Question about Sharp Televison & Video
I have a sharp aquos LCD TV model # LC-C5262U it has lines in the picture and a double picture aswell
    Top Expert:
  • Sharp Master
  • 74,251 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Mar 31, 2015
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
  • 53 Answers
SOURCE: yellow box with the letter "K" in it.
the TV needs to be reset with the Factory Initialization. Try contacting Sharp at 1-800-327-4277 for instructions.
Posted on Mar 14, 2008
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
rulds2008
  • 3866 Answers
SOURCE: Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
Posted on May 15, 2009
  • 73 Answers
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Posted on Sep 27, 2009
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
What voltages should I look for on the RDENCA184WJQZ power supply for my Sharp Aquos LC-C5262U TV that will not power up.
SMPS output voltages and input voltage should be checked. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 21, 2015 | Sharp Televison & Video
No sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Nov 24, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
What is the best settings for a sharp lc-c5262u lcd tv?
whar ever your taste are there are no best setting on any set just play with your settings till you get what you like you can always reset to default setting
Nov 21, 2009 | Sharp LC-C5262U 52 in. LCD TV
Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
Jul 13, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
52 SHARP AQUOS
Either bad connection with the LVDS cable, defective LCD controller, or even a defective LCD panel. Can you post pictures?
Nov 13, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Yellow box with the letter "K" in it.
Sep 17, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
