Hou to increaw brightnes in the same???
I cannot increase the brightnes in this same...
Brightness hp
check in the key board for a brightnes key symbol normaly function key or arrow keys or to battery icon in the desktop and increase brigthtnes
Nov 01, 2013 | HP ProBook Computers & Internet
The displey of my Canon S2IS turns darker as soon as I press the button half-way to take a picture and I can hardly see anything. It does that independently of the ambient illumination, so it's not an...
It sounds like your lens is stopping down to show the depth of field. Some cameras can be set to do this in their menus. Check your manual or menu system to see if you have that setting available.
Mar 05, 2011 | Cameras
How can make brightnes
Go into the Menu Key " Look for Copy Quaility or Copy Density "
Change that from normal to Darker and change the contrast to darker you should see a difference. Incase you can't find it Print the Menu Map Look under Media OR Reolution it should be there. Again print Menu map to find it
Oct 10, 2009 | HP Color LaserJet 2600n Printer
I cant able to use my keypad function key for sound and brightnes
i dont know the model of your laptop..but check this out!!!!
its not the issue for sound drivers...if you want to work with the key function...you must install the hotkey..if the model of your laptop has a function key...
Jan 05, 2009 | Sony Computers & Internet
Philips 170s6fs monitor: OSD menu blocked
.well i had the same problem but my dad fixed it.
.he opened the monitor [like unscrew it.] and just clean it. brush it. and it will work fine.
if it didnt i dont know.
Dec 06, 2008 | Philips 170S6FS 17" LCD Monitor
AKAI CT 2112
This is a typical power supply problem. Please check the B+ Power Supply that goes to the LOT (FBT). It should be 110V. If that is ok, check the voltage while increasing and decreasing brightness, sound. If there is variation, the problem is in the SMPS. Look for dry capacitors, open/high value resistors, zener diodes, transistors etc. If nothing works, please download a data-sheet of the IC and check voltages at the pins and locate the adjacent components. Even a dry capacitor in the power supply can decrease the votage at load
Mar 30, 2008 | Akai LCT2662 Television
Brightening my computer screen
Push and hold the Fn button and for decrease of brightnes push F7 for increase push F6 . So Fn+F7 dark: Fn+F6 bright.
Arsim
Mar 12, 2008 | Computers & Internet
Not show display clear is very darkness
Have you increase the brightnes by Fn key and brighntess key on above of keypad please set it first fn>+brightness key
Also please check wheather the deaault settings are in agp card settings in display properties
Regards
Balisonu79
Feb 15, 2008 | Lenovo ThinkPad R51
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
