Question about Gaggenau Ovens
I have error code E036 on the LCD panel and cannot get oven to work
Power off, on does not work
    Top Expert:
  • Gaggenau Master
  • 10,875 Answers
Try shutting breaker off for a bit,heres your manual,it says to call them with this code page 36, Gaggenau BO 250 Instruction Manual Trouble Shooting Error Messages...
Posted on Mar 31, 2015
2 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: Kitchen Aid Wall Oven KEMS308SSS - Display Panel
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic
mode and verify the error codes. Ensure AM software, UI software and EEPROM
CHECKSUM versions appear on the lower text line. If AM software and EEPROM
versions do not appear, UI and AM may not be communicating. Verify this for the
lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show
the AM software version for the lower oven appliance manager, and the microwave
UI will show the AM software and EEPROM versions for the microwave appliance
manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT
DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions,
go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND
EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER
OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 22, 2010
What is an F 19 error code
I have a newly installed single wall over that came up with an F19 error code. The oven electronics worked fine but the oven wouldn't heat up. I moved the breaker up one slot in my federal pioneer panel to straddle the black bar (2phase) and now the oven works fine. If the breaker is in the improper position the oven will only be getting single phase power and you will get an F19 error code. I don't think this is the only time you will get this code but this may help some with new installs.
Apr 05, 2014 | LG LWD3081ST Electric Double Oven
Error codeE6 F2
Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours.
If the error code came back on, replace the control board.
If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly).
- The part number for the new control board AP3595759
- The part number for the black/stainless control panel AP3131755
Good luck.
Gene. __________________Hi I did some research for your oven and this is what i found , someone with the same problem , control board needs to be replaced , if you click on the web page below it will explain it to you , good luck Frank
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html#ixzz1gYuqvZnV
Dec 14, 2011 | Whirlpool RBD275PR Electric Double Oven
Error 08 on my hotpoint ovan workes for a bit then goes off and sayes error 0 8
HELLO.
The code displayed on the oven indicate that the oven has detected an error from the source of power control (panel).
This problem can be as a result of over flow of water or liquid substance on control unit,
or when there is over flow of power supply on the oven.
when the door of the oven is not properly close etc these can be as a result of the error code displayed on the screen of the oven.
WHAT YOU NEED TO DO TO SOLVE THE PROBLEM OF THE CODE DISPLAYED ON THE OVEN,
is to off and unplugged the oven from power supply for something then plug it and allow it to load on power on it's own before any form of operating then push the reset button if any.
With this the problem of the code will be solve
If there is a need for further help get back to me with your comment.
THANKS.
Sep 18, 2011 | Ovens
On the screen there is a error code and nothing works
What is the error code? most error codes are the resault of a failed componenet, but on occasion disconnecting the power will rest the washers electronic control panel.
Jan 23, 2011 | KitchenAid Architect II KEBS207SSS...
Warning codes f2 & e3 on Whirlpool oven . Warning beeps alerted us to a problem.
good luck
Feb 27, 2010 | Whirlpool Ovens
After a power outage oven will no longer work
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
Oct 27, 2008 | KitchenAid Architect Series KEBC107KSS...
Control panel beeping & oven not working
what brand oven, what is the model number, what is the error code seen. Try pressing the cancel button for about 10-15 second. Have you tried disconnecting power to the oven - do so about a minute
Regards
Sep 26, 2008 | Ovens
Gaggenau Ed 220/221 Error Code F 70
I had the same fault F70. Poured several liters boiling water no result. I decided to take the oven out the kitchen and put on the table. Be carefull, its edges are sharp. You need to disconnect water supply, first close the tap, then remove the water pipe from the oven by hand. Remove also the drain pipe from the sewage connection. You cannot detach it from the oven. Unplug power supply. Then start unscrewing the top panel. Once removed you can unscrew also the side panel left side (by looking at the oven from the front door side) and finally remove the back panel. You will need a special screw driver as the screws are star type.
I found out that there was some little water on the bottom panel of the oven. There is a safety sensor which is in contact with the bottom panel on the left side of the oven near the electronic board.
If this get wet, the faul code F70 appears.
Also some water was in the hole of the level sensor in the pump chamber next to the other sensor (white plastic box)
So dry all the water with the help of kitchen paper and finally with hair dryer.
Put back all teh parts and voila', it works again.
Feb 20, 2008 | Gaggenau ED 220/221 Electric Single Oven
Ovens Logo
196 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
