Question about Garden
The throttle keeps reving up and down wont stop moving back and forth
Tried to tighten spring no luck thanks Robin
  • Eugene Rounds Mar 31, 2015
    Find you governor cross shaft connect coming from the throttle butterfly. Watch area as you move the throttle to full. Now loosen the retaining screw and turn the cross shaft in the same direction that move as you went to full throttle until shaft stops turning and tighten the retainin screw. Since engine is already running it probably won't turn a lot but the play does need to removed. The service for your particular would better instructions than this but this how it is basically done.
  • RobinRossiter
    RobinRossiter Mar 31, 2015
    thank you i no what u mean will give that a go cheers Robin
  • 1,169 Answers
Engine probably needs a static governor adjustment and possibly a carburetor cleaning. If you can hold the throttle butterfly steady by hand and the engine smooths out then it is the static adjustment that out adjustment.
Changing the spring length will cause the problem to get worse by making the governor more sensitive if shorten too much.
Posted on Mar 31, 2015
Testimonial: "thank you ,how do I do that. cheers Robin"
    Champion:
  • 225 Answers
Chances are itt needs a carb clean or ideally a ultrasonic clean
Posted on Apr 02, 2015
  • Neil Hancock Apr 02, 2015
    chances are it needs a carb clean or ideally a ultrasonic clean
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
The first thing I'd suggest would to be to check and clean the air filter. It could be starving for air causing the butterfly to partially close which causes the governor linkage to 'throttle up' then the restricted entering air causes it to pull down.
Also if you have last years gas in it, dump it out and fill it with fresh summer blend gas and try again after cleaning the filter.
Posted on Apr 01, 2015
Got a cub cadet zero turn rzt50 the throttle cable moves back and forth but will not idle down
Check if the small clamp that holds the cable to the engine is tight. The entire cable may be moving with the throttle rather than just the wire inside the cable.
Oct 02, 2017 | Cub Cadet Garden
Toro 6.5 model 20016 throttle stuck open
I believe that is the governor spring you are referring to. YES it needs to be replaced, before you sustain permanent engine damage.
May 21, 2013 | Garden
Craftsman Riding Mower (24 HP 42 in cut Model 289254) with throttle issue. Very slow in 6th gear
follow the throttle cable all the way down to the engine. Have some one move the throttle up and down to see if the throttle plate is opening and closing all the way. You can loosen the screw holding the throttle cable and move it back and forth to see if it will allow the throttle plate to open and close correctly. It may have slipped when the assembler tried to tighten it.
Mar 10, 2012 | Craftsman Garden
Tri z I havnt started my tri z since sept and I started and put in gear and in jumped and stalled. I started againg with clutch handle pullled in and started and it jumped and i didnt let it stall drove...
I had a Tri Z, and every time it sat the clutch stuck. I'm not exactly sure why your clutch won't disengage when you tighten the springs-I do know that the springs MUST be tightened to where the bolts bottom out for it to work. I do also suspect that running it with the springs loose has burned what was left of the clutch. The basket and inner hub grooved could be an issue. It would depend on how bad it's notched. They will normally operate fine with some notching. Filing down the basket is not recommended-you would have to take the exact same amount of material off each finger of the basket for it to work properly. I've done this only to get it running while waiting for a new basket and drive hub to arrive.
The main thing now is to get the clutch to disengage w/ the lever. Take the pressure plate off, and watch for the lifter to mave about 1/8" when you pull the lever. If it's not moving, or is too high, remove the lifter, the round ball behind it and the engaging rod out of the hollow clutch shaft. A small magnet tool works well.It may have gotten past the cam on the cable end of the system. With the rod out, turn the cable actuating lever back to the end of it's slack and reinstall the rod,ball and lifter. You should be able to turn the cable actuating rod with your fingers and watch the lifter come up. You can feel when the rod is in the right position on the cable arm-it should bottom out and lift within the working rotation of the lever. So if you get that working, put what's left of the clutch back together, tighten the springs and make sure it works.You will at the very least need to replace the friction plates in the clutch. The steels should be checked for warpage on a flat surface. If you can get .002 feeler gauge under the warp it's too far gone and they should be replaced as well. Most Yamaha clutches have a first and last friction plate that's a different part number when you order them, be sure to check that when replacing the plates.I'd get new springs as well, they're cheap. Good luck!
Jun 27, 2011 | Yamaha YZ 250 Motorcycles
1977 Suzuki TS185 throttle sticks
Could be 2 things to look at first.1 the idle adjusting screw has been screwed in to far and is holding the throttle slide open.The other is an air leak between the carby and the motor resulting in the air/fuel mixture being to lean.This would cause the revs of the engine to be to high.Check these 2 things.Hope this helps
Aug 15, 2009 | Suzuki TS 185 Motorcycles
The kohler engine on my poulan pro 42 inch 17 hp is reving way too high the throttle cable does not apear to be stuck
YOUR THROOTLE LINKAGE IS BINDIND WITH THE ENGINE OFF MOVE THROTTLE BACK AND FORTH WATCHING THE LINKAGE ON THE CARB, SPRAY LINKAGE WITH PENETRATING OIL SO IT LOOSENS UP
Jun 26, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Engine throttling up and down continually
This is the classic symptom of improper air/fuel ratio.
There should be an adjusting screw on the side of the carburetor -- it has a spring at the base -- turn this with a screwdriver slowly back and forth to see which direction makes it run better -- take it from there...
May 09, 2009 | Garden
My homelite wont idle
When you pull the trigger on your saw lhile looking near the carb you will see the throttle plate moving back and forth as you pull it. The end of it usually rests against a screw with a spring. Screw the screw in some so the throttle doesn't come back so far.
Mar 01, 2009 | Garden
Powermate 6250 loaps.
I've never been a big fan of the 180 OH family of engines in these things, but here goes.
1 - If the engine will stay running while it surges, close the choke a little at a time and see if it settles down. If it does, there is something amiss in the carb. The carbs on these engines are very picky about tiny bits of dirt. The good news is that they are fairly simple to take apart and clean, the bad news is that lots of the parts are plastic and break easily. At least they aren't too expensive.
2 - I've seen 2 ways to adjust the governed speed on these engines; a spring that connects to the governor arm at one end and a tab bent up from the sheet metal that mounts on top of the engine at the other - bend the tab so the spring is tighter to speed the engine up, and (b) a jam nut and screw mechanism that presses against a lever that pulls on a spring that connects to the governor arm - screw the screw in tighter to raise the engine speed.
Note that in either case the mechanism adjusts the tension in a spring that pulls against the governor arm, this is helpful in finding out where to make the adjustment.
Here in the US we want our 2 pole generators like this to run at 3750 rpm at no load so that we get very close to 3600 rpm at load. If you're using a DMM to measure the output of the generator in Hz, you want 61.5 at no load.
If nothing you can do with the choke makes the surge go away, you might have a misadjusted governor. The Tecumseh service manual has a great procedure for making this adjustment, essentially what you do is loosen the retaining nut on the governor arm, twist the governor shaft to its minimum speed position, then hold the throttle assembly at the idle stop and tighten the governor arm jam nut. Always keep a finger near the kill switch when running the engine the first time after this procedure, it's easy to mess up and have a runaway engine.
Please rank me if this was helpful,
Carl
Nov 12, 2008 | Coleman Powermate Premium Plus 6250W...
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
