Question about Poulan Garden
Can I bye a fuel tank anywhere for my Poulan P3400
    Genius:
  • 2,653 Answers
The manufacturer should be able to supply a new one .www.jackssmallengines.com/poulan_chainsaw_parts_index.cfm can supply.
Posted on Mar 31, 2015
Broke small black connector between fuel line to side of carburetor. Flat bottomed funnel shape fits in to side of carb. Has filter inside. I believe it feeds the primer.
That is a fuel tank vent kit. Most models have a vent in the fuel cap but that model uses a separate line with a Duck bill vent (usually a green rubber inside that piece in picture). Part number for that is 574859301 . Your blower should run ok with out it but could leak fuel. If you are going to order any parts for your blower do so using Model # PPBP30 Your parts will be cheaper. That particular model has exchanged hands between MTD/Mcculloch/Bolens and Husqvarna/Poulan over the years. The parts are cheaper when you use the Husqvarna/Poulan model # PPBP30. Only noticeable difference will be a yellow starter housing if you buy a starter assembly.
Dec 17, 2015 | McCulloch ASB3206 - Blowers - 30cc Gas...
Poulan 21cc weedeater - starts but won't stay running. I've cleaned all fuel lines, cleaned plug and has plenty of gas - but still won't start. runs for 2 or 3 seconds and dies. appears to not be getting...
On these types of motors that could be the problem, another thing to check is the primer bulb. I have had a primer bulb that had a small crack in it which went undetected for a while. These types of motors do not have a fuel pump and they work on a siphon type mechanism, if there is an air leak dealing with the gas tank anywhere, that is your problem.
Aug 11, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan P3400 Chainsaw Fuel Line Routing
If the saw has a primer bulb, then you require one line from it's output out to the tank return. Another line runs from the carburetor outlet to the primer inlet. Make sure that you use original rubber lines, not plastic replacements. The primer ports are found by trial and error--hook the filtered line directly to one primer port and leave the other port open. If the bulb is in good condition, and correctly connected to fuel, the bulb should fill with fuel after several pumps. If nothing, reverse the port connection at the primer--and pump test again. One of these two connections should allow pumping to occur. When you get pumping, install the tank return line to the empty primer port. Remove the filtered line from the primer and install on the carburetor. A new piece of line runs from the now empty primer port and connects to the output port on the carburetor. If the carburetor lines are correct, you should be able to pump fuel through the carburetor body and out to the primer bulb. If nothing happens, you may need to swap the carburetor lines, and you will likely need to service the carburetor. Hope this helps!
May 25, 2010 | Garden
How to replace Poulan fuel lines
it takes a lot of patients, you have to pull the gas tank, the line runs into ght gas tank with filter on it pull the hose off the carb first and feed it into the gas tank until you can reach the filter to get it off, than you can pull the hose out of the tank , get the same size line so it will fit in the hole of the gas tank. put it back together in reverse.
Feb 22, 2010 | Poulan Garden
I have a Poulan 2450 thats not getting any fuel, I drained the fuel tank. When I looked inside and the fuel line,the white filter and the gromet which goes from the inside to the outside of the tank was...
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
Typical fuel system:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
2450 Gas Saw Type# - # is the dash number of your serial number.
HTH
Lou
No one illustration shows all fuel system components.
Nov 28, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan pro weedeater will start fine run untill you pick it up then dies
poulan has a bad habit of the fuel breaking inside the tank if it breaks before the fuel filter that makes the fuel line shorter
Nov 05, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Fuel line crack dry out, in pieces
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Find your saw here:
Poulan.com
SmallEng.com
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
I think the second line on the carburetor is an impulse line and connects to the crank case. HTH
Lou
Oct 08, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need a repair diagram for a poulan 2050 that shows just where each gasline goes. Anyone know where to go?
the bottom fuel line that goes to carb lower port also goes to the fuel tank look inside fuel tank threw gas cap hole to find the fuel filter hose is picking up the fuel and bringing the gas to the lower fuel port into carb (the upper from carb goes to prime or return to tank)
May 09, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
47 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
