Question about Proscan Televison & Video
I have a Proscan 49 inch tv. Screen just began going black in and out for a few seconds every couple of minutes. Any help would be appreciated. Thanks joe
    Top Expert:
  • Proscan Master
  • 75,157 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Mar 31, 2015
    Top Expert:
  • Proscan Master
  • 6,702 Answers
Could be a bad contact on the power supply, like a bad soldering, or just a little oxidation in one of the connectors. Oas a tech close to you for help.
SOURCE: 2 inch black vertical line near center of screen
If you have a black stripe probelm on your Gateway TV, check out pleasefixitdave@yahoo.com. I asked him for help last year (September '08) and his solution worked perfectly. Still no more stripes (I had 4 of them) and here it is June 23, 2009!!
Posted on Jun 24, 2009
  • 556 Answers
SOURCE: Sony kdfe60a20 - The TV turns on but after a
classic Sony telling you the lamp is going bad. Replace lamp yourself it is consumer replacable.
Posted on Aug 11, 2009
  • 1039 Answers
SOURCE: Screen on my Samsung LE32R87BD goes black for a
Contact Samsung . There is a software upgrade for this.
Posted on Sep 01, 2009
  • 8457 Answers
SOURCE: Black shadow boxes on 46 in Samsung 46 in LCD HDTV.
Ur backlight video board is dying,must replaced to solved this problem.Part and labors about $500.
Posted on Dec 15, 2009
SOURCE: vertical line on my 46" toshiba lcd tv
The only logical solution for the problems people are having for the toshiba regza's tv's is to get into a class action law suite..., they contiue to sell tv's with defective parts and refuse to help the customer that spent large cash to find out they last if your lucky 2.5 years, they are junk and anyone with one will soon find out./.......
Posted on Jan 25, 2011
Our Proscan 42 inch LED TV (only one month old) just started going fuzzy. There are green horizontal lines going across the entire screen. If I reset the TV (turn off and unplug) for a minute or so, then...
Possible fault in the convergence circuit, failure of the IC. I advice that you must not tamper on the TV but ask for the warranty replacement without even opening the set. You are entitled to this service and must not throw it off. So call up the dealership and register your complaint .
Sep 01, 2010 | Proscan Televison & Video
Hi, I turned on my 4 year old Sony 42" plasma today and the screen was black with speckles of colour flashing for a few seconds before fading out and the whole screen goes black. The sound was fine...
in sony 42 inch what is the exact model number of your TV?
also can you tell be how many times does the stand by light blink. that would help us to decode the problem in your TV
thank you
Aug 16, 2008 | Televison & Video
My Proscan 19LA20Q Keeps going to sleep mode after my sister touched something on the remote. The Blue screen and the source flashes on for a few seconds then the light goes orange and the screen goes...
ur sister possible turned the sleep mode on.......check on ur remote that is is off......if this problem persist u have to call service to fix ur problem
Nov 20, 2009 | Proscan 19LA20Q LCD TV
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
42 inch lg tv powers on,goes off after about 30 seconds
hello my friend you have some loose connections on the digital board.this board is located right in the top center of the tv.if you do not have repair skills call the repairman he should not charge you too much for this job. good luck
May 31, 2009 | LG 42LC2D 42 in. LCD HDTV
36 INCH 1997 - 1998 SONY TRINITON
Proceed with caution! High dangerous voltages exist within.
Check the current sense circuit from the aquadag coating.
Jul 15, 2017 | Televison & Video
Sony KV34HS420
Always go through the basics before you post questions.  All I did was reset the TV (unplug for a few minutes) and it is back to normal.  Lesson learned, TV fixed, thanks.
Feb 15, 2008 | Televison & Video
SCREEN GOES BLACK AFTER 1 MINUTE
In electronics dust has nothing to do. cleaning will not solve your problem your problem is due to trouble in vertical section. mostly it is due to electrolytic capacitor in vertical section is defective.it is common problem. also check supply to vertical section. "THE SCREEN SHRINKS TOWARDS THE TOP OF THE SCREEN FOR A FEW SECONDS BEFORE THE PICTURE TURNS UPSIDEDOWN THEN TURNS BLACK." is called fold over. regards thanks
Sep 12, 2007 | Sony KV-32S42 32" TV
Picture problems
Sounds like a problem in the main power regulator circuit, such as a bad capacitor or regulator IC or transisitor. There are no user serviceable parts inside these sets and every thing is soldered into place. I recomend that you call in a trained service tech to assist you with this repair.
Sep 25, 2006 | Proscan PS50670 50" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
