Question about Daewoo Washing Machines
I have a Daewoo washing machine fully automatic DW-760 MP. I loaded the clothes and started the machine . water started filling but at the same time water keeps on draining due to which the washing cycle does not start.
  • Daewoo Master
  • 5,323 Answers
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
Posted on Apr 13, 2015
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
  • 351 Answers
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
timer or timer module fault
Posted on Mar 02, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
My washing machine does not clean clothes properly and washing powder residue is left after wash on clothes I have Daewoo Dwd F1243
start a wash with a load and after he machine fills with water check to see if the drum rotates this is usually the problem if you get powder residue on wash with no drum action the powder does not disperse also check to see if the machine spins if it does check belt tension if not check belt tension and motor brushes
Mar 04, 2014 | Washing Machines
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Whirlpool WFC7500VW Washer
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
During filling reaches fL before finished filling and stops
Not sure if this was explained to u but these washers do not fill like the old top loads did... the machine uses very little water, the clothes are rolled over and over through the water as it cascades down and up through the agitator. If you look at the agitator you'll notice it does not have an elongated spindle, it's not required. Although the machine doesn't fill your clothes will be fully washed, this design was developed to conserve water...
Aug 19, 2013 | Kenmore Oasis Agitator 4.5 cu. ft....
With my aftron automatic top loading washing machine, I am facing following problem :- 1. It does not have any problem while washing cloth or while water drain, but after it washes cloth, it cannot able...
We have AFTRON FULLY AUTOMATIC TOP LOADING WASHING MACHINE BOUGHT IN 2002 FROM DOHA QATAR. WE COULD HARDLY, USE IT FOR A COUPLE OF TIMES IN INDIA. ALL OF A SUDDEN THERE WAS SMOKE COMING OUT OF THE MACHINE AND FINALLY, WE FOUND THAT THE CIRCUIT HAS GOT BURNT ON THE PCB. NO BODY KNOWS THE SOLUTION IN INDIA.
I WENT TO AFTRON'S H.Q. IN UAE BUT INVANE.
PLS. ADVISE US.
RGDS.,
Aug 14, 2010 | Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
