Question about Dryers
What three wires or what and which is the power and ground
    Scholar:
    New Friend:
  • 65 Answers
According to your picture, the color code is as follows:
White is Neutral, Black is Live or Hot and Green with Yellow stripe is Ground.
Please ensure that you have disconnected the house power before making the connections as the voltages are dangerous.
Posted on Mar 31, 2015
  • Geoffrey White
    Geoffrey White Mar 31, 2015
    It is also a good idea to get a multimeter and use it to double check the white and black have no voltage on them
Plz briefly explain how to connect a 3 phase motor to star delta connection
A three phase motor will usually have three contacts and a ground. Hopefully the ground is distinguished somehow. The ground will have no resistance to the motor frame.
Delta is dangerous, it has a 'hot' leg, 220 volts to ground. The other two have 110 volts to ground (or 115 or 120). You can hook up any of the three power wires to any of the three motor wires. If the motor spins the wrong way, reverse any two, it doesn't matter which ones.
Aug 29, 2015 | Air Tools & Compressors
4-prong to 3-prong Power Cord Conversion.
On a 4-prong power cord you have 2 hot wires, one neutral wire, and one ground wire. On a three prong cord, you have 2 hot wires and one neutral/ground wire. The difference is the on four prong the neutral wire goes to electrical neutral bus in the breaker panel and the ground wire goes to the ground bus in the breaker panel. Since the neutral and ground buses, although separate, both go to physical ground, on a three-wire setup, you are just putting the neutral and ground wire together, Most dryers actually have a place at the pigtail connection to do just that.
Sep 09, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How to wire a three pronged flasher
You are correct, Power flash and ground.
Dec 08, 2009 | 1985 Chevrolet Nova
The plugin on my dryer has the terminals going in a slant. the outlet in my house are straight. what should i do
You can purchase a dryer main power cord that fits the type outlet you have. Some cords are three wire and some are four wire. Here is some information on changing from a three wire to a four wire configuration or vice versa.These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the right/bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helped and best wishes.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Plug problem
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 01, 2009 | Whirlpool LER4634J Electric Dryer
I have a new 4 prong plug to replace a old 3 prong on dryer
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
Repairing 3 wire drop cord
Sep 09, 2009 | Whirlpool LER5636P Electric Dryer
Convert three pin plug to four pin
Sep 06, 2009 | Frigidaire GLEQ2152ES Electric Dryer
I'm trying to replace the power cord on the Maytag Atlantis MDE7400AY. originally it has a three prong cord but i need to put on a four prong. in the back of the dryer it seems to only have three...
Sep 04, 2009 | Dryers
Are all three wires in the power cord suppose tobe
not generally there should be a hot, a neutral and a ground for 110VAC if 220 two hot and a ground, if you are reading voltage on your ground, the braker of fuse should have tripped or blown, and you have a component that is shorted.
Jul 15, 2009 | Dehumidifiers
Dryers Logo
53 people viewed this question
Top Dryers Experts
