Question about Maytag MHW5100DW MHW5100DW 27" Wide Front Load Washing Machine with Large 4.5 cu. Ft. Capacity PowerWash Cycle Internal Heater Stainless Steel Wash Basket and Direct Drive Motor in White
Locked door light is flashing motor humming...I tried unplugging... how do I reset the computer
  • Maytag Master
  • 5,323 Answers
Usually unplugging a few minutes will reset it
Posted on May 21, 2015
2 Suggested Answers
gary1121
  • 332 Answers
SOURCE: door won't unlock
try the cancel button it will drain the water and release the lock
Posted on May 30, 2009
Chamberlain whisper drive residential door opener model LW3500 stops after perhaps 2 seconds, lights flash and door will not open or close
Page 36 owners manual.
35
Operation
Diagnostic Chart
Your garage door opener is programmed with
self-diagnostic capabilities. The "Learn"
button/diagnostic LED will flash a number of times
then pause signifying it has found a potential issue.
Consult Diagnostic Chart below.
Installed
Safety Reversing
Sensor
"Learn"
Button
Safety Reversing
Sensor
Bell Wire
Diagnostics Located
on Motor Unit
LED or
Diagnostic
LED
1 Flash
Safetyreversing
sensorswire open
(broken or
disconnected).
OR
2 Flashes
Safetyreversing
sensorswire shorted
or black/white wire
reversed.
Symptom:
One orbothof the Indicatorlights onthe safety
reversingsensors donot glow steady.
l
Inspectsensor wiresfor a short(staple in wire),correctwiring
polarity(black/white wiresreversed),broken or disconnected
wires,replace/attach asneeded.
l
Disconnectall wiresfrombackofmotor unit.
l
Remove sensorsfrombracketsand shorten sensor wiresto
1-2 ft.(30-60 cm) frombackeach ofsensor.
l
Reattach sending eye to motor unitusing shortened wires.If
sending eye indicator lightglowssteadily,attach the receiving
eye.
l
Align sensors,ifthe indicator lightsglowreplace the wiresfor
the sensors.Ifthe sensor indicator lightsdo notlight,replace
the safetyreversing sensors.
3 Flashes
Door control or wire
shorted.
Symptom:
LEDis not lit ondoorcontrol.
l
Inspectdoor control/wiresfor a short(staple in wire),replace
asneeded.
l
Disconnectwiresatdoor control,touch wirestogether.If
motor unitactivates,replace door control.
l
Ifmotor unitdoesnotactivate,disconnectdoor control wires
frommotor unit.Momentarilyshortacrossred and white
terminalswith jumper wire.Ifmotor unitactivates,replace
door control wires.
4 Flashes
Safetyreversing
sensorsslightly
misaligned (dimor
flashing LED).
Symptom:
Sendingindicatorlight glows steadily,receiving
indicatorlight is dim orflashing.
l
Realign receiving eye sensor,clean lensand secure
brackets.
l
Verifydoor trackisfirmlysecured to wall and doesnotmove.
5 Flashes
Motor overheated or
possible RPMsensor
failure.Unplug to
reset.
Symptom:
Motorhas overheated; the motorunit does not
operate ortrolley is stuck onstopbolt =Motorunit hums briefly;
RPMSensor=Short travel6-8"(15-20 cm).
l
Unplug unitto reset.Tryto operate motor unit,check
diagnosticcode.
l
Ifitisstill flashing 5 timesand motor unitmoves6-8"(15-20
cm),replace RPMsensor.
l
Ifmotor unitdoesn'toperate,motor unitisoverheated.Wait
30 minutesand retry.Ifmotor unitstill will notoperate replace
logicboard.
6 Flashes
Motor CircuitFailure.
Replace Receiver
LogicBoard.
Symptom:
Motorunit doesn't operate.
l
Replace logicboard because motor rarelyfails. https://www.chamberlain.com/CatalogResourcesV3/en-us/shared/files/tucmanuals/114A4252.pdf
Jun 30, 2017 | Building Materials
Making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
Jul 05, 2010 | GE Energy Star WCVH6260F Front Load Washer
Garage Door opened but will not close. I opened
I think the trolley has jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. With the door closed locate the 'up limit' control on the side of the motor unit. Turn this 2 turns in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Timer light keeps flashing
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up, the drain pump is humming, causeit cant pump any water
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Door Locked after FA code
Press "end of cycle" button and wait for a click or 3 minutes, they try the door. Do not force door
Dec 28, 2007 | Whirlpool GHW9300 Duet Washer
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Maytag MHW5100DW MHW5100DW 27" Wide Front Load Washing Machine with Large 4.5 cu. Ft. Capacity PowerWash Cycle Internal Heater Stainless Steel Wash Basket and Direct Drive Motor in White Logo
167 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
