Question about Miscellaneous
Why does my car still have check engine codes . I was told that my pcm was bad and i replaced it . After having my pcm reprogrammed .
I have a 2004 3.4 liter chevy impala , and I'm having problems passing the emissions test . The codes are p404 I replaced the egr , p1404 egr is reading stuck opened . Do I need to have the codes removed ? Any suggestions
  • 2,039 Answers
After replasing a part you got to clear the old code i show you how to do it
Posted on Apr 01, 2015
  • 5 Answers
Look ive done this countless times. plug in your pcm, turn the key to the on position/dont start the car just on. On your pcm run your test as usual then once the same codes come up erase um all until its clean. turn the key off. remove the pcm and start the car. run the car for a week normally and your problem should be gone.
Posted on Apr 30, 2015
    Master:
  • 354 Answers
Changing the PCM removes all the codes. If there are codes after the PCM was changed and the engine was started then, there are problems. If you changed a part without a proper diagnostic done, you may have wasted your money. An EGR code does not necessarily mean the valve has to be replaced.
Posted on Apr 03, 2015
Check eng. light on. P0601 code What can I do?
A code P0601 in most cases means the PCM has gone bad. This is possibly due to a short-circuit inside the PCM. Or, if you disconnect the wires/connector from the PCM while the battery is still connected, that may also cause this code. the most common fix is to replace and reprogram the PCM. In a few cases the dealer may be able to reflash the PCM and get it working. But more than likely the PCM will need to be replaced and reprogrammed dealership for this). The good news is it *may* be covered under your emmissions warranty. good-day!
Apr 07, 2014 | 2001 Dodge Ram 1500 Truck 2WD
Check engine light came on
. code po305 is cylinder 5 misfire that can a bad spark plug or a injector.po153 is a o2 sensor. there is 3 on your engine. which one did they replace. the code po153 is for the front one it is in front of the radiator. code po443 is for the purge solenoid ,but there is many things the can cause the code the garage should have checked things first. wow
Dec 12, 2012 | 2000 Ford Taurus
I have a 2004 Cadillac CTS and about a week ago the key got stuck in the ignition. We were first told that the battery was bad and needed to be charged. Well that didn't work and we took it in to an auto...
if the pcm is not communicating with the car you may have to program your cars vin number into the computer.or have the computer flashed at a dealer the reprogramed with your cars vin number
Jan 19, 2011 | 2003 Cadillac CTS
What is the pcm in a 2004 chevy trailblazer? and how I can fix it.
PCM is what control's all of your engine sensor's, there's no repair for the PCM, but to replace.
Nov 09, 2010 | 2004 Chevrolet TrailBlazer
Error code 1680
Chevrolet OBD Fault Codes
DTC P1680 - Driver 5 (ECU malfunction)
This is any internal ECU problem (ECU = ECM = PCM device); check other details HERE; keep in mind that its possible that you have to reprogramm the ECU.
Here is a bulletin for this problem.Subject: Service Engine Soon Light On, P1680 (Reprogram or Replace PCM)
Models:
2004 Buick Rainier
2004 Chevrolet Trailblazer
2004 GMC Envoy
2004 Oldsmobile Bravada with 4.2L Engine (VIN S - RPO LL8)
Some customers may comment on the Service Engine Soon Light coming on. Upon investigation, the technician may find a P1680 diagnostic trouble code Check the resistance of the accelerator pedal position sensors using the procedure in the appropriate Service Information for DTC P1680.
If the resistance of the accelerator pedal position sensor is within the specifications shown in the Service Information and the vehicle was built prior to the following VIN breakpoints, then reprogram the PCM with the latest calibration.
If the resistance of the accelerator pedal position sensor is within the specifications shown in the Service Information and the vehicle was built after the following VIN breakpoints, then replace the PCM. If the resistance of the accelerator pedal position sensor is outside the specifications shown in the Service Information, then continue with the diagnostics for DTC P1680.
VIN Breakpoints
• Vehicles built at Oklahoma City Assembly Plant - 46192755
• Vehicles built at Moraine Assembly Plant - 42315833
Hope this help
Aug 03, 2010 | 2004 Chevrolet TrailBlazer
Code p1680 manufacture control and auxiliary input and output problem
You have to reprogramm the ECM. Here is a bulletin for this problem.
Subject:
Models:
2004 Buick Rainier
2004 GMC Envoy
Some customers may comment on the Service Engine Soon Light coming on. Upon investigation, the technician may find a P1680 diagnostic trouble codeCheck the resistance of the accelerator pedal position sensors using the procedure in the appropriate Service Information for DTC P1680.
VIN Breakpoints
Hope help with this (remember rated this).
Jul 09, 2010 | 2004 GMC Envoy
My check engine light is on had the OBD checked and stated a temperature problem autozone suggested to check coolant level first then replace the temperature sensor where is it located?
I had the exact same problem on my 2003 Trailblazer. The check engine light came on, I took my vehicle to autozone and they told me the code was P0495 (cooling fan speed high)but they did't know how to fix the problem.
I called the dealer and they told me that it would cost me $89.00 to reprogram my PCM. I took my vehicle to the dealer and now my trailblazer is working like new. I hope it's that simple, the other thing also that could have gone bad would be the relay to your electric fan. The relay is a not like a normal relay but is more like a module that can regulate the speed of the electric fan which a tech2 scanner can determine if it's bad or not. Good luck
Thank you for using fixya.
Apr 22, 2010 | 2004 Chevrolet TrailBlazer
I HAVE A 2004 HONDA ODYSSEY THE CHECK ENGINE LIGHT CAME ON, THE CODE THAT CAME UP IS P1607 PCM INTERNAL CIRCUIT FAILURE COULD ANYONE PLEASE TELL ME WHAT THAT CODE IS?
this code can sometimes set due to low battery voltage. find the cause of the low battery voltage(this code usually pops up after a car is jump started or the battery is replaced or gone bad). clear the code. if it returns, then yes, the pcm will need replaced.
Jan 05, 2010 | 2004 Honda Odyssey
I have a ford f 250 with dtc code p0606, Internal Ctrl Mod Kam Error, what is wrong and how do I correct or fix
There is no P0606? P0602, P0603 or P0605. P0603 KAM interrupt can be a blown fuse or low battery, P0605 can be aftermarket chip / programing or PCM failure (diesels do have a reprogram for false P0605). P0602 is usually a PCM failure.
Oct 24, 2009 | 1999 Ford F250 Regular Cab
S10 CAME IN MULIPLE CODES
no on a 1998 s10 all you need to do is buy a new pcm.. if you buy used you will need to reprograme.. if new you will not have to reprograme.. good luck keith...
Mar 20, 2009 | 1998 Chevrolet S-10 Pickup
Miscellaneous Logo
50 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
