the USB cable, you may need to buy the printer interface option.
Jul 07, 2010 | Kyocera Copystar CS-1620 Black and White...
Copystar/Kyocera 1620 error code: "C-6" and "400" (cylces back & forth once a seond)
so, just enter 10871087, press start, after enter 163, press start. thats all.
Feb 04, 2008 | Copystar CS-1650 All-In-One Laser Printer
42 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
