Question about Acer Computers & Internet
So my dad just got me a used pc from his friend and some cables were unplugged, i was wondering were they go. ps It doesn't show up on the monitor
  • 1,087 Answers
So you get no pre-boot video...You need to supply more info than this for a resolution. A picture of the wires your talking about would be a good start.
Posted on Mar 31, 2015
Acer aspire x1200 powers on but doesn't connect to monitor
  • Kindly check the cable that connect between cpu and monitor.
  • Re-insert RAM
  • Input Voltage if not connected using UPS.
Thank you for asking on fixya.com
Mar 20, 2013 | Acer Aspire X1200 Desktop PC - Athlon X2...
The monitor does not power up. no power light comes on, there is nothing that shows up on the screen. All cables are well connected and yes the power switch is on.
check by changing the power cord if this does not solve the problem the fault is in the power of the monitor better call technician or take it to the service centre
Aug 02, 2011 | Samsung SyncMaster 940UX LCD Monitor 19...
How do you use external monitor facility? Aged friend has Versa m370 and needs larger screen due to poor eyesight.
does your friend laptop supports dual monitor if does you need another monitor a larger one so that your friend wont have a problem with his poor eyesight. But if it doesn't support dual or multiple monitors do the same buy a new monitor a larger one.
Jul 01, 2011 | Computers & Internet
No signal to monitor
Check all conections between the tower and the screen, make sure all are secure, if no joy, unplug the tower and remove the side panel to see if the graphics card is in securely, maybe take the graphics card out and put it back in again to be sure. If you have another monitor or monitor cable try replacing to see if the situation improves.
May 05, 2011 | Acer Aspire M1641-U1521A PC Desktop
Normally, when the monitor is switched on, a blue screen is shown momentarily, with 'acer' right in the middle, before it shows the image that the computer is sending. But now, the screen does not show...
It sounds like either a bad signal input , possibly from a loose plug on the cable from the PC or bent pins on the plug / the video graphics card in the PC/ or the settings on the monitor need adjustment. Use the OSD (On Screen Display)
First check to make sure both ends of the cable from the PC to the monitor are not damaged and are seated good & tight.
If those are fine then unplug both cables from the monitor & leave unplugged for 10 minutes or so to see if the screen has an automatic reset.
If that does not work then use the monitors OSD (On Screen Display) to adjust to default settings. If that does not work, plug the monitor into another known good PC.This will tell you right then if its the monitor or "Your" PC.
__________________________________________________________
Here is your manual if needed
http://www.retrevo.com/support/Acer-AL1717-Monitors-manual/id/719ag107/t/2/
Oct 09, 2010 | Acer AL1717 17" LCD Monitor
ViewSonc VX924 LCD Monitor
Check the information at Viewsonic's website regarding their warranty:
http://www.viewsonic.com/support/warranties/limited-warranty/
If you have your proof-of-purchase and it shows the monitor is less than a year old, it would be covered. You would need to follow the procedure on their website to have the unit repaired or replaced, but it would not be your job to try to fix it.
Feb 11, 2009 | ViewSonic VX910 19" LCD Monitor
Is it my monitor or my video card
1.there might be a problem with your signal cable. if one of the pin in the signal cable is open. it might also happens
2.adjust signal cable.
3.Check VGA video card is working properly. unplug the VGA card and Re-plug to its slot. if your mother borad has inbuilt video card. this process cannot be performed
4.Even problem with operating system might also happen.. problem with Video Ram memory
5.if you want to check whether your monitor is ok. just get Cpu Box alone frm friends for a while for a testing.
6. if your monitor have problem then contact service centre.
Oct 15, 2007 | Samsung SyncMaster 551 15" CRT Monitor
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
Check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Feb 05, 2007 | IBM E74 17" CRT Monitor
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
