Question about Craftsman 15" Scroll Saw Manual Model 572.247202
How do you attach saw blade ? - Craftsman 15" Scroll Saw Manual Model 572.247202
    Top Expert:
  • Craftsman Master
  • 10,875 Answers
Can't lousen bolt to put on blade on
Procedure for installing/replacing blades:
BEE CAREFUL DO NOT PINCH YOUR HAND!!!
REMOVE BATTERY FROM THE DRIVER!
1. Dismount saw from the driver!!!!!!
2. turn saw around, You will see gray button near of the axial, press it and hold it.
3. Insert key into screw on spindle and turn it clockwise
Apr 19, 2013 | Craftsman Bolt-On 3-3/8" Trim Saw...
Looking for replacement blades for Black & Decker Zip Saw
Its on ebay http://www.ebay.com/itm/NEW-BLACK-DECKER-ZIP-SAW-11-PIECE-CUTTING-SET-74-691-/260888941452
only 15.00
Apr 02, 2012 | Saws
How do i change blade on dewalt dw303 reciprocating saw
Open the yellow tab on the side of the blade guard and lift the blade out. Install a new on and close the tab. If the blade has been damaged, it may need to be pried off the locating pin at the attachment point.
Aug 08, 2011 | Dewalt DC385B 18v. Cordless Bare...
Saw won't turn when blade is attached, just clicks?
Dose it spin with the blade off. If so then the blade is bent take the blade off and put it on a flat surface if it dosn't lay flat you need a new blade.Even if you could strighen it enough to rotate it wouldn't cut vary good and wouldn't be safe to use.
Jan 24, 2011 | Milwaukee Tool 6310 20 Saw Circ 6 1/2 18V
The return spring for the blade guard on my Makita 5630D cordless circular saw came off. It is attached to the blade guard, but I can't figure out where it attaches to the saw housing. Any hlep would be...
there should be a hole in the housing towards the back of the saw, you can go to Makitatools.com and download a breakdown for this tool.
Feb 01, 2010 | Makita Saws
I bought a delta scroll saw model number 40-540, the blade was broken. I need to know how to change the blade and what type of blade the saw takes. Thank you
your delta scroll saw has two blade attachment points one under the table and one in the arm. attach under the table first and then in the arm. that way you can be sure to adjust the tension properly.
there are only two styles of scroll saw blade, those with pins and straight blades without pins
look carefully at your saw and you will be able to see which type holder you have
Sep 15, 2009 | Saws
I just purchased a Hitachi C12LSH. The blade hits the guard in the cutting trough. How do you move the saw blade to center it?
you should be able to adjust blade up a little bit, you only want blade to cut through tile bout 1/4 inch ,should be big knob you lossen to lift up motor and blade good luck
Aug 02, 2008 | Irwin Miter Saw Laser Guide Attachment...
RYOBI TS254 change saw blade???
should have blade lock button remove blade with proper size wrench reinstall new blade in reverse remember some of these the loosening of the blade will be clockwise so if nut dont come loose try clockwise to loosen good luck
Apr 22, 2008 | Irwin Miter Saw Laser Guide Attachment...
Craftsman 15" Scroll Saw Manual Model 572.247202 Logo
81 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Mike
John Trevino
Jim London
Jim London
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
