Question about Garden
How do I check the PTO switch on my RTZ22 mower?
My mower blades will not engage since I reinstalled the PTO clutch assembly.
  • 1,169 Answers
Hopefully you put back the stabilizer for the clutch assy. If not then it spun the first time you you crank the mower engine and destroy it wiring connections.
If this didn't with the mower not run but the ignition in the on position disconnect the connector at PTO clutch. Now switch on the PTO switch and using a voltmeter (DVM) check for the battery voltage across the two wire at the connector. If voltage is there then the PTO clutch is bad. But if the voltage isn't present then either you have bad PTO or ignition switch or have wiring problem.
Posted on Mar 31, 2015
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Why doesn't the PTO engage the blades?
assuming the PTO is an electric clutch engagement ? if so you must not be getting voltage to it. also you may have a safety switch restricting voltage from getting there. i have a rider that has this type of PTO and if my battery gets low mine will cut in and out as i mow. i charge my battery and then it works just fine. check for voltage at the clutch and also you can check continuity of the switch itself to make sure it does work. hope this is some help
Oct 13, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem
"On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem" Okay, what I'm hearing is that "nothing" means the blades-driving PTO won't engage (declutch) when you switch on mower; but then, (say) as you start to dismount the mower (seat) the mower (drive clutch) engages even as the deadman switch (seat switch) kills the engine (and the drive/pto shaft starts to slow down. The key here seems to be that at full engine torque the clutch is unable to remain engaged but, rather, slips so that mower blade inertia (resistence) cannot be overcome...but as engine/pto rotation slows the clutch is able not to slip. First place to consider is the clutch gap which is probably to0 large (possibly from wear and tear, possibly not). So check specs and how-to from manual or factory and reset the pto drive clutch gap...not hard to do. If clutch gap is not the problem then most likely rehab or replacement of the clutch assy will be needed...is the mower has many years use sufficient to wear out the clutch. Another possiblity is an electic (wring/switching/grounding) problem involving mower and deadman switches.
Aug 19, 2014 | Garden
John Deere SST16 PTO won't engage mower blades
check for power at the clutch if no power check the safety switches and the switch itself
Apr 23, 2012 | Garden
Mower blades will not turn on with pto switch engaged on john deere stx 46
first look for a blown fuse the old clutch may have burn it out the check to see if a safety switch burned out
Apr 01, 2012 | Garden
I have a 60" Lesco
If it were me I would check the PTO switch with it running and use a dvm or test light to see if switch is working or defective , you could just have a bad wire connector at the switch or at PTO clutch ....look for discoloration or spread terminals, good luck
Aug 01, 2011 | Garden
When engaging the blade for my Husqvarna riding mower, nothing happens. I recently had the mandrel assembly replaced for the left blade, and this is the first time I've tried to start it up.
It's possible the repair folks didn't properly reinstall the mower deck belt. Check that it's in place, and under good tension. If that's OK, look at the wires to the mower engagement switch (PTO switch) and make sure the connections are on tight. Then check the motor pulley where the PTO clutch is, making sure those wires still in place.
Jun 10, 2010 | Husqvarna 165HP 42" Lawn Tractor
Ariens ezr1742 mower blades do not engage....noticed after went over a stump.
The common cause of this problem is that one of the safty switches has come dis-connected or has failed since most every newer mower has a electric clutch controlling the mower deck PTO there are safties bilt in under the seat and in other locations to make sure everything is ok before the blades engage, easiest way to test this is to run a jumper from the positive post of the battery to the input wire on the electric clutch assembly making sure all other wires ade dis-connected from the clutch and see if the blades engage if so then usint a continuity tester check all the wires and switches to this item to check for a faulty switch or broken wire. Thanks Don
Nov 09, 2009 | Ariens 34 In. Zoom Series Riding Mower
Blades won't engage. OK-I need a pto clutch
A switch should only be about $25. Before you spring for a new PTO assembly, take your switch out and take it to a shop and have it tested. I may just be a bad switch. Don't bother taking it to Sears though. Take it to a shop that works on Husqvarna and/or Poulan Pro. (Both basically same as Craftsman). DO take the model number from under the seat with you.
Jun 24, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
