Question about Toys
How do you tilt the bed on a farm pro raider utility vehicle
Can not figure out how to get the bed to tilt
How do you change the head gasket in a 1988 dodge raider
This kind of jobs, need a repair store. If the head and the block are not exact flattened, you will blow out the gasket within one hour. Afer you blew out the head gasket it needs a revision like repair.
Oct 27, 2014 | Pro Boat Head Gasket 18
Farm pro raider(Homier)
Only thing left is compression. Stuck valves will affect compression as well as worn rings.
Jan 23, 2014 | Peg Perego John Deere Farm Tractor and...
Need a charger for model number kt1085wm mongoose raider quad
I have 6v chargers with alligator clips on the end that work, you'll just have to remove the plastic battery cover (6 screws) so that you can clip it onto the battery
Jan 06, 2013 | Mongoose Raider Quad Ride-on Bike
Im having problems figuring out how to convert my bebecare stroller yo its collapsed/flat form?
To fold a Raider AT pushchair, first make sure that the front wheels are locked into the non-steerable mode. Next, look at the twist-grip in the middle of the handle. Press the central red button and simultaneously turn the collar in the direction of the arrow. The chassis should begin to close at this point.
Then find the lever on the side that operates the secondary locking device. Tilt the chair forward and continue folding until it is fully closed. It may be necessary to align the front wheels with your foot in order to enable the chair to close fully.
An instruction manual, with diagrams, is available from service@bebecar.co.uk
Jan 05, 2011 | Bebecar Raider AT Stroller
Windshield wipers dont work in the rain
replace the wiper relay located in the fuse box in the engine compartment.
robert
Sep 10, 2009 | 2006 Mitsubishi Raider
Toys Logo
50 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
