Question about Cobra Radio Communications
How to fix and tune a cobra gtl 148 - Cobra Radio Communications
  • Mike Charette Apr 15, 2015
    Hi Robert lombardo, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Genius:
  • Cobra Master
  • 1,795 Answers
There are 12 different kinds of 148gtl's.Which one are we talking about.
Posted on Apr 15, 2015
SOURCE: cobra 148 gtl
First take a jumper wire and connect it to the DC Ground of the input of the radio then touch it to the TX pin on the radio if it does keyes up then its in the mic or mic cord on the end of the mic plug or where it goes into the mic cable goes up inside the mic. If the radio don't key up at all then check the main voltage regulator chip one pin will have 8 volts transmit and another pin will have 8volts recieve. If you get no switching DC voltage on the regulator then its bad and needs replacing there is also a known bad capacitor in the radio thats only 10 volts change it to 25 volts at the same capacitance.
Posted on Jan 08, 2008
  • 9 Answers
SOURCE: cobra 148 gtl channel mods
contact me i can mod your radio for 65.00
Posted on Dec 06, 2008
audio20
  • 22 Answers
SOURCE: cobra 148 gtl dx manual
This is the Manual for the C148GTL
Posted on Apr 23, 2009
  • 19 Answers
SOURCE: Cobra 148 GTL ST. No AM transmit audio. Carrier is
Could be TR41 or TR42. I would try TR41 first.
Posted on Jun 29, 2011
Ironfist109
  • 3018 Answers
SOURCE: schematic diagram of cobra 148 gtl cb radio china made
  • Locate the MB8719 chip that is right behind the channel selector. Wire a SPST switch from pin 10 to ground and another from pin 11 to pin 12.
  • Channel Chart
  • Position 1: sw1 down, sw2 down
  • NORMAL CHANNELS
  • Position 2: sw1 up, sw2 down
  • 15=26.815 20=26.885 25=26.925 30=26.985(ch3)
  • 16=26.835 21=26.895 26=26.945 31=26.995(ch3A)
  • 17=26.845 22=26.905 27=26.955 32=27.005(ch4)
  • 18=26.855 23=26.935 28=26.965(ch1)
  • 19=26.865 24=26.915 29=26.975(ch2)
  • Position 3: sw1 up, sw2 up
  • 1=27.605 6=27.505 10=27.555 14=27.605
  • 2=27.455 7=27.515 11=27.565 16=27.475
  • 3=27.465 8=27.535 12=27.585 20=27.525
  • 4=27.485 9=27.545 13=27.595 23=27.575
  • 5=27.495
  • Position 4: sw1 down, sw2 up
  • 1=27.605 11=27.725 21=27.855 31=27.955
  • 2=27.615 12=27.745 22=27.865 32=27.965
  • 3=27.625 13=27.755 23=27.895 33=27.975
  • 4=27.645 14=27.765 24=27.875 34=27.985
Posted on Nov 09, 2011
Want to lower my dead key on my cobra 148 gtl mobile...where do i find the adjuster?
need to get a watt meter hooked up to then go the where the final is and look aroung for a tuning slug marked L38 and that is the baby you have to turn in order to power down this radio.
Nov 09, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
How do I increase power output for a cobra 148 gtl the latest Chinese version
best way is to leave the radio in piece and obtain a linear amplifier to do the job a 10 meter ham radio amplifier will do nicely but you must re-tune it for the 27 mhz band 10 meter band is 28 mhz.
RF amps work best using side-band mode.
Oct 14, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl d has problem transmiting with covers off. trying to tune radio up. was thinking I need to ground the chasis
I would say a bad or cold solder joint on board somewhere. Bad quality control. Might flex radio chassis slightly while keying? A tooth pick and hours of probing around switching area on board and the pa section till problem found.
Oct 25, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
Looking for the best micaphone for cobra 148gtl
Turner+2 Ham CB Radio Microphone Transistorized SSB Base Station Shark Fin
turner microphone ' eBay
Jul 29, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
I want to power my cobra 148 GTL in my home, want kind of inverter would I need to do this?, (watts)
you would probably want at least a 4watt continuous power supply or better. do not use as switching power supply.
Oct 23, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Have a cobra 148 gtl cb/ssb. It is brand new. I hvae it hooked up and have tuned the antenna using the swr meter on the cb. I habe channel 1 and channel 40 metting at about 1.6 swr. I have what appears to...
Hi, my name is John. Welcome to FixYa. Check your antenna, you need to set it with a real SWR meter, pick one up at any near-by CB shack $10.00. Thanks for choosing Fixya...John
Jul 22, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 channles
CONTACT ME AT COBRAMAN148@GMAIL.COM I CAN HELP YOU OUT.
Mar 30, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
5 pin mic
All "older", "real" or "desirable" Cobra 148 GTLs came with side-mounted 5 pin microphone sockets. For wiring information, see...
http://www.offroaders.com/info/tech-corner/reading/mic-wiring.htm
Feb 06, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
My cobra 148 gtl-dx has excessive levels of white noise that effect even relatively close stations incoming signal. is there any way i can vary or reduce the ferocity of this white noise
goto you tube and type in cobra 148 gtl dx and look for video by the cobraman in the uk - or type in the cobraman - u can contact him and he is a bit of a genius on this radio - he will even make a video and show u how to fix prblem
Jul 06, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
174 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
