Question about ProForm XP 440 Recumbent Exercise Cycle
Loud noise from bike pedals
Noise was not present initially
The bike makes a loud noise when pedaling
I suspect the crankset or bottom bracket. It can have the illusion of tightness when not moving, but "clunk" everytime you pres on the pedals. I would first make sure that the cranks are tight on the bottom bracket axle. This will require a metric wrench.
Oct 10, 2014 | Huffy Cranbrook 26" Mens Cruiser Bike
Pedal gear makes snapping noise
need new pedals, they screw off and one if left hand thread and one is right hand thread. or
unscrew both over the top to the rear.
Apr 11, 2014 | Tunturi E30 Ergonomic Exercise Bike
Pedal / Chain shaft(?) problem
Sounds like you will need new bearings,check manufactures website for parts and instructions.shouldnt be a hard fix.
Nov 29, 2013 | Schwinn Airdyne Evo Comp Upright Bike
Setup of new bike. Unable to turn pedals. Loud grating noise oise
Is the noise coming from the pedals themselves or the bottom bracket?
Jun 14, 2013 | Schwinn Cycling
Loud clicking noise while pedaling
The crank bearing is shot get a new bearing that should fix problem
Mar 01, 2013 | Exercise & Fitness
New Balance 6100 Recumbent Bike making a clanking noise when pedaling
I have done a tremendous amount of research on this problem. New Balance (Fitness Quest) is out of business as of late 2012 and no parts are available. The main bearing or crank bearing set is 100% compatible with Proform part number 295560. Since New Balance put their name on this product, they have stated they will reimburse customers for the repairs.
Feb 03, 2013 | Cycling
When pedaling starts off making squeaking sound but now it is very loud with cracking and popping.
Pedal or bottom bracket bearings need a look. The web has many resources for identifying noises on a bike. Just search for a few key words. For example "bicycle pedal loud cracking and popping"
One resource...
http://www.parktool.com/blog/repair-help/trouble-shooting-a-creaky-or-noisy-drive-train
Happy hunting.
Aug 18, 2011 | Cycling
Loud noise when pedaling. Stops when brakes are applied. Bike is brand new. Sounds like it's coming from the wheel.
Take the bike into you local bike shop to have properly diagnosed. This one has too many variables to guess and if something is broken or even just misaligned it could cause a problem that will result in serious injury. Your local bike shop will be able to help you best on this one, as someone really needs to see and hear the problem.
Apr 05, 2011 | Schwinn Cycling
Scraping/Squeaking noise on recumbent stationary bicycle
There are most likely some sort of bearings inside the wheel hub that are causing this.
Jan 13, 2010 | Cycling
ProForm XP 440 Recumbent Exercise Cycle Logo
331 people viewed this question
Top ProForm XP Cycling Experts
John Egan
John Egan
Are you a ProForm XP Cycling Expert? Answer questions, earn points and help others
