Question about Casa Vieja 52" Costa del Sol Scroll Ceiling Fan
Easy way to change light bulbs in housing without taking it all apart.
    Genius:
  • 2,465 Answers
Just remove lens and change bulb.
Posted on Mar 31, 2015
I need to replace the front fog lamp bulb on my 2014 Hyundai i10 1.1. Can anybody tell me how to do this?
Without lift, without dismantling the bumper. You can lie on the ground split. Fog lamp housing with two screws locked, you can start with a wrench 7MM demolition, but it is best to use 7MM sleeve, easy to split the left and right of the difficult demolition, you can remove the bulb to be loaded into.
The first time I was looking for repair of changing light bulbs, the next time you will know how to change a light bulb
Car Diagnostic Tool
Aug 22, 2016 | Cars & Trucks
Changing headlight bulb.
Some car it is hard I did G6 took me one hour.You can get bulb or whole light out.
Apr 25, 2013 | 1993 Chrysler Lebaron
How do I change the interior light in a 2002 chrysler sebring
perhaps if you were to take a good picture and post it we would have a better idea, as I can not imagine a metal cover over the bulb unless it is some sort of heat shield .
Aug 21, 2012 | 2002 Chrysler Sebring
2003 mazda tribute. How to change license plate bulbs. I can't get the plastic housing off.
It's easy, but may need some patience. No need to take off rear door inside panel! Press firmly on the left side of the light housing. It should move towards the right..then pull up slightly and it should pop out from the door panel. Twist the center bulb housing counterclockwise just slightly and the bulb should disconnect from the lense. Pull the bulb out...and replace with new bulb. Replace both sides if you like.
Nov 23, 2010 | 2003 Mazda Tribute
I need to replace the bulb. Do I need to order the bulb only or bulb+housing. where is the bulb located on the back of tv? Thanks for the help
If you are looking at the back of the TV look on the left hand side to see if there is a access panel on that side of the TV - open it up and you will see the light bulb housing - take it out and look to determine whether you think you can replace the bulb by yourself or if you need assistance - I will say this most of the LGs are not soldered on they are put on using a small nut and they are easy to replace - 1 note is to order just the bubl if you think you can replace it yourself but DO NOT remove the bad bulb from housing until you get the new bulb so you can see how to hook up the new bulb :-) plus it usually takes about a week to get the new bulb in and sometimes people tend to forget how things were taken apart :-) Good Luck you will save money if you order only the bulb!
Thanks,
MC
Oct 28, 2010 | LG RU-52SZ51D 52" Rear Projection...
How do I replace the turn signal bulb on my 1997 Jeep Grand Cherokee? It seems like I must remove alot of the front end to get at the bulb... is this true?
For the front turn signal:
There are two ways to get at the bulb.
Way 1) YOU NEED A SKINNY SHAFTED STAR SCREWDRIVER. This is how the manual describes it: Unscrew the 2 star screws holding the parking light housing on. One is on top, the other is between the parking light and the turn signal. This second screw can be very difficult to get to because the parking light and turn signal housing are very close. After the parking light housing is off, you can unscrew the turn signal housing. The screws should be located on top of the housing, underneath the parking light housing.
Way 2) This is the way I did mine: First, you have to take the headlight housing off. It should be pretty easy to pop off if you pry it the right way. It is held on by 1 square clip and 2 ball and socket clips. There is a small risk of breaking the ball and socket clips, as getting the headlamp housing off does require a little force, so be careful. You may want to take the headlight bulb out first, but isn't necessary. (Removing the right side bulb may require removing the battery) Once the headlamp housing is off, the turn signal bulbs should be very easy to get to.
To remove the bulb, simply turn the bulb socket and it will come out.
For the rear turn signal:
Open the lift gate.
There are 3 hex screws that hold each rear light assembly on. I'd recommend a hex screwdriver, as a socket wrench or box wrench would be very hard to use on the screws. Once the hex screws are off, just tug on the light assembly and it will come off. The bulbs are very easy to get to. The turn signal is the yellow one.
Nov 10, 2009 | 1997 Jeep Grand Cherokee
Drivers Side brake light bulb is burned out.
Pull the panel back on the INSIDE of the car's hatchback or trunk. The bulbs twist in from the back.
Dec 03, 2008 | 1993 Ford Mustang
Replacing front turn signal bulb on 2006 Cadillac SRX
wow i feel sorry for you because Cadillac designed this bulb to be a don't get to bulb but OK here's what you do take the bottom cover off or skid plastic panel under neath the front end theirs little plastic clips holding it on just get come dikes and don't cut them but just use it to help pull them out. after you get that off use a flash light and locate your light housing you should see two screws holding the house in i think those screws are 8mm i cant remember remove those two screws and be careful the metal from the bumper cuts you pull the light housing out and remove all the screws around the housing and open the housing up replace the bulb and make sure your contact to the bulbs clean and then reassemble the way you took apart. if you cant get it well then best bet is take it somewhere i know Cadillac charges an arm and a leg so you can go somewhere else.
Nov 13, 2008 | 2004 Cadillac SRX
How do you change the fog light bulb on 1993 zx?
Take out the small screws that hold your turn signal/marker lights on. This will allow you to reach in and undo the three (if I remember right) 10mm nuts on the back of the fog housings that hold them in the bumper. Once they're removed, press on the back of the fog housing and the foglight assembly will pop out of the bumper. Then you can replace the bulbs.
What I did on my Z is something you might consider - while I had them out, I took them apart (just a couple screws and bolts, very easy). Open it up so that you have access to the glare guard - the cup that sits in front of the bulb. This blocks forward projection of the light, and instead bounces it onto the reflector to be spread very wide (but not far forward) in a fog beam pattern. I used pliers to physically break the guard off the housing, so that instead of a wide, shallow fog pattern, I had a forward-projecting driving beam. I also swapped the 35w OEM bulbs for 55w higher-output superwhite bulbs (this increase in power consumption is not enough to cause any risk to the wiring or fusing, by the way - it worked for years for me). Then put them back together and reinstall them - you'll find a drastically improved light pattern for night driving, and they're still low enough to the road to cut under most fog. Especially since I always felt that the Z headlights were pretty pathetic for output (at least until I installed HID lighting), this was a great mod to make to the car.
Sep 04, 2008 | 1993 Nissan 300ZX
Removal of projector bulb housing
Here is a better site for instructions. It has a .pdf file.
http://www.911phone.net/Panasonic_TY-LA1000_Instruction_Manual%5B2%5D.pdf
Feb 21, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Casa Vieja 52" Costa del Sol Scroll Ceiling Fan Logo
166 people viewed this question
Top Casa Vieja Dryers Experts
Stan Ford
Tom Chichester
Bill Boyd
Are you a Casa Vieja Dryer Expert? Answer questions, earn points and help others
