Question about Microsoft Computers & Internet
How do I correct having used the Ctrl key instead of Shift. The result is that keys such as question mark do not work. Help!!!
alocenar
  • 293 Answers
SOURCE: keyboard ctrl key not working
try another keyboard to check if there is something wrong with your os settings.
1. if it works with the new keyboard , your keyboard is the problem.
2. if it does not work w/ the new keyboard still the same problem, os settings in the keyboard is the problem
Posted on Apr 01, 2008
SOURCE: keyboard problems - crtl, shift, alt keys does not work
I met the same problem, and I fixed it.
For my own case, it is mainly a hardware malfunction happening at the data bus(the wide, plastic strand) connecting the keyboard to the mainboard.
I found that part of that strand was bent, so I squeezed it to keep it flat.
everything has been OK since I did that.
zhao qi
Posted on Jul 03, 2008
  • 3 Answers
SOURCE: Keyboard
that means that the keyboard has been set to a different language. On my screen at the bottom right hand is a little keyboard icon and when i click on it it lets me scroll through US English, Canadian French and Canadian Multilingual Standard. If the keyboard is set to the Canadian French option (or whatever other option that is available on your keyboard in red characters) the number two button changes function.
Posted on Jul 29, 2008
SOURCE: My question mark key does not work
Remove conncetion from the CPU and connect it again. or
Otherwise you need to try with another shift button and try it.
It might work.
Hope this helped.
Posted on Feb 01, 2009
  • 105 Answers
SOURCE: when I use the shift key and the question mark , I get the French e symbol instead of the question mark. How do I fix this
Hi there
thi should be quite a simple fix for you
click start then control panel , regional settings , advances you should now be able to see what keyboard layout you are using click add then add the correct one for your language and remove the incorrect one
restart pc and test
Regards AL "alstech"
Posted on May 29, 2009
How do I get the question mark punctuation to work...
When you were typing something you probably hit the left shift key along with ctrl. Hold down the left shift and ctrl for about 2-4 seconds and you should get your question mark back.
To make it so it never happens again, go to control panel / region and language / keyboards and languages / change keyboards. Remove every language except for English (us) or whatever region you want to use. Before you accept verify that your keyboard is on your preferred language before you do this. check and make sure you are getting the proper slash when you push slash, to change it if you're not getting the slash use the (left ctrl + left shift for 3-4 seconds) if that doesn't work then try alt and left shift.
Sep 13, 2014 | Lenovo Keyboard
If function with array
Here is an example:-
We have to calculate result on the basis of marks.
1. Select answer range and click in formula bar
2. Type following formula
=if(d5:D9>=40,"Passed","Failed")
3. Now Press CTRL+SHIFT+Enter key
4. Observe the result in answer range and formula in formula bar, notice { } braces come automatically when we press CTRL+SHIFT+Enter key for an array.
excel3-yi4l5i2224qkwob0czw2k0fe-5-0.png For more clarification please mail on ali_zulfikar@yahoo.com with screenshots.
Apr 13, 2014 | Microsoft Excel for PC
Shift and cntrl keys are not working .Please help em how to reslove the issue?
It might be that you have by mistake turned on the sticky keys on the system.
Sticky Keys is an accessibility feature designed for people who have difficulty holding down two or more keys at a time. When a shortcut requires a key combination such as CTRL+P, StickyKeys will enable you to press one key at a time instead of pressing them simultaneously
I would suggest you to check whether the sticky keys are turned on. Follow the steps mentioned below.
a. Click on Start and click on Control panel.
b. Click on 'Accessibility Options' and in keyboard tab make sure that there is no check mark near 'Use sticky keys'.
c. If there is a check mark then remove it and then click on Apply.
Also check to see if anything is stuck under keys - cleaning the keyboard using a vacuum cleaner (AT VERY LOW SUCTION) could help
Oct 24, 2013 | Dell Vostro 1014 Notebook
Turning off my green keys on HP pavilion desktop keyboard?
How to turn off Sticky Keys: disable the Ease of Access feature
Tip: use the Windows Ease of Access Center
How to turn off Sticky Keys: what are Sticky Keys and why turn them off?
Sticky Keys is a Windows Ease of Access feature that makes it possible to use keyboard shortcuts or type capital letters without needing to press more than one key at once. Normally, you'd hold down the Shift key while pressing a letter to type a capital, or hold down the Ctrl key while pressing 'S' to save a document. It's even trickier if you want to use a shortcut such as Ctrl-Alt-Del or Ctrl-Shift-Esc.
With Sticky Keys, you can press Ctrl, Shift or Alt, let go and then press another key - Windows will interpret this as pressing two keys together. You should also hear a beep if you have speakers connected.
That's great if you're disabled and can't press two keys at once, but what if you want to disable Sticky Keys?
How to turn off Sticky Keys in Windows 8
You can't press Shift another five times. Instead, you need to bring up the Start menu (or Start screen in Windows 8) by pressing the Windows key. Now type "ease of access" and click on Ease of Access in the list of results.
If you're using Windows 8, you need to click on the Ease of Access Keyboard settings result, and then it's a simple case of sliding the Sticky Keys toggle to 'off'.
If this does not help you. Let us know the below details to understand the issue bettery.
What is the OS?
What do you mean by hot keys? ex.......
Rgds,
Divya
Sep 02, 2012 | HP (395366-001) Keyboard
Cannot change the function on my keyboard back to a question mark
If you're on Windows then try pressing CTRL+SHIFT keys together (sometimes ALT+SHIFT, see which combination works for you) until your keyboard layout indicator in your system's notification area (bottom right part of your screen, just left of system clock) shows the keyboard layout code that you're used to, in your case "EN". You can cycle through all the installed keyboard layouts using this same key combination.
Mar 02, 2012 | Compaq Keyboard
Where can i find a printable page to print all the controls and functions on lock on moder air combat please help
Scroll Lock Key nearest air target Alt + Scroll Lock Key center-of-view air target Shift + Insert Key next air target Shift + Home Key previous air target Shift + Scroll Lock Key nearest ground target Ctrl + Num Lock Key center-of-view surface target Shift + End Key next surface target Shift + Delete Key previous surface target
MISSION EDITOR Ctrl + N Key create a new mission Ctrl + O Key open an existing mission Ctrl + S Key save the active mission to disk Ctrl + Shift + S Key save the mission under another name Esc Key delete the current selection on the map Delete Key delete the current selection on the map Ctrl + Shift + C Key assign the active mission to a class and protect it with a password Ctrl + Shift + D Key declassify the active mission Ctrl + H Key hide or show specific objects on the map Ctrl + 1 Key return the map to the default magnification level around the crimean peninsula Ctrl + + Key magnify the map by a factor of 2 Ctrl + - Key scale the map down by a factor of 2 Ctrl + O Key take the view down to a very close level Ctrl + V Key magnify the map to a regional view centered on the selected object Ctrl + B Key view and edit the mission briefing Ctrl + D Key view a debriefing when a saved mission is loaded Ctrl + F Key start the current mission Ctrl + N Key begin a network multiplayer session Ctrl + M Key chat with other players during a multiplayer session Ctrl + R Key start the mission and record a video sequence Ctrl + P Key play back the last recorded video sequence Ctrl + V Key start the video sequence and enable its editing Ctrl + Shift + F Key specify failures that may happen to your aircraft Ctrl + Shift + W Key specify meteorological conditions Ctrl + Shift + E Key open encyclopedia Ctrl + Shift + O Key open options screen F1 Key help F2 Key keyboard command list
Feb 27, 2011 | Video Game Consoles & Games
Apostropy and quotation mark keys change
The only time that I have this problem is when I've accidentally hit SHIFT and CTRL at the same time. Do it again and you should go back to your old way of typing characters.
Jul 14, 2010 | Acer NSK8458AN Keyboard
I can't turn off the red keys on my Toshiba Satellite L300.
you press ctrl+shift either once or twice, it will revert back to the normal keys.
Jun 26, 2009 | Toshiba Satellite Pro L300-EZ1004X...
Cannot get apostrophes or question marks
I just figured this out. Hold down your left shift key, then press CTRL. It may take a couple of times for it to work, but it will eventually.
Oct 08, 2008 | Compaq Keyboard
Computers & Internet Logo
59 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
