Question about Philips Televison & Video
No subtitle button on the Philips SRP4004/86 universal remote. Is there a way to program that option?
    Master:
  • Philips Master
  • 487 Answers
Talk to Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Posted on May 05, 2015
aprmaejun
  • 97 Answers
SOURCE: philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jul 29, 2008
SOURCE: i lost my manuals to my philips universal remote how do i program it wthoout using the code
I lost my instructions to program my tv with the remote can you help me
Posted on Nov 13, 2008
  • 7 Answers
SOURCE: Philips Universal Remote PM435S reprogramming
I have the same tv and remote that you do. I went on Philips website and they have instruction manuals and the code lists. You can also press and hold the 'CODE SEARCH' button until the light stays on. Then press 'TV' button. Make sure your TV is on and press Channel Up button until the channel changes on your TV. If you go too far, press the Channel Down button until it changes again. Then press the Mute button to store the code. Good Luck!!
Posted on Mar 29, 2009
  • 5 Answers
SOURCE: need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red indicator stays on and release button
3: press and quickly release what you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again.
5: press and release MUTE to install the code.
Posted on Jul 17, 2009
jhinsincity
  • 616 Answers
SOURCE: i need codes for my universal remote
INTERNET!!!
Posted on Aug 23, 2009
How to program Phillips universal remote for TV.
    Select the Device You Want to Control. At the top of your Philips universal remote, there will be several buttons with names of devices on them (e.g. Television, VCR, DVD, etc.) Toprogram the remote for a certain device, choose the button with the name of that device, then press it while the light of theremote is on.
    How to Program a Philips Universal Remote ' eBay
    www.ebay.com/gds/How-to-Program-a-Philips-Universal-Remote-/.../g.htm...
Feedback
Universal Remote Control Code Finder - Philips
Jan 01, 2016 | Universal Televison & Video
Tip
Programming Philips Universal Remote Control To Your Device
Program the Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2. Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3. Release the Setup button
4. Press the button to which you want to programme(TV/VCD/DVD).
5. Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7. If the device responds, you have successfully programmed your Philips universal remote.
8. If the remote is not programmed then, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
1. Turn all of your devices off, and then manually turn on the device you want to program.
6. Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To Get The Programming Codes :
Please go to below website to get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote model.
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
Attached a image for your reference:
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
on Jul 27, 2010 | Televison & Video
Is there a way to access the subtitle button on a philips dvd player using the chunghop RM-88E universal remote control? Please help :(
Aren't you trying to select closed captions (CC)? If so, turning off the TV sound will cause closed captions to appear after a brief pause. Naturally, your TV has to be capable of doing this
Nov 02, 2012 | Televison & Video
Philips
You must have its original remote control to do this. Contact the nearest authorised service center for Magnavox.
Apr 28, 2012 | Philips Televison & Video
I can not turn off the closed captioning on my philips tv , i do not have the original remote to the tv but my cable remote works as a universal remote, please help me the subtitles are driving me crazy !...
I have direct tv, and had the same problem. After an hour on the phone with the worthless tech, I gave up. Finally I figured it out. First of all do you have closed caption problems or is it "subtitles". mine turned out to be direct tv subtitles, not closed caption. I hit the yellow button on the direct tv remote, and presto. Subtitles was set to the on position. changed it to off, and what do you know. fixed.
Jan 02, 2011 | Philips Televison & Video
I am using a Philips SRU3003WM/17 Universal Remote with my Sylvania TV Model number 64119E. When programming the remote some strange numbers appeared on the screen and now I cannot get them off. The...
Well your Philips universal remote control comes with a list of codes for devices by brand name.
Find the first code for the brand name and type of device you wish to program. Turn all of your devices off, and then manually turn on the device you want to program.
Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid. Release the Setup button. Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV.Release it immediately and make sure the indicator light is illuminated. Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button. If the device responds, you have successfully programmed your Philips universal remote. If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
If your TV code is not listed on the manual then you can use the Remote Using Code Search Option -
Your Philips universal remote has a built-in code search feature that will find the correct code for your device. This process may take longer than using direct code entry, but can be helpful if you do not have access to the code list or if the brand for your device is not listed.
Make sure all of your devices are turned off, and then manually turn on the first device. Press the Code Search button and hold it down until the red indicator light stays illuminated. Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV button.  Release it immediately and make sure the indicator light is illuminated. Press either the Channel button until the device responds. You may have to press the button up to 300 times. Each time you press the button, the Philips universal remote tries a new code. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
I thing you wrongly do the second option that creates the problem. No issue, if your tv code not listed on the manuals then you can go with the second (code search) solution. Please post comments for further help or information.........
Good Luck!!
Thanks
Jul 31, 2010 | Televison & Video
RECTANGULAR BLACK BOX COVERS ONE THIRD OF SCREEN DURING LIVE PRO FOOTBALL GAMES AND MARCH MADNESS BASKETBALL . HAPPENS ON CBS AND ESPN. ALSO SOMETIMES ON FOX TV.
 I programmed my PHILIPS Universal with code 0115 then the subtitle (CC) button worked no problem.I am sure any Universal remote with the subtitle button that u can program will work. My Comcast Remote would not work.Did This Help ?
Mar 30, 2009 | Orion STV2763 27" TV
Turn off c/c
Not a big mystery. You just need a remote that can turn them off, unless the panel buttons have a CC menu option.
Mar 02, 2018 | Philips 25PS40S 25" TV
Can't turn subtitles off
Hmm... have you tried ontop of the remote where it has "tv" vcr" sat" etc...hit tv first then try the menu?and do you have satelite by any chance? because something similar happened to me when i had my old tv put upstairs and hooked up, the remote for it did not work so i had a universal and the tv was on "video 1" input the whole time and the universal remote didn not convert it back to tv so what i had to do was hook up the reciever to the "video 1" port instead of the "tv" input in the back...i hope you get it cause i know it can be a pain in the A$$
Sep 13, 2008 | Televison & Video
I want to thank whomever suggested the following...it works. I had been trying for days. Here is the solution:
Turn off the cable box and hit the menu button on the universal remote. The screen with the closed caption selection appears. Scroll down to the line regarding subtitles and turn it off.
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
