Washer ecosmart WA371 will not do anything. How do I reset it?
  • Washing Mach... Master
  • 5,323 Answers
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Posted on Apr 16, 2015
Ecosmart washer won't drain it filled with water, washed and nowwon't drain the water.
you need to vacume out all the water so you make it light, then dolly out the washer to some place you can drain it. now take off the front of the washer and locate your water pump, its attached to your drain line. take off drain line to water pump and see if anything is clogged in the pump. This is most likely what is wrong if it wont drain. hope this helps.
Feb 22, 2013 | Fisher Paykel EcoSmart GWL15
Fisher and pykel EcoSmart won't start
You can find a service manual at the link below to assist in repairing your machine.
Download the smart drive mw511 manual
Link:
Mar 10, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel EcoSmart GWL15 no power
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens ( or if there was nothing wrong with the breakers/fuses in the first place) sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 22, 2011 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
THE WINGS ON THE AGITATOR ON MY FISHER PAYKEL ECOSMART TOP LOAD WASHER ARE BREAKING OFF. CAN I REPLACE THIS EASILY?
yes loosen the wing nut nd remove nd replace , u can order part from F&P direct 1800650590 ask for spares
Jan 28, 2010 | Fisher Paykel EcoSmart GWL15
The washer wont drain
Check clear filter //pump
Sep 29, 2009 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel Ecosmart will Wash but not Rinse/Spin
You have too many clothes in the washer. Take some out and try again
Sep 09, 2009 | Fisher Paykel EcoSmart GWL15
Ecosmart washer will not stop filling
It needs a new fill valve. These are not expensive and you can easily do this yourself.
Jun 22, 2008 | Fisher Paykel EcoSmart GWL15
Maytag washing machine
The lid switch is bad on your washer. Either replace it or bypass it.
Oct 22, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
