Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire side,by side digital display flashing #4, what does,this mean....the freezer side is not warm, but nothing is staying frozen, the fridge side,is cool, but not cold
  • Brett Corris
    Brett Corris Mar 31, 2015
    model # FRS6LF7FM9
  • Official Brand Answer
  • 2,267 Answers
Good Morning Brett, thanks for your inquiry!
I understand that your Frigidaire refrigerator is flashing a "4" and you would like to know what that means. The "4" on your display means that there is a damper failure within your refrigerator and I would recommend checking the damper in the rear of the refrigerator to assure it is opening and closing. The damper is located in the back of your refrigerator. I would place your hand back there to assure it is blowing cold air into your refrigerator.
If the damper is not working it could be a potential issue with your damper, main control board, or wiring harness. I would then recommend performing a reset on your refrigerator. You can do that by unplugging the power cord for roughly ten minutes. If this does not help resolve your issue I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Posted on Apr 02, 2015
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
We have a 4 year old frigidaire side by side refrigerator, model phs69ejss0, it has stopped cooling fridge and freezer and there is a 4 flashing in refrigerator temp display area, any idea how to fix?
The Flashing #4 occurs when power is applied to the fridge and the control board goes through it's cycles and didn't detect a damper connection.
So its your air damper that's bad.
Here is the part to order.
Dec 09, 2012 | Frigidaire Pro PHS69EJSS Stainless Steel...
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
Freezer keeps defrosting and nothing is stay frozen and nothing is staying cold in fridge either
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 20, 2010 | Frigidaire FRS26KR4A Side by Side...
Temp display (fresh food temp) has flashing # 4. Any idea's? Mod# GLHS36EFSB1 - side by side fridge
my Frigidaire showed the number 4 on the display after power outrage. And the temp is really warm inside. I unplug the power and plug it back 1 minute after. now I can set the temperature and it's working fine.
Mar 26, 2010 | Frigidaire GLHS36EESB Side by Side...
Fridge side of side by side Frigidaire not working
your damper door is frozen or iced up and not opening up to let cold air in from freezer compartment,defrost it and make sure its dry,also check your door seal to make sure its sealing good and not letting in warm air that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
Flashing #4 on temperature display
flashing #4 is a communication error between the control board and the damper assy, usually it is the fault ogf the damper assy but if it is under mfg warranty, replace both, if you need to pay for the parts yourself get the damper first.
Oct 24, 2009 | Frigidaire GLHS36EESB Side by Side...
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Sep 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
144 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
