Question about John Deere Garden
I have a John Deere LA 115 hydrostatic transmission that's going on 8 years old. When I crank it there is a noise that almost sounds like something is loose under deck. When I press clutch, it stops. What do I need to do to get rid of the noise?
  • John Deere Master
  • 1,169 Answers
Check drive path for the idler pulleys. One is a flat and the other is V type. The bearing go dry on lube and require replacement,
See Circled items below.
I have a John Deere LA 115 hydrostatic transmissio - 25618943-2wczxmwxrocgkwnpwicxibzt-4-0.png
Posted on Mar 31, 2015
  • 1 more comment
  • Jeremy Ashley
    Jeremy Ashley Mar 31, 2015
    Is there a grease fitting where you are describing?
  • Eugene Rounds Mar 31, 2015
    No just sealed bearings. Although you can sometimes use a needle grease injector to lube them it don't always works as usually the balls and race ways are already damage and can sieze at anytime.
  • Jeremy Ashley
    Jeremy Ashley Apr 06, 2015
    This was it!!! Thanks Eugene.
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
mowerman1857
  • 389 Answers
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
Posted on Sep 18, 2009
John deere 425 transmission pushing fluid out of vent on top of transmission. PUmp making a whining noise
You have a fluid overheat condition here, so something is wrong inside the transmission that is causing this.
Feb 22, 2017 | John Deere Garden
My John Deere 2520 hydrostatic transmission is making a screeching noise when I push on forward or reverse pedal.
Maybe a pulley trying to lock up, drop the deck and spin your pulleys to see if theres one thats hard to turn or is loose
Apr 27, 2016 | John Deere Garden
John deere lx188
a lot of hydrostatic problems can be fixed by changing the oil and filter so try that first see if it helps
Mar 01, 2014 | John Deere Garden
Animal1018_2@yahoo.com
Check the drive belt.
Jan 15, 2014 | Garden
Have a 2 year old 115 with new blades, the blade heights do not match in the center of the mower deck. Is there an adjustment so theymatch
No, not unless somebody has changed the bearing unit out and it has a different depth to it. The washer on the top? Maybe. I have 2 john deeres out there and I know they are not adj, but I would check the spindles for washers or whatever somebody might have done to it. How far is it off?
Jun 28, 2011 | John Deere 195HP Hydrostatic 42" Cut...
La 115 with hydrostatic transmission will not move forward or backwards with engine running
if there is no problem with the drive belt getting power to the transmission, then the transmission is failing.
Aug 22, 2010 | John Deere Garden
Defective seat cover
Welcome to "Made in China"
All John Deere tractors are now made in China.
A new yellow seat vinyl with foam with the John Deere imprint is available at Princess Auto.ca for $9.99.
Check it online.
Nov 07, 2009 | Garden
John deere transmission what other mowers interchange
You will have to first know what kind of transmission you have. You will have to consider if it is manual or hydrostatic drive. The transmission model number should be stamped usually on the top of the transmission. Yes transmissions are interchangeable, for example some John Deere, Craftsmans and Husqvarna all use the same transmission. Peerless is a manufacturer of these, the only one I know of. So don't let anyone tell you that you can ONLY use a John Deere product. To determine what transmission you can cross over with, get the model and serial number off of your John Deere's transmission. Call a small engine repair shop and ask them what all transmissions it will cross over with. Let them know you are aware that Peerless manufactures the same transmissions for most all riding mowers and that they will interchange. If they are uncoperative, contact me with the model and serial numbers off of your transmission and I will cross reference it for you. But try to get model and serial numbers for other brands from them, then check these against used ones. You will need to tell them if it is a hydrostatic transmission or manual and if so what speed manual.
Jul 11, 2009 | Athearn N Rtr John Deere Tractor Model B ...
John Deere LT190 Lawn Tractor transmission problem
is it hydrostatic drive? if so you probably need to change filter and fluid
Oct 01, 2008 | Garden
Garden Logo
126 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
