My volume /power button turns all the way around instead of just clicking on and off and controlling volume. It won't flip the inside switch or whatever it does inside to turn it on.
    Top Expert:
  • 10,875 Answers
Push on the button to turn off
Posted on Apr 07, 2015
    Top Expert:
  • Audio Player... Master
  • 12,962 Answers
The switch has to be replaced, pure and simple since the on /off part of it is bogus. If you want, you can bypass the on off switch part with a toggle switch and continue to use the pot since it is probably still good to adjust volume.
How activate bluetooth
Plug a Bluetooth adapter into a USB port on your computer.
If a Bluetooth adapter is already built in to your computer, ignore this step.
Flip the switch or push the power button on the Bluetooth device to turn it on and make it discoverable.
Click the "Start" button on your computer and select "Control Panel."
Click "hardware and Sound" and choose "Bluetooth Devices."
Click "Add." Follow the onscreen instructions, which vary depending on the kind of device you are installing.
The instructions mostly consist of clicking "Next" or verifying that you want to install the device.
You now have activated a Bluetooth device on a Dell laptop.
hope this helps
Aug 30, 2012 | Dell Computers & Internet
How do I turn up the volume control IPhone 3GS?
when you hold the Iphone in your hand with the round button with the square inside it on the bottom of the phone. turn the right side of the phone down to the floor while you do this look for 3 buttons on the side of the phone the TOP button must be pushed upwards at all times this flip switch is your MUTE switch pushed down it is in must mode switched up is sound mode.
Below this is 2 buttons the button just under the top flip switch is volume up the other one is volume down there ya go.
Please rate my solution and leave testimonial this is how i earn my achievements thanks in advance.
Apr 22, 2012 | Apple Cell Phones
My logitech speaker system is no longer powering on. I am not sure of the exact model name, but it is a 5.1 surround sound system with a little control center that has a volume knob and a little lcd screen...
sound drivers might not be installed
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if you dont have a cd with sound drivers you will have to download them
if you need more haelp with this post a reply
hope this helps
Aug 17, 2011 | Logitech Audio Players & Recorders
The buttons on top of mt tv go crazy the flip channels automatically and turn volume up and down automatically
I have had this problem on this same model (F32650) and I discovered that what is happening is that dust and debris are causing the microswitches in the panel to short, therefore the channel starts changing and wont stop or the volume changes etc...
Get some electronic switch cleaner and (with the power off of course!) spray into the crevaces around each button and press each button a few times and then power the unit back on and it should be fine.
May 08, 2009 | RCA F32650 32" TV
Tivoli Model one radio - volume control does not go to quiet. I like to listen at night but volume does not lessen past a certain point which is too loud.
I noticed the same problem after I had moved. Hadn't had it before. The solution was easy in my case. (It took some time to accidentally figure it out though). I flipped the power cable around 180 degrees / upside down and re-connected. After this the volume worked as before. This was the model with European power plug.
Mar 01, 2009 | Tivoli Kloss Model One AM/FM Radio
Why won`t my mp3 take itself off hold?
Power & Hold switch
Slide and hold in the opposite direction
of the arrow for power on/off.
Slide in the direction of the arrow to
lock the button functions.
If that fails,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 15, 2008 | Samsung YP-T10 Digital Media Player
Remote Volume Control Not Working
MEtten,
Flip the top cover, just above the "AV MENU" there is a round boll kind of switch, it has to be pressed when you want to function top cover button, so may be it is warn out or the nob has been broken. if you press that switch with pen nob it will function...
It is bad design...
Surendra
Jan 05, 2008 | Sony STR-DA3ES Receiver
Wont come on
try pressing one of the number keys instead of the power button on the remote
Sep 06, 2007 | Beko 324250WN 28" TV
168 people viewed this question
 Grubhead
Grubhead
