My VMOTO MONZA 125 has no spark to the spark plug? have tried other plugs still no spark. @
SOURCE: benelli vevet 125 /02 no spark changed coil/lead/plug..?
see if you have ac voltage from the stator coil when cranking motor.if you do,try swiching cdi box out.also check for power to ign. coil.
SOURCE: help. my sons derbi send r 125 wont start. all
have you checked your air filter. If its dirty wash out with air filter cleaner or petrol and replace.
SOURCE: oil in spark plug hole
Check the spark plug is may not be tight enough, don't over tighten it as you will damage the head.
Replace the plug as it may be missing its oil ring.
Hope this is of some help.
Ed
SOURCE: what spark plug for yz 125?
I have a dennis kirk book, the correct spark plug is a --BR9ES--(NGK)
i always used SAE 10w-30 oil on all my dirtbikes,
no transmission fluid
for the chain you should move the back tire back until the chain is at a snug tension
SOURCE: Skyjet 125 Spark Plug
hi ive heard people using an ngk irridium plug i have one in my dtr and its great!there about 12.00/15.00 gpb
