Question about Whirlpool Washing Machines
I have a Whirlpool Duet Dryer that I purchased in 2006. It runs fine but during the day when it is not running, it makes some sizzling, zapping noises that sound like they are coming out of the control panel up top. It might last for 3-4 seconds. This is now happening randomly throughout the day. Any thoughts on what this might be. Again, this happens when the dryer is not running.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
HI KEN,ITS LASTED YOU VERY WELL.THE LAST TIME I OPENED
A DRYER THAT OLD THE INSIDE WAS LITERALLY FULL OF FLUFF AND FIBRES,AND SCORCH MARKS IN SEVERAL AREAS.IT SOUNDS TO ME LIKE A LOW VOLTAGE SHORT
ON YOUR FUNCTION BOARD.MY ADVISE IF YOU CAN AFFORD IT GET RID,UPGRADE TO NEW.IF NOT PLEASE GET A SERVICE GUY TO OPEN IT UP FOR A LOOK.IF YOU CAN WATCH HIM EVEN BETTER BECAUSE YOU WILL SEE ALL THE FLUFF N BITS INSIDE..NOT TO WORRY YOU BUT LEFT UNCHECKED,WORSE CASE?IT BURNS YOUR HOUSE DOWN MATE,IT IS CURRENTLY A TICKING TIMEBOMB..ALL THE BEST MARK IN SWANSEA
Posted on Mar 31, 2015
Testimonial: "Thanks Mark for the input I was kind of wondering about that myself. I looked at the cost of a new board and figured it would have been good to go ahead and replace it - however - I threw some wet towels in it to dry them and after they were finished I went to the garage and turned off the breaker for the dryer. I go back into the laundry room to push on just to make sure I turned off the correct breaker. Right before I pressed the button, I heard the static like buzzing for about 2 seconds. I hit the on and it was definitely off. But since I was standing there this time I recognized exactly where the sound was coming from. There was an electric dog collar sitting up on top of the dryer that has been there for a couple of weeks. Turns out my wife never noticed it as she was telling me about this problem. Turns out the dryer is fine! Thanks for the help!"
Whirlpool (Old) dryer makes a zapping noise at the outlet. It will run, but there is no heat
Unplug the dryer, IMMEDIATELY.
Get a Pro to check for wiring shorts or heating elements that are, burned loose, touching or other wise going to ground...
What you are describing is a severe fire hazard if not corrected...
Feb 16, 2014 | Dryers
Whirlpool Duet dryer time skips mins.
clean the stainless steel sensor pads located just inside the dryer door with isopropyl alcohol,these sensors register moisture in the garments and adjust drying times accordingly,when you use dryer fabric softener sheets it coats these sensors and throws the system off,make sure to shut off power to unit as this alcohol is very flammable,then leave door open to air out before re-powering up unit
Apr 24, 2012 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet dryer runs way too hot, even during air only cycle.
sounds like restricted air flow to me . check filter and the vent for plugged pipe
Apr 18, 2012 | Whirlpool WED9400S Electric Dryer
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
Dryer quit heating runs fine it is a gas dryer
Is the pilot light or "stricker" working when you start the unit.. Is it getting good supply of gas?
Mar 12, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet Dryer not heating
FIRST YOU SHOULD CHECK YOUR BREAKERS MAKE SURE BOTH ARE ON. YOU NEED 110V TO RUN THE MOTOR BUT 220V TO HEAT.IF THAT IS FINE IT MAY BE A SENSOR OR A ELEMENT.
Jan 15, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
WHIRLPOOL DUET HT FRONT LOADING WASHER
This is a strange problem. I work on these all day, and never have a problem getting these boards. Might want to try and calling local part houses for this part.
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
