The screen flashes, is it a setting problem. - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,211 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Mar 31, 2015
How do i set the Barbie Glamtastic alarm clock radio
Barbie Glamtastic Alarm Clock Radio 11765268
There are four (4) buttons on the back:
  • Mode
  • Set
  • Scan
  • Reset
Everything regarding setting dates and times is done starting with the Mode button, and using the Set button to adjust various settings.
Set Year
  1. Press Mode until the date appears.
  2. Press Set. The year will begin to flash.
  3. Press Mode until the correct year is reached.
  4. Press Set.
Set Date
  1. Press Mode until a date appears in the form of MM-DD.
  2. Press Set. The year may flash first. Press Set again. The month (MM format) will begin to flash.
  3. Press Mode until the correct month is reached.
  4. Press Set. The day (DD format) will begin to flash.
  5. Press Mode until the correct day is reached.
  6. Press Set.
Set Time
  1. Press Mode until the time displays.
  2. Press Set. The hour will begin to flash.
  3. Press Mode until the correct hour is reached. Keep in mind the AM/PM indicator in the far left of the screen. Make sure that the hour to be selected is with the correct AM/PM indicator.
  4. Press Set. The minutes will begin to flash.
  5. Press Mode until the correct minute is reached.
  6. Press Set button.
Set Alarm
  1. Press Mode until the the Alarm screen displays. The Alarm screen has an AL in the far right of the screen.
  2. Follow steps 2-6 above under Set Time (these same steps are just being done on the Alarm screen).
Turning Alarm On and Off
The left side of the radio has an On/Off dial (for the radio) at the top, and a slide selector button (for turning the alarm on and off) at the bottom.
  • Sliding the selector to the far left will result in Barbie's voice as the alarm.
  • Sliding the selector to the far right will result in a piercing noise as the alarm.
  • Sliding the selector to the middle slot will result in the muting of the alarm.
There are graphics on the left side of the clock that denote each result above.
Mar 28, 2014 | Barbie Glamtastic Alarm Clock Radio...
Why is my screen flashing
go to setting and developer option and disable alll scren option there you will see update screen and gpu rendering and screen flash etc
or reset your setting to factory reset but before doing so backup your data with external memory card
Feb 01, 2014 | Dual 3g, Next Android 4.0 Sim Core Cpu 4...
Digital Camera HP Photosmart M517 Want to take a picture of my computer screen to send by email. Flash goes off every time and leaves a bright white light that obscures the screen. Can I disable the flash...
Press the flash button (just under the viewfinder) to cycle through the flash settings. Your choices are Auto Flash, Auto Flash with Red-eye Reduction, Flash On, Flash Off, and Night.
If you want to capture the screen image, you're better off using the computer operating system's screen-capture capability. This will give you the screen exactly as it is, without the distortions inherent in converting to an analog image and then converting it back to a digital image.
Mar 15, 2010 | HP Photosmart M517 Digital Camera
I changed the batteries and continued to take photos when i noticed that the screen was flashing on and off and then going to standby mode. tried resetting back to default but screen still flashes. flash...
Hi Bill,
You are not using this flash like a sub-machine gun, right?
Is your reachargeable batteries older than 15 months?
Try this:
Set to low power on flash, set flash to manual.
Remove flash from hotshoe.
Fire the flash by pushing the flash button for 3 mins, same problem(s)?
atdlee@netzero.com
Jan 17, 2010 | Nikon Speedlight SB-600 TTL Flash
How do I get the flash to work. I have hit what looks like the flash button directly above the Ok button with no success yet in getting a flash to occur when taking a picture. Thanks for your help.
Check to see if your camera is on the macro function. The button is on the left side of the camera (as you are looking at the screen) and it is a slide button. If the camera is on macro, there will be a flower displayed on the screen. This is for close-up photos and will not allow the flash to be set. Slide the button up and a mountain should show on the tool bar of the screen, this is the far away setting. You should be able to set the flash settings now. Good luck.
Dec 25, 2009 | Vivitar ViviCam 5022 Digital Camera
Sony cyber-shot dsc-w50 problem
When “FLASH error” (Self-diagnosis Code E : 91 : ** ) occurs, to prevent any abnormal situation caused by high voltage, setting of the
flash is changed automatically to disabling charge and flash setting.
After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the Setup screen.
Method for Initializing the Flash Error Code
Initializes the setting to the default setting.
1 Select [OK] with v on the control button, then press z.
The message “Initialize all settings Ready?” appears.
2 Select [OK] with v, then press z.
The settings are reset to the default setting.
• Make sure that the power is not disconnected during resetting.
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
I bought a Sony DSC t700 approximately 6 months
If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
To set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness, press the UP ARROW on the control button until a lightning bolt icon appears on the LCD screen.
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
When shooting MPEG movies
When set to the Twilight mode
If an external flash is connected
If in the Burst or Multi Burst mode
Please touch the MENU option on the screen of the Camera.
Then, select the REC MODE under the MENU.
Then, select NORMAL under the REC MODE.
If you're not able to select the NORMAL under the REC MODE, try Initializing the Camera.
First, please touch the HOME on the LCD screen of the Camera.
Then, select the SETTINGS in the HOME menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize under the MAIN SETTINGS.
If the issue still persists after performing the troubleshooting steps provided above service of the Camera is required.
It's required to physically examine the Camera to determine the exact issue at the service center.
Jun 16, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Flash will not atomatically flash/can't change flash setting
Do you see any flash error code on lcd screen? if no then...
Flash will work when camera will set on auto mode ( green mark on jog dial) and you will see flash icon on lcd screen.
Dec 12, 2008 | Cameras
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Flash pops up but does not flash
Turning the Flash Off and On: 1. With the camera in any user set, repeatedly press the Flash/ISO button on the lens barrel until the flash cancel icon (a lightning bolt in a circle with a slash through it) is displayed on the control panel and screen. 2. When finished, to return to the default setting, press the Flash/ISO button until AUTO and the lightning bolt icon are displayed on the control panel and no flash icon is displayed on the screen. If it still doesnt help: 1. Check that batteries are fresh. 2. Check that camera hasn't been set for no-flash mode. 3. Give the flash time to charge before pressing shutter.
Sep 07, 2005 | Nikon Coolpix 5700 Digital Camera
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
