Question about Home Security
Cannot remember pin number.Cannot open safe.
Need instructions to get a new pin number so I can open safe.
    Top Expert:
  • 6,702 Answers
If there was such a thing, anyone could open the safe and it would make that system worthless. Try writing down all combinations you can think of, because you could have used them. Then one by one try them.
Posted on Mar 31, 2015
Testimonial: "Done that already, Harrie"
Helix safe instructions need help setting up safe
Depending on the model, you may be able to find the instructions online. If you remember the store you bought it at, you can also ask them. If they can't help, they may be able to get the manufacture number for you.
Elisa Jed ' http://www.suburbanlock.com/safes/
Mar 16, 2014 | Home Security
I gave my mom a Safewell Home Safe for her birthday. She forgot the code but still has the keys. She placed her passport inside with no other valuable but we are travelling soon. Can someone help or point...
Hello -
I hope I am safe in assuming your mother (or you) tried opening the safe with the key and that did on work.
If so, this YouTube video may prove instructive regarding opening a digital safe:
https://www.youtube.com/watch?v=hcYB9ceiAiY
This YouTube video shows another method:
https://www.youtube.com/watch?v=fjrTTlxWTIY
Note: Assuming the safe can be opened following one of the techniques in the video, a new battery / batteries should be installed before resetting the code. (Also, I understand the batteries should be replaced regularly to avoid the battery / batteries becoming depleted and causing problems in opening the safe.I suggest replacing the battery / batteries once a year - note the date on a calendar you will look at regularly.) Plus, you and your mother should write the new code down and put the information in places where you will remember them. I like to put codes in my address book (a physical address book for people's names, street addresses, and phone numbers - very old school.) For a safe code, I have used the maker name of the safe as the "last name" and my first initial as the "first name". Example: Safewell, J. I have also made the code look like a telephone number. For example if it is a 6-digit code for the safe, I have made the code the first 6 digits, followed by zeros. Example: code is 987654, phone number in my address book: 987-654-0000 (USA phone number style.)
Best wishes.
Jan 23, 2018 | Home Security
How do you reset the Pin on the Hot Focus Pink Digital Safe
Hot Focus Pink Digital Safe pin reset instructions:
1) Hold down the star button (do not let it up until the process is completed). 2) Press a four number code sequence. 3) Press the pound key. 4) Release the star key.
Nov 25, 2012 | Toys
How do you set your own combination for the locks on the briefcase,there were no instructions with the case
  • 1 Turn the lock to the correct combination and open the briefcase.
  • 2 Look at the lock. There should be one or two pins that you can slide with your fingers. If there is one, simply push it in. If there are two, push them together. It may be the same button you use to open the case.
  • 3 Change the lock to an easy-to-remember value, such as 000 or 123, to test the lock. Release the pin.
  • 4 Close the briefcase and turn the lock to another value. It should not open. Now turn it to the test combination. It should open right up.
  • 5 Repeat Steps 2 and 3, but this time choose a number that will be easy for you to remember, but hard for someone else to guess. Write down your new combination and keep it somewhere safe.
  • Dec 29, 2010 | Office Equipment & Supplies
    I forgot my safes password
    call a local locksmith he can help, if it can not be opened you may have to bust it open, call some one with many tools they may help. I recommend an angle grinder this will cut through steel. If you can remember where the pins are that hold the door closed you can grind through the side and cut the pins with two cuts. would take ten minutes to open with this method. There is probably an upper and lower pin.
    Apr 01, 2010 | Safe International Digital Electronic Safe...
    Lost pin number.
    When you first setup the GPS, you can setup a safe location, go back to your safe location, there will be not lock on it then.
    Regards
    May 24, 2009 | Garmin StreetPilot c530 GPS Receiver
    Brinks fire resistant safe model 5059 instruction manual
    Here is the turning sequence:
    General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
    Combinations consist of FOUR (4) positions (numbers).
    BEFORE YOU START
    Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
    three times. We also recommend to try the procedure with your safe door open first. Then
    follow these steps:
    TURNING SEQUENCE
    1. Start the dial on 0 (zero).
    2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
    times and stopping at that number on the fifth time around.
    3. Turn the dial to the LEFT, passing your second combination number TWO (2)
    times and stopping at that number the third time around.
    4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
    and stopping at that number the second time around.
    5. Turn the dial to the LEFT, to the last combination number and STOP.
    6. Insert the key in the cylinder lock and turn RIGHT to open.
    Your safe should now be opened.
    Apr 30, 2009 | Computers & Internet
    Electronic digital safe richmond
    after six years of good service the batters ran out when we were not at home sadly after all this time I cant find the security key to open my safe the number of it is ho 155 how can I get a new key
    Apr 07, 2009 | Safe International Digital Electronic Safe...
    Blue Hat Bank
    Type in the code 1234 ENTER then enter your child's new pin.
    Pax, Moncia
    Jan 04, 2009 | Blue Microphones Blue Hat Little Shots...
    New Lexsor safe LXo24 Model
    Hi there, I had the same problem yesterday but luckily remembered the code and got the safe open. The factory pin is 159B.
    Regards Norma
    May 27, 2008 | Ventamatic Gable Mount Power Attic...
    Home Security Logo
    104 people viewed this question
    Top Home Security Experts
    Lawrence Oravetz
    Are you a Home Security Expert? Answer questions, earn points and help others
