Question about Garden
Why is the dip stick blowing out
Runs for a few minutes then blows out
    Top Expert:
  • 10,875 Answers
Must be a dip stick blower,its a new model
Posted on Apr 28, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
The dip stick on a leaf blower ?
you sure ?
Do you have a Billy Goat blower ???
    Top Expert:
  • 6,702 Answers
You must have blown a gasket. Most likely the head gasket. Won't take long till the motor stops complete.
Posted on Mar 31, 2015
My intec 22hp. Briggs moter blowing compressed air out dip stick
they all do that to some degree . some vent back to the carburetor and some use that pressure to power the fuel pump .
May 14, 2016 | Garden
What's your question?my Isuzu 4ja1 engine .my problem is the oil comes from deep stick
i think you mean
when running the engine
the DIP STICK seal as it fits the dip stick tube end. leaks oil
this a bad PCV valve.
excess crank case pressures.... cause by not doing service on car.
or worse a very worn out engine with huge blow by gassed.
is engine miles high? over 300k? miles?
or the dips stick seal there is bad.... looking at it tells you that.
Sep 20, 2015 | Isuzu Cars & Trucks
Too much oil in pressure washer
NEVER run any motor with too much oil. You can blow the seals. Let some out to achieve the correct level. Also, verify that you are reading the dip stick correctly. Many motors you DON'T screw the dip stick in when takeing a reading. Just wipe it and set it in.
May 19, 2014 | Garden
17hp briggs and stratton blowing oil out of dipstick
looks the rings are stuck.when you have head off check piston. john.
Mar 10, 2014 | Briggs & Stratton Garden
5.3 blows dipstick out
Sounds like your piston rings are bad causing excessive blow-by ...meaning your power is going around your rings and building massive crank pressure and using your dip stick housing as if it were a pressure relief valve ...motor needs to be rebuilt by an automotive machinist.
Jan 12, 2013 | 2004 GMC Sierra
Why is my diesel blowing oil from the dip stick?
Sounds like blow-by...due to worn piston rings. (Compression that gets pushed past the rings, into the engine crankcase, and out the dip stick tube.) Make sure that a vent may not be plugged.
Sep 08, 2011 | Isuzu Trooper Cars & Trucks
The oil dip-stick is blown out of its seat when the compressor runs
Without knowing what make or model you have, check the following:
1. Some, not all, compressor dip sticks have venting holes for the crankcase. If the vent holes are plugged or the check ball is stuck the dip stick will get forced out when the piston comes down.
2. Make sure the oil level is where it's supposed to be. Too much oil in the crankcase will cause the motor to work harder and the excess oil being splashed around the crank case can overwhelm the vents in the case or dip stick and again blow the dip stick out.
3. Worst case, you have worn or broken rings on the piston(s), a hole in a piston or a badly scored cylinder(s) and air is leaking past the piston and creating pressure in the crank case and blowing the dip stick out.
Jan 26, 2011 | Campbell Hausfeld Air Tools & Compressors
I have a clark rebel air 30 the compressor work ok but now and again it blows the dip stick out .
The crankcase should have a breather on it that is probably stopped up by a dirt dauber nest. This could cause the dip stick to blow out.
Jun 20, 2010 | Air Tools & Compressors
My 1979 chevy bonanza 4wd. pickup has started blowing transmisssion fluid out the dip stick tube,after the truck warms up a few minutes.thank you albert blair
turbo 350? if so it can be that it is over full or sometimes the gears that are in the tranny that sling the tranny fluid up will get bent or worn and will sling oil to the wrong spots and that will cause your gears to get hot and expand and that can cause it to shoot oil up your dip stick
Dec 04, 2008 | Chevrolet 1500 Cars & Trucks
Garden Logo
251 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
