Question about Colibri Watches
How does the colibri touch sensor work - Colibri Watches
What type of battery I need to buy for Colibri touch senzor lighter ( model 70-80s )? Thanks
they do not have a battery when they quit you throw them away and buy a new one
Apr 30, 2016 | Colibri Watches
I have a model 35002 triple torch Colibri gear lighter and I need instructions on how to refill it with butane.
There is a small nipple on the bottom of the lighter. That is where you put the canister on to refill.
Dec 12, 2015 | Colibri Watches
Battery required for colibri lasertron lighter
This lighter would normally use a CR1240E-T lithium 3 volt battery. If you still have an old flat battery, it can be charged if you know what you are doing. OK, so you don't have an old battery, so there are 2 types of battery that you can use to sort the problem. A lot of advice out there suggests using a CR1225, with a little packing to make up for the lack of thickness, this I have found barely works, as the capacity is so low to start with. And now for the real solution........ I use two silver oxide 391 batteries (11.6mm X 2.1mm @ 1.55volt each). With bits of paper to insulate the positive poles from shorting, and more paper to insulate the screw down cover from touching the top battery. The whole thing takes only a couple of mins, and you'll have months worth of bright red light and powerful sparks. Good luck John P. sylvie44@btinternet.com
Feb 21, 2011 | Colibri Watches
Colibri where to buy new watchband colibri cxw95612
jewelry-watches.pricegrabber.com
or
cgi.ebay.com
or others
Aug 05, 2009 | Watches
Colibri lighter
Usualy there are screw at the bottom.
If there are no screws at all. that means the lighter is assembled in 'click-on' way and you have to use your imaginary engineering skills.
Start with a part which looks attached to lighter the last.
Dec 20, 2008 | Watches
How do I change the date on a Colibri Pocket Watch?
Usually all quartz watches are supplied with calendar setting mechanism and it is very simple-
try to pull out crown and you will notice that there are two clicks,so, when the crown is pulled out to the first click, the date can be adjusted by the turn of the crown. When crown is pulled further out (second click)- the watch is in hand setting position and you can adjust time.
Did it help?
Dec 15, 2008 | Colibri PWS-95877-N Pocket Watch
Watches Logo
62 people viewed this question
Top Colibri Watches Experts
NOEL
NOEL
Are you a Colibri Watch Expert? Answer questions, earn points and help others
