Question about Tagital Tm 9" Android 4.0 Tablet PC Capacitive Touch Screen A13 1.5GHz Camera
How do i download apps straight to sd card? - Tagital Tm 9" Android 4.0 Tablet PC Capacitive Touch Screen A13 1.5GHz Camera
    Sergeant:
  • 268 Answers
There is no easy way to directly download apps onto your external sd card directly. There are methods to do the redirection using the Android SDK installed on a computer but they are too complicated for most users.
You can move apps to the SD card once they are loaded onto your tablet. Find the application manager on your tablet in Settings and go to each individual app and move it to the SD card. Or, an app I have used successfully is APP2SD, or now APPMGR III, which gives you a nice user interface to look at all the apps on your device and choose which ones to move to the SD card.
Posted on Mar 31, 2015
  • Tagital Master
  • 2,045 Answers
By default they're downloaded to SD card. What's the problem? Just move them afterwards to ExtSD if you want.
Another way (if you have your device rooted and familiar with Unix commands) is to change system start-up parameters to mount ExtSD as a /sdcard/download from terminal application.
We have a lenovo tab2 A8, with a 64 GB microSD card installed. With both netflix & amazon prime video, in options, there is no selection to download to the SD card instead of the internal storage.
First, go to Settings > Storage and check if the "Default write disk" is set to "SD card". Then go to Settings > Apps and swipe to the left until you get to "SD card". Below will be all the Apps that can be be moved to the external SD card. Click in the box on the right and another page will come up. About in the middle of the page will be "MOVE TO SD CARD" tab. Tap on it and wait until it finishes. Then go back and pick another App to move. You should be able to download apps directly to the external SD card. I haven't done that on this device and not all apps will download to the external SD card (the app maker can restrict downloads to only the internal memory. This tablet is one of the rare few Android devices that allow moving Apps to external memory.
May 25, 2017 | Amazon Tablets & eReaders
How do i set my tablet to auto save to my SD card
There are several methods to help you set download application path to SD card by default.
Please follow the steps given below,
Method 1:
- Insert the SD card into the device, Touch 'File Browser' on 'Home screen'.
- Tap 'Apps', On Apps, select the 'App to be installed'.
- Tap OK to install the App to SD card.
Method 2:
- Tap 'Settings' on 'Home screen'.
- Tap 'Storage', Check to turn on SD card, and set 'SD card' as the default storage place.
Method 3:
- On your Android tablet or phone, tap the 'App drawer' icon from the home screen.
- From the displayed list, tap on the 'My files' icon.
- From the opened window, on the top right corner, tap the icon with four horizontal lines.
- From the displayed menu, tap the 'Settings' option.
- On the opened Settings window, under 'Select directories' on the left, tap the 'Set home directory' option.
- From the window that appears next, tap to select the desired folder or the entire external SD card where you want the files to be downloaded by default.
- Tap the Done button from the top right corner of the window when you are done.
GuruAid.com
Jul 22, 2016 | Polaroid 7-in. Internet Tablet - Other
Not downloading to the sd card
If you are referring to apps you are downloading, that is probably correct. Most apps will not use the SD card to run (or load). It takes more programming for apps to use the SD card than not to, and since many users do not have an SD card installed, most apps won't use it. That is the falsehood that comes with tablets and eReaders. Users are led to believe that even though the tablet may not have a lot of internal memory that they can add an SD card. That works fine for personal files and photos, but not for apps and their data. Users need to know that if they want a lot of apps on their tablet, they need a tablet with a boatload of internal memory.
Dec 06, 2015 | Tablets & eReaders
How do I move my downloaded apps to my SD card?
You really should check the manual, to see how to move or to install the apps on the SD card. Not all Android tablets and phones work the same. You not giving any detail of yours does not make this easier.
Some systems can install the apps on the SD card and they can run from the card. Others only allow you to put apps on the SD card, but before you can use them, you have to install them in the internal memory.
Again, check the manual.
Apr 19, 2015 | Tablets & eReaders
I have an irulu tablet. I inserted a 32gb sd card. It says it is mounted and when i try to install an app from the google play store i get the message there is insuficient space available. how do i get it...
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
Dec 03, 2014 | Tablets & eReaders
How to set memory card as default memory storage
Download Titanium back up. it has all you need you can move all the apps to sd card including built in apps (the ones that can not be unistalled)
Caution: your phone has to be rooted juts google how it can be done in case you are not rooted yet. and be carefull while moving apps some apps can cause damage to your phone if moved to sd card. just move the downloaded ones and some few like photo viewer, galary, music player and the like
Nov 13, 2014 | Nextbook Tablets & eReaders
Why I can't download any apps
sounds like your cellphone has dumped all of the DOWNLOADED apps because there was too many for the size of the SD card, and they were clogging up the system , simple answer is get a bigger micro SD card then go to Playstore and look for ' my apps ' in the menu . you will see all of the apps you have downloaded , now you can download them again to the bigger micro SD card. try not to overload the micro SD card, leave about 15% free
Oct 08, 2014 | Nextbook Premium 8 Se Android
Nextbook 7 troubleshooting
I figured it out smile.gif Apps that I downloaded I can move to SD card while apps that were pre-loaded on the tablet can't be moved to SD-Yet when I move downloaded apps I get back MB even with clean master.
Try also this site.
How to transfer files and apps from Android phone Android tablet to SD...
May 15, 2014 | Tablets & eReaders
Moving apps onto sd card
Hi in order to move apps to sd card you need place the sd card in your tablet go to settings then applications. On the next screen you've got the list of downloaded apps just clik on one of them and then properties screen come up on which in the second row you will see button move to sd card. Just press on it wait few seconds and your apps is moved. Repeat this for every app but bear in mind that some of the apps can't be moved to sd card Regards
Dec 26, 2013 | Samsung Galaxy Tab Tablet PC
What does code 912 mean? i get this when downloading apps from apps store
There are a few reasons why you would get a 912 error when downloading apps.
  • Downloading apps directly to an SD card
  • Play Store (app store) needs to be updated
  • Bad cache
The following methods could help solve the problem
Clear Cache and Reboot
  • Go to Setting >> Go to Application Setting (In some devices application setting is named as apps).
  • Go to, All the apps > >Find the Google Play Store >> Clear Data and Cache
  • Once you have clear everything, Next you need to Force Stop the application
  • Also, try to clear Cache and data of Download Manager and Google Service Framework.
  • Now, Restart your device and try to download the app.
Unmount SD Card
  • Go to Setting >> Storage >> Scroll down and select "Unmount SD card"
  • Open Google Play Store >> Download the app again that was giving you the error message
  • After successful installation, Go back to Settings >> Storage >> tap on "mount SD card"
  • If above steps didn't work, also try removing your SD card before installing.
Move app to phone
  • Go to Settings >> Go to Apps >> Select, All the apps
  • Scroll down and select the app that was giving you the error during update
  • Select "Move to phone"
  • Open Google Play Store and update the app
  • After successful installation, you can move the app back to SD card
Feb 01, 2018 | Tablets & eReaders
Tagital Tm 9" Android 4.0 Tablet PC Capacitive Touch Screen A13 1.5GHz Camera Logo
373 people viewed this question
Top Tagital Tablets & eReaders Experts
Lawrence Oravetz
Vernon Taylor
Are you a Tagital Tablet and eReader Expert? Answer questions, earn points and help others
