Question about Frigidaire Freezers
Let's try this again. My frigidaire freezer model Lffh21f7hwg, the display board reads "of". How do I reset it. I do not have the owners manual.
  • Official Brand Answer
  • 2,267 Answers
I appreciate your post, Clayton!
From the information you have provided the display board on your Frigidaire freezer reads "OF". That reading means your freezer is off, you should be able to turn it back on by pressing the up or down arrow five times in a row. If you need any additional assistance please feel free to reconnect. I hope this is helpful to you. -Matt
Posted on Apr 02, 2015
  • Sharon Grama
    Sharon Grama Aug 12, 2015
    Thanks so much for this info. Our 3 year old freezer was doing this and wouldn't turn on. So I tried this and it worked. We were all ready to call repairman or trash it. THANKS SO MUCH!
4 Suggested Answers
SOURCE: I have a frigidaire upright
OK, this is a failed controller board, any E4* is Power supply & Controller Board, probably caused by a power spike.You need to get the unit looked at to see if it is able to be repaired, and if parts are available. If you wish to try and repair this yourself, you must get a service manual, to do so, and to be able to order parts.
Posted on Apr 06, 2010
  • 1531 Answers
SOURCE: frigidaire freezer LFFH21F7HWG. the temp
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Posted on Sep 01, 2010
krb55
  • 604 Answers
SOURCE: We just purchashed a Frgidaire
usually the back wheels are rollers that allow you to pull the fridge straight out from the wall, so NO, not leveling in the back, but you don't need it anyway, just use the front adjustments
Posted on Mar 17, 2011
Display reading " of " and will not change by trying to reset
I've seen this on samsung refrigerators. It sounds like you put it in display mode. What's the model number?
Mar 06, 2015 | Frigidaire Freezers
Ok, upright freezer, frigidaire, read -12 after power outage but working ok..when I tried to reset temp to 0, light went off, freezer went off, front display reads 56..any ideas?
Thank you for your post, Cynthia!
Based off the information you have provided your Frigidaire freezer is not cooling properly and is now displaying the temperature of 56. It sounds like your freezer is not on, even though it has power the compressor is not turned on. I would suggest pressing either the down or up arrow three times within five seconds. That should power on your compressor and it should start cooling properly. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Feb 28, 2015 | Frigidaire Freezers
UPRIGHT FRIGIDAIRE (ELECTROLUX) FREEZER HAS STOPPED WORKING. LFFH21F7HWG
Hello Friend, I am happy to assist you!
I see that your Frigidaire freezer (LFFH21F7HWG) is not working. Often this is because it could have floating restriction in the line or something more complicated like an issue with the sealed system that only a professional can repair. This can include the compressor not working, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. It is typically normal to hear the compressor running, humming, or even to be a little warm. However, if you do not hear the compressor at all, I suggest cleaning your refrigerator out including the coils you can reach (typically located in the bottom behind the toe grille) and make sure no food items are blocking any vents in your appliance. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Best regards! - Z
Jul 15, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Figidaire model lffh21f7hwg lost manual don't know how to set digit inst. to set temp.
Free Frigidaire Freezer User Manuals ManualsOnline com Try this website. I know it is discontinued, but the manufacturer will be able to email you something.
Mar 16, 2014 | Freezers
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
We just purchashed a Frgidaire Freezer model #LFFH21F7HWG. Does it have leveling legs on the back as well as the front? Are we missing 2 leveling legs?
Mar 17, 2011 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer...
Aug 31, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a frigidaire upright frost free freezer model number is FFU2065FW3 I put in a new electronic temperature control Board and when I plugged the freezer back in, the control board was flashing "E" and...
Apr 03, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
Freezers Logo
521 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
