Question about Motorola Radio Communications
How do I restore the ability to pair
My bluetooth was acting funny. so i told the iphone to "forget this device" however, now I am trying to have it pair and it doesn't do it. I did this with a motorola bluetooth and was able to get it back. any suggestions?
  • 774 Answers
Go to the Apple Store, they will fix this for you in 5 minutes for no charge.
Posted on Mar 31, 2015
  • Sara Mar 31, 2015
    Good idea. Thanks
  • Official Brand Answer
  • 3,100 Answers
Sara-
What Motorola Bluetooth Headset do you have? You'll need to get your Headset back in pairing mode so you can search with your iPhone to find the headset and connect it.
Mark
Forums Manager
    Genius:
  • Motorola Master
  • 2,669 Answers
Go into settings and make sure it is enabled. Hope you did not delete the software.
  • Sara Mar 31, 2015
    I have a Motorola Bluetooth which I treated the same way but I am able to pair it anyway
They will not pair with my I phone, just says searching for your music device. I have turned my iphone on and off, it used to connect without a problem
Go into the iphone and remove any devices left in the Bluetooth cache.clear cache and forget any device.then start a new search.
i have heard it is sometimes possible to refresh by turning on airplane mode then back into network.this also a good way to restore airplay.
Dec 08, 2015 | Cell Phones
User manuals free downloads
Hi. I may be able to help you, but I will need more information. Specifically, which device are you trying to pair to your iPhone? I assume you're talking about Bluetooth, right? You can use Bluetooth devices with your iPhone, including headsets, car kits, stereo headphones, or an Apple Wireless Keyboard.
To specifically answer your question, I would need more information about what you are trying to pair with your phone. Note that the documentation that came with your device (headset, car kit, etc) should contain instructions. Is it a Plantronics that you're trying to pair by any chance?
Also, from the title of your post, it appears that you're trying find free manuals for your iPhone. You can access the iPhone Manual from this site: http://support.apple.com/manuals/
If that link doesn't work for you, just go to www.apple.com, click on the Support tab located in the bar at the top of the screen, then scroll all the way to the bottom of the page and look for Manuals under the Resources column in the rectangular "Support" box at the bottom. From the new page that opens up, select "iPhone User Guide -- For iOS 7.1 software." You can download the manual or simply view it. It is very long! Bluetooth Devices are located in Chapter 3: Basics, page 35. BUT, the manual doesn't really tell you anymore than what I've listed below.
Here are some basics, if that is all you're needing:
Turn Bluetooth on. Go to Settings > Bluetooth.
Connect to a Bluetooth device. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. See the documentation that came with the device for information about Bluetooth pairing. (For information about using an Apple Wireless Keyboard, there are different instructions.)
iPhone must be within about 30 feet (10 meters) of the Bluetooth device.
More basic instructions are here:
Return audio output to iPhone. Turn off or unpair the device, turn off Bluetooth in Settings > Bluetooth, or use AirPlay to switch audio output to iPhone. See AirPlay on page 34. Audio output returns to iPhone whenever the Bluetooth device is out of range.
Bypass your Bluetooth device. To use the iPhone receiver or speaker for phone calls:
Answer a call by tapping the iPhone screen.
During a call, tap Audio and choose iPhone or Speaker Phone.
Turn off the Bluetooth device, unpair it, or move out of range.
Turn off Bluetooth in Settings > Bluetooth.
Unpair a device. In Settings > Bluetooth, tap next to the device, then tap "Forget this Device." If you don't see the Devices list, make sure Bluetooth is on.
Aug 06, 2014 | Apple iPhone 5c
How do I get the blue tooth to cancel the "in use" signal"?" The phone or car functions do not respond to any prompts.
Maybe i don't get it, but you can simply turn off bluetooth on your iphone to cancel all bluetooth connections immediately. Re-Enable bluetooth to re-engage your connections.
If you wan't your iPhone to "forget" a paired bluetooth device just go into the bluetooth settings and tap on the little info badge for the device you want to remove. From there you can delete this pairing.
Apr 24, 2014 | Apple iPhone4 4G iPhone 4
Cant pair my iPhone with jabra sp5050
forget the headset
turn bluetooth off
turn the headset device off
reboot phone.
try again
Mar 04, 2014 | Jabra A320s Bluetooth Wireless Adapter
I told my Iphone to forget a bluetooth device, how do I get it back because it won't pick it up on my phone anymore?
First thing you need to do is to go into your Bluetooth settings and make sure that your phone is set up to pair with a device. Next, make sure that the device your are pairing to your iPhone, is in pairing mode. After both of these steps are complete, the phone should recognize the device and you can complete the pairing process. Hope this helps!
Jan 12, 2013 | Apple iPhone Smartphone
IPhone not pairring with parrot ck3100: I pressed "forget this device"
remove other paired devices on your device, may be the device has crossed the limit of phones it can connect.
start pairing fresh on both devices- phone and bluetooth device.,
Jun 06, 2017 | Apple iPhone 4S
I forget my bloothoot password
Hi ricky123mar! What device are you trying to pair? Do be able to re-pair just delete the current bluetooth settings and try to pair again.
Jan 05, 2012 | Apple iPhone 3G
Cannot pair S305 to iPad 2
If you have the headset paired w/ another device, you have to "forget" it on that device and then try to pair w/ the iPad.
I was having the same issue w/ new iPhone 4, but this solved it for me. It is a bit annoying to have to forget and unpair every time you want to switch devices, but oh well.
Apr 02, 2011 | Motorola Mobility S305 Bluetooth Headset
By mistake I touched "Forget
Remove the device from the computer, and remove the computer from the phone, then start over and try to pair again
Mar 02, 2011 | Apple iPhone Smartphone
Have put bluetooth on but it wont paid with any
To your diappointment the Iphone cannot send photos, songs, or anything like that, yet. What you can try is restoring your Iphone and then see if you can pair it with your device. If that doesn't work, then it just means that the device you are trying to pair with it non-compatible with the Iphone.
Oct 27, 2009 | Apple iPhone 3G
Radio Communications Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
