My tip numbers are: 7, 24, 63. Which one do i use?
  • Brad Brown Mar 31, 2015
    Hi Tom Boutros, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Computers & ... Master
  • 2,045 Answers
77 or even 99
Posted on Mar 31, 2015
What is the wahl01 part called and were can I get one
That is called the blade drive arm or driving lever. If yours has a red tip on it then the tips are available separate from the arm or you can buy an arm that has no removable tip. The arms without the red tip are a bit stronger. Part number for the non tipped arm is 1245-7040. Part number for the arm that takes tips is 1247-7990. If you just want to change the tips a bag of 10x is part number 1291-7050. From the look of the cord plug in the photo you are in the UK, if that is the case www.peasridge.co.uk can help you
Mar 26, 2014 | Wahl Switchblade Animal Clipper Kit:...
My new Hp Officejet j3680 caller ID is not working... All the phones in the house display the incoming phone numbers except the j3680. I wonder why?!! it shows instead ringing!!!
The caller ID phone having the tip & ring detection circuit to detect the incoming phone number, but in this model doesn't have tip & ring detection circuit to display other phone number but after connecting the other fax it will read the information which was stored like company name & phone number of other one..
Jan 04, 2012 | HP J3680 Officejet All In One Printer
Frances left a 12% tip on a meal. Including the tip,it's cost was $47.04. wHAT WAS THE COST BEFORE THE TIP?
The cost before tip is X. the cost after tip is X+12%(X) which is equal to X+0.12X=1.12X (you convert percent to decimal number, 12%=0.12). Now you can write 1.12X=47.04 so X is 47.04/1.12=42$.
Aug 21, 2011 | MathRescue Word Problems Of Algebra Lite
Having trouble getting a good spray pattern when I use thick latex
You have two choices to fix this problem: First thin the paint and/or add a conditioner like Floetrol to make the paint flow properly. Second, use a tip with a bigger opening. On sprayer tips there is a three digit number (.ABC). The first number (A) is one half the spray pattern size when held 12 inches from the wall. A two will give you a four inch pattern, five will give you a ten inch pattern, etc. The last two numbers (BC) are the oriface size. For latex you should be using at least a .017 or .019 tip but if the paint has to be very thick you may need a .021 or larger.
Jan 05, 2011 | Campbell Hausfeld Airless Spray Guns &...
Need dryer blueprint for kenmore dryer model number 417.83042300 serial number xd40802217
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
This tip also will tell you how to get that...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 07, 2010 | Dryers
I have a Weller 1002B soldering station. Haven't
Hi, I'm not sure the tip is defective. Check that the tip is screwed in tight. If it is not good and tight the tip will not get a good heat transfer from the solder wand. Hope this helps. If the wand will heat then the tip should.
Jul 11, 2010 | Weller Welding Tools
WHERE DO I FIND THE MODEL NUMBER ON MEDION TV
Tips for identifying Manufacturer:
When adding devices to your Harmony account, it is important to correctly identify your components so that your Harmony Remote can control them as efficiently as possible. Below are some tips to help with figuring out how to add your devices correctly:
Tips for identifying the Device Type for your devices:
A general category description:
Examples: Television, VCR, CD Player, DVD Player, Stereo Receiver, Amplifier, Game Console, etc.
1. Also referred to as “make” or “brand name”
2. Typically on the front of the component
3. Sometimes on the label with the Model Number
examples: Sony®, Phillips®, Denon®, DirecTV®, TiVo®, etc.
Tips for identifying Model Number:
Note: also “Model” or “M/N”
1. usually on a label on the front, back or bottom of the component
2. the model number may be different than model name
3. also found in the component’s user manual
4. Not the model number on the old remote control
5. Not the serial number (SN) which is usually much longer
examples: RC-QN3BK, CT-36XF36C, Explorer 3100, L32 HDTV 10A, etc.
Jan 25, 2010 | Televison & Video
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
