I tried to reprogram my tv to get more channels, but now I can't get any channels. All I get is the words: Video, or Game, or ColorStream HD
  • Bobbi Gann
    Bobbi Gann Apr 05, 2015
    I did it!!! I left it alone for a couple days, and tried again with fresh eyes-discovered a combination of button clicks that I hadn't tried, and fixed it!!!
  • Bobbi Gann
    Thanks for being there!
  • 97 Answers
SOURCE: no video
Is the video cable composite or s-video? the output from the receiver to the sets line input (1,2,3,s-video) must be the same on most receivers. If the game console uses composite (yellow rca connector) to the receiver, the same cable must be the same from receiver to TV. Some receivers do "up convert" to s-video or to Progressive scan (red,green,blue rca connectors) and do not follow this rule. Yor set needs to be switched to the correct input as well. None of the receivers I have services thus far hve the 75ohm cable lug for RF. Check all the cableing and repost if you find something new or different.
Posted on Jun 09, 2007
Manutd777
  • 30 Answers
SOURCE: video input
If there is no input button on the tv itself to change the input then you will most likly need a remote. so you can get a universal remote and follow the instructions to adapt it to your set then you can use it to change the input. (you can get a universasl remote for like 10$) hope it helped
Posted on Aug 24, 2007
jan mczeal
  • 632 Answers
SOURCE: Sony (KDF42WE655). Always have a video 7 label on the screen
Try these:
  1. Press MENU on the remote control
  2. Select Settings
  3. Highlight Setup
  4. Select Label Video Inputs
  5. Select Video 7
  6. Select None if available or
  7. Leave the label blank
Posted on Aug 23, 2009
tvtek
  • 1284 Answers
SOURCE: I am using ColorStream for my HD inputs, the top
There should be a wide/screen size/ format button on the TV remote that allows you to make those adjustments.
Posted on Nov 11, 2009
j2easy
  • 152 Answers
SOURCE: I can not receive only one channel on my tv. I
make sure your input is antenna/tuner you might be looking at the input of another soure, such as your dvd/vcr thats why when you use the tv remote to go and change the channel it doesn't seem to change.
Posted on Nov 28, 2009
My toshiba 57H82 tv has double image blue and yellow
This is a known issue with the model that you have listed. The repair kit is here: http://www.tvrepairkits.com/xcart/57h82/ You should be able to solder, the kit comes with diagrams, photos, parts and support.
Mar 07, 2014 | Televison & Video
Cant hook my ps3 to my toshiba colorstream
you have the rca cables pluged in the wrong spot. move the three cables over to the right one spot. then it will work. you might have to put tv to channel 3 or select input1
Mar 11, 2013 | Video Game Consoles & Games
Black and white picture when connected to Toshiba LCD colorstream HD tv. Help!
Try to check the video format if in proper selection or try check this selection in your remote PAL,NTSC or AUTO. Wrong selection caused the fault of your unit. good day and thank's
Jul 14, 2011 | Televison & Video
Have new 55ux600u toshiba. Hooked up a one year old wii and get no color
The 55ux600u toshiba hdtv has a setting that needs to be changed with the wii in order to get color.
1. Click 'Menu' on the TV remote 2. Arrow over to 'Preferences' 3. Arrow down to 'AV Connection' 4. Click 'OK' 5. Arrow down to 'AV Input' 6. Change setting from 'ColorStream HD' to 'Video' by clicking the right arrow. 7. Hit the'Exit' button on the TV remote.
This will give you color for your Wii. You will have to change this setting back in order to view DVDs in color. :-)
Jan 01, 2011 | Video Game Consoles & Games
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Can't get system to come back on to tv screen after unplugging and now plugging back into tv. Worked just fine for over a year. Unplugged system and disconnected audio/video cables from front of TV to...
how was it connected at this other residence? was it via HDMI cable by any chance? if so try this, with the PS3 in stand by mode Press and hold the power button for 5 secs.. (until you hear the second beep) this causes the PS3 to reset the display properties back to 480i..follow the onscreen instructions to set it back up to 1080i
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
My hd cable box works great in all of the video in connections on the tv, but my dvd player, hd camera do not work when I plug them in, the picture is like it is scrambled, but if I plug the cable box in...
Are you connecting these devices to the ColorStream inputs?
If so you will need to set the output settings on the DVD player or your camera to 480i. You have an HD capable TV but it is old technology and is not capable of handling the signal levels produced by HD equipment these days.
Look at the menu options on your equipment and most of them have the ability to put out the lower level signal or just hook them up using the standard yellow/red/white inputs. Hope this helped.
Good Luck..
Dec 10, 2009 | Toshiba 36HF72 36" TV
I plug all the right stuff in but its not coming on the screen...i have i fixed to video and everything
Assuming you plugged in everything correctly, (power, yellow white and red) and have set the TV to the proper channel/input, there are only a few other possibilities:
1. Video cord may be bad (unlikely)
2. Xbox 360 may have some sort of hardware problem (would have to ship it in for repairs if it does)
3. TV won't support it. To check that, all you have to do is try it on a different TV.
Oh and something else I remembered. On the end of the video cord that goes into the Xbox, there's a little switch on the side of it. Make sure you have it set appropriately
Good Luck :)
Nov 29, 2009 | Microsoft Xbox 360 Console
I am using ColorStream for my HD inputs, the top and bottom of every HD input is cropped. how do i adjust in colorstream mode?
Nov 11, 2009 | Toshiba 57H81 57" Rear Projection...
Its not broken or nothin i was wondering how to put the input for cabel from cable/sat to colorstream hD1
Cable boxes or satellite receivers typically only come with audio/video output, RF output, and component output. You need an upgraded one which has the Hdmi output jack. The upgraded box will cost you a service fee around $5-10 a month, so if you don't want to pay to receive the 1080p service you can receive 720p by using the component video output leads from your cable box.
The quality is almost as good. The only difference will be that you won't be able to receive the hi-def channels that the cable company offers.
Apr 29, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
