Question about Sony Cyber-shot DSC-H9 Digital Camera
While focusing, the image is not still, it's shivering
My immobiliser light wont go off
Hi, Anonymous don't know about the Shiver ECU and you may want to give your local Aprilia dealer a call for more information about your question and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
Thread Some Shiver Useage FAQ
ducati immobilizer bypass
Diagnostics Italian Bike Programming and Keys
http://aprilia-taiwan.com.tw/servicearea/SERVICE-MANUAL/DORSODURO%20750/APRILIA_MSS_1056703_EN_DORSODURO-ABS.pdf
Apr 07, 2016 | Motorcycles
Shiver has ECU plug error
Hi, Richard and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Thread Fault Finding Shiver ECU Faults
Aprilia Shiver Urgent Service Problem
Aprillia Shiver SERVICE errors reset
Aprilia SL750 Shiver Workshop Service repair manual Download Manuals...
Apr 02, 2016 | 2009 Aprilia SL 750 Shiver
I have red light on and service urgent dont start and when i give the starter to start just gives some turn and cut off what do i do guys ???
Hi, Mixalis for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Thread Urgent service light
Aprilia SL 750 Shiver 2007 2008 2009 2010 Service Manual Download Manuals...
Mar 04, 2016 | 2008 Aprilia Shiver 750
2008 aprilia shiver dash going on and off
Hi Anonymous, check the ignition switch for continuity and the wire connector to the dash lights and I am sorry you can't find the first and best tool you ever bought for your Aprilia but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day. DOWNLOAD 2010 Aprilia Shiver 750
Jul 14, 2014 | 2010 Aprilia Shiver 750
Reset code aprilia shiver
Hi Anonymous, for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix/test or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day. DOWNLOAD 2010 Aprilia Shiver 750
Feb 09, 2014 | 2010 Aprilia Shiver 750
Service code for 2009 aprilia shiver
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Aprilia but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
http://www.apriliaforum.com/techtips/1000/faultcodes.htm DOWNLOAD 2010 Aprilia Shiver 750
Sep 15, 2013 | 2010 Aprilia Shiver 750
How do i remove the battery housing aprilia shiver
DOWNLOAD 2009 Aprilia Shiver 750
Mar 29, 2013 | 2009 Aprilia Shiver 750
Oblivion expansion will not load
The shivering isles isn't in anvil. First go to your map, scroll to bravil and look off to the right in the water. You should see a small piece of land that you can travel to, this is the door to shivering isles. I have this game, its amazing!
Oct 07, 2009 | Take 2 Interactive Elder Scrolls IV:...
Vertical white wide band - Shivering fonts
Unfortunately that sound like a defective LCD panel. You can verify this by plugging the system into an external monitor. As long as the shimmering band does not appear on external display then it is the LCD. If it is under warranty I would suggest taking it into Apple.
Aug 16, 2009 | Apple MacBook Air Mac Notebook
Nintendo DS Lite top screen is shivering
I think you have a defective screen or the adjustment 'screw' for the topscreen on the mainboard is defective.
My opinion is to send it for repair to Nintendo or a DS Lite repair service.
Nov 25, 2008 | Nintendo DS Lite Console
Sony Cyber-shot  DSC-H9 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
