Question about Real Simple White Kitchen Island
Leaf is defective. how do I replace - Real Simple White Kitchen Island
Poulan pro leaf blower spark plug keep getting wet
check for a plugged exhaust... then suspect a defective carb
Aug 04, 2014 | Garden
Blower does not turn on
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Apr 03, 2014 | Toro Garden
Brushes on the motor are bad. where can I buy them
Sounds like the brushes are worn out and in need of replacement, if available.
Nov 04, 2011 | RTO Weed Eater Electric Barracuda 2595...
How do I get a new solid state ignition. My crruent leaf blower is not getting any spark
Hi, most lawn mower repair shops either will have those in stock or can order them for you. Its a common item, or you can go to www.mtd.com and order it online. Before repalcing the coil, remove the kill switch wire from the coil, then check for spark again. you could have a defective kill switch.
Sep 24, 2010 | Yard Man Mulchinator QuickShift BlowerVac...
Starts but turns off when choke is turned off . Seems gas air mix is off but no adjustments are possible
sounds like your "sucking air", get it running with choke on and slowly spray carb cleaner around carb at mating surfaces, i.e anywhere theres a gasket, if it bogs or stalls replace defective gasket/s
Nov 14, 2009 | Husqvarna Garden
My Ryobi RBL30MVA. leaf blower will not start, when pulling stater chord it feel as if it is not engaged with engine ie engine does not turn over
I have had this exact same problem with the same model after just one hours use.
Returned it a week later and after 2 months the replacement did the same thing.
Returned that one and got a third. A week later that ones doing the same thing again after only an hour or so use.
Obviously some defect in them.
I'll be getting my money back and visiting the local mower center to get their help rather than doing the guess work my self and ending up with a dodgy model
Nov 07, 2009 | Ryobi Garden
Flowtron Leaf-Eater Mulcher LE-900F
Shot in the dark here. If the mulcher is tripping and needs to turned off then back on, it's defective and should be replaced. If the circuit breaker in your house panel is tripping, try to use different circuit on a 20 amp circuit breaker. If your using a plug that is controlled by a GFCI receptacle or breaker, move to a different plug. GFCI receptacles tend trip when motor loads are applied. These are my best guesses since I'm not sure what exactly you are reseting.
Apr 25, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
Circuit breaker
I was able to get a replacement 5 amp MB-1 push to reset circuit breaker for my Flowtron LE-900 directly from Snap Action http://snapaction.net/ for no replacement cost and no shipping/handling cost. No one at Snap Action enquired as to what it was for, age, warranty, etc. (their MB1 product description indicates it to have a lifetime guarantee). I just had to mail them the defective original breaker - took about 2 weeks to receive the replacement.
Brett
Oct 16, 2008 | Flowtron LE-900 Leaf-Eater Mulcher
Real Simple White Kitchen Island Logo
566 people viewed this question
Top Real Simple Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Real Simple Furniture Expert? Answer questions, earn points and help others
