SOURCE: Pioneer vsx-5300 reciever
If you have just one pair of speakers hooked up and have both A & B speakers selected you won't get ANY sound out of unit, so check that?
SOURCE: No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
SOURCE: pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
SOURCE: my pioneer av receiver vsx1020 produces same sound in front and back speakers
Try changing surround modes. You might be in 5 channel stereo mode.
