Color lines on screen - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,599 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Mar 31, 2015
Vizio 46lfhdtv20a verticle rainbow line down the screen. picture start playing and after a while the color line cover the screen
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 29, 2016 | Vizio VO47L 47 in. LCD TV
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
TV HAS A COLOR LINE WHEN IS ON IN THE MIDDLE OF SCREEN
if it runs across the screen its a buffer board usually. Can you paste a picture of the line?
Mar 10, 2013 | Sanyo DP50747 50 in. Plasma TV
I am getting lines on my laptop screen. the colored lines appeared all of a sudden and hiding half of my screen. pls help
Hi azmiug,
I see that you are getting colore lines on the screen hiding half of your LCD screen, Please see steps below.
*Turn your Laptop OFF.
*Once Turned OFF, Turned the Laptop back ON then keep on tapping F2 on your keyboard.
*By Tapping F2 on the keyboard this will bring you to the BIOS screen, once in the BIOS of your Laptop and the Colored Lines are still present then the problem is the LCD of your laptop and may reuire replacing.
*If the Colored Lines are not present then the Problem would possibly be the connection of the Video Card to the LCD or the Video Card itself.
*Reformatting Windows can be one of the steps to be done to find out if the issue Colored Lines will be fixed or not.
I hope that this will help you with your concern.
Have a nice day,
mvincentc
Apr 24, 2011 | Computers & Internet
I have compaq laptop, in my screen lines with colors are view in the bottom of the screen laptop is working had only one problem
lines color ? if these lines are in color red green or blue you must be change the panel screen couse yuo have brocked pixels
Jan 09, 2011 | HP Compaq Evo Notebook N600c
Lines across screen
If the lines are slightly diagonal and in red, blue and green you have a problem in the ABL circuit. if the lines are only one color you may take the front grill cover offf and remove the panel. look fro the black box 2 inches square with 6 little controls on it. 3 are for focue 3 are for screen the middle on of the screen is the green adjustment the other 2 should be labled r and b respectivly. what ever the color of the line turn the control labeled screen and r b or g for that color ever so ligtly counter clock wise.
Mar 30, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Noticeable line through screen picture sony KDL-40V3000
TRY USING THE COLOR CONVERSION OPTION ,,ITLL FIX THE COLOR
Mar 07, 2009 | Sony BRAVIA KDL-40V3000 Television
Philips Flat Screen Green Lines
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
Nov 28, 2007 | Philips 20 in. TV/VCR/DVD Combo Flat...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
