Question about Vizio E-series E241-A1 24" LED TV 1920x1080, 60 Hz, HDTV
TV won't turn on. I hit the power button and the white LED comes on bright and nothing happens.
Normally the white LED comes on bright for a few seconds and then dims when the screen comes on. Warranty expired the week before so I took off the back cover to check for burn marks on the circuit boards but found none. Tested the output voltage off the power board going to the main board and it is fine. I suspect the main board went bad. Before I get a new one board does anyone have any experience with this same problem?
    Top Expert:
  • Vizio Master
  • 75,462 Answers
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Mar 31, 2015
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
Hisense LED HDTV
I am no expert, but I would be looking for a replacement or warranty on that unit.
Unfortunately there is very little an every day user can do to fix a problem like this on their own.
Jan 29, 2014 | Televison & Video
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
My philips 42in lcd tv screen went black, I found a faulty slave inverter and replaced it. Now the screen is still black but my blue led comes on when I plug the tv (without turning the tv on) and fl
However it may sound to you the inverter does not affect the TV's ON/OFF status (i.e. the LED at the front) in almost no way except possibly in case of a dead short when the power board may detect it and shut the whole TV off.
You can disconnect the inverter from power and I bet you the TV will continue doing the same as before.
An inverter is nothing more than a voltage transformer - well, with a key for turning on/off and usually another control for selecting another paramenter, which results in brightness (higher avg output voltage and lower avg output voltage, aka DIM).
For more details I'll need to know the model and I can probably help better.
www.coppelltvrepair.com
Sep 06, 2012 | Televison & Video
Sharp LC40LE600E wont turn on
Had exact same symptoms as Keran. Turned out to be my daughter had turned the TV off with the other power switch which is a button on the right hand side of the set - we always use the rocker switch on the left hand side and had forgotten about the button. Turned the rocker switch on, then the button and it was back to normal.
Jul 19, 2012 | Sharp Televison & Video
Power LED on but no boot up
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
Won't turn on...
It's possible that the convergence IC's may be bad in this set along with a few resistors. A TV repair shop should be able to fix the set for you.
Dec 19, 2006 | Samsung HCN4226W 42" Rear Projection...
Vizio E-series E241-A1 24" LED TV 1920x1080, 60 Hz, HDTV Logo
227 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
