There is a video but there is also horizontal lines
    Top Expert:
  • Televison & ... Master
  • 75,157 Answers
Vertical retrace lines; is the fault. It will appear horizontally. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Reasons and repair-work to this fault is given.
Posted on Mar 31, 2015
Zenith 50 Inch Plasma TV has black horizontal lines
Generally black horizontal lines are from the panel being bad, you could try a new Tcon board but I doubt it will help
Feb 07, 2018 | Zenith Televison & Video
Tv has horizontal line in middle of screen,sanyo ds25390
hi if only a horizontal line across with no video anymore, you have bad either vertical ic or no dc supply b+( vertical ic ) or no output dc coming from the ic. if it is not totally a horizontal white line and you can see a video you must check leak or bulged capacitors at the vertical section near the vertical ic. hope this can help good luck.
Oct 02, 2012 | Televison & Video
Hey I got an IBM T42. It boots fine when its clear but after that it horizontal lines being to appear througout the scree.
Either you can hook up an external monitor or access BIOS setup (Basic Input/Output System) to replicate if the horizontal line appears. This step will check if the problem is with the video card or the LCD.
If you get the horizontal line on the BIOS or never get it on the external monitor, then surely the LCD screen is beginning to fail. You need to reinsert and/or replace the LCD inverter or LCD itself.
However, if you see the horizontal lines on the external monitor but not on the BIOS, try to update the video driver. If this will not resolve the issue, you need to replace the video card or the motherboard of your laptop.
Hope this helps.
Jun 06, 2011 | IBM ThinkPad T30 2366 Notebook
Horizontal line pictures
am getting experience the same problem - horizontal white lines on blurry still pictures - after 2 years. But the video is working properly.
Aug 03, 2009 | Canon PowerShot A430 Digital Camera
DCR-PC4E HORIZONTAL LINES ON VIEW FINDER WHEN VIEWING PRE RECORDED CASSETTES
These horizontal lines are due to dirty / clogged video head. Use good quality video head cleaning tape and clean video head of camcorder.
Thanks.
Apr 27, 2009 | Cameras
Horizontal grey lines running whe camcorder in play mode
Its symptoms of dirty / clogged video head. Please use Sony video head cleaning tape to clean video head.
Jan 28, 2009 | Sony Handycam DCR-TRV140E Digital...
Capture video from composite input
you should make sure everything that may cause interference is away from any of those cables, such as cable/dsl modem, wifi router..etc because they cause a large amount of electromagnetic interference
Nov 02, 2008 | Pinnacle DV500 DVD Video Capture Graphic...
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Horizontal Lines in picture
CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. HOPE THIS HELPS!
Jan 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
