Question about Dryers
How can I remove the glass shade to change the bulb? I am trying to turn it, and it doesn't move.
    Genius:
  • 1,617 Answers
If it doesn't twist off then check for thumb screws on the inside of the rim.
Posted on Mar 31, 2015
How do you remove the glass shade to change the light bulb
I don't know what kind of fan you have but usually there are 3 thumbscrews holding on the glass. If you don't have that then you just twist counterclockwise. You might have to loosen it by pushing up on the glass carefully or spraying around rim of glass with WD-40
Feb 12, 2016 | Dryers
Model aer52ww5lkrc
Turn glass shade counter clockwise. Just to the point that it unlatches. Be extremely cautious or glass could end up everywhere.
Jun 29, 2013 | Televison & Video
Can't removed the glass to change light bulb!!!!
Try using an oil filter band style wrench wrapped in a towel.
It it breaks,that's OK-you won't get bloody.
Mar 02, 2013 | Casablanca Fan Stealth 3211T Ceiling
Replaceing bulb on ceiling fan
Turn off the fan before you climbing the ladder to remove the dead bulbs
  • Note whether a screw secures the shade or if the lightbulb holds the shade in place.Unscrew the lightbulb counterclockwise. If the bulb is securing the shade, grasp the shade with one hand while removing the bulb.Install the new lightbulb by turning clockwise into the socket. If the bulb holds the shade in place, keep the shade in position with one had while screwing in the bulb with the other.
  • ceiling light
  • May 15, 2012 | Hampton Bay 24002 Ceiling Fan
    Need new glass shade for hampton bay tahiti breeze fan. How do I get one?
    Hampton Bay is a Home Depot product. Many Home Depots carry these replacement shades in stock. If your Home Depot doesn't have this shade in stock they can order one for you. Regards, Joe
    PS Please rate my answer. Thank you.
    Jan 06, 2010 | Hampton Bay 52 In. Indoor/Outdoor Tahiti...
    I have a OK Lighting touch lamp and three of the glass planels are broken do you kow whenere I can get replacements
    Hello there:
    here is several links that will definatly help you in your quest to find touch lamp glass ok? look below mainly # 3
    best regards michael
    1. Lamp Shades - Glass Lampshades - Silk Replacement Lamp Shades - 2000 item catalog of glass lampshades, silk replacement. ... Finishing Touch - Finials. Tulip - Lilly - Large -Small. Oil Lamps & Fonts ...www.specialtylampshades.com
    2. Speciality Lamp Shades Add a finishing touch to your shades. Reverse Painted & Dome Glass Shades ... Replacement Glass Lamp Shades- Reproduction & Custom ...www.specialtylampshades.com/lampshades.html - Cached
    3. Touch & Glow Replacement Kit | LampsPlus.com 3-way touch lamp. Saves energy. Extend bulb life. ... Glass Shades. Light Bulbs. Night Lights. Under Cabinet. View All Categories. Bathroom Lighting ...lampsplus.com/.../Touch-and-Glow-Replacement-Kit__35098.html - 110k - Cached
    4. Elegant Touch: Brown's Lampshades ... a special accent for your special lamp and replacement lamp shades. ... Glass Small Tear Drop Lamp Finial. c3-finial $12.95. Crystal Gothic Cross Lamp Finial ...brownslampshades.com/store/ctgy/elegant-touch.html - Cached
    5. Nec Display Solutions 50016683 Replacement Lamp - Yahoo! Shopping Yahoo! Shopping has Nec Display Solutions 50016683 Replacement Lamp. Quick Links: Specifications - Description - Compare Prices shopping.yahoo.com/p:Nec Display Solutions 50016683 Replacement Lamp... - 126k
    6. Replacement Shade for 2198 Floor Lamp - Shop.com Shop for Replacement Shade for 2198 Floor Lamp and Floor Lamps at Shop.com. the 2198TA lamp was designed by fontana arte in 1954. a very dignified modern touch to an...shop.com/replacement_shade_for_2198_floor_lamp-59830151-7...
    lamp
    Sep 24, 2009 | Electrical Supplies
    Glass Shade wont come off
    The same thing happened to me, you put them on two tight. just right now i was going to take mine off so i could let u know which way to turn it. but can't take it off and i just put it on last night, & not too tight. i just remember that i have an xtra one, okay i got it it's counter clock wise. you're going to need someone to help you hold the light kit fitter assembly while you turn it. careful not to strip the light kit fitter assembly. mine rotates both ways now because when i tried to take it off it would turn so mabybe it's the other way, and nothing. then i got **** & started to used more force, back and fort, by myself even with the help of my friend it was a ***** to get it off. good luck. Rube
    Oct 23, 2008 | Hampton Bay 04078 Avanti Ceiling Fan
    Scanner error message hp laserjet 3030
    This problem has to do with the scanner mirror. You may hear a grinding sound, also. The reason it does this is because the scanner bulb cannot find 'home', so it keeps trying to find it. Well, it uses the mirrors to reflect on another object inside the scanner to tell it when to stop. The mirror on top of the right next to the scanner bulb may need to be cleaned. This works every time for me, except the same problem always comes back sooner or later.
    how to clean-
    1.unplug your scanner
    2.notice the glass covering on the left side, it can be removed with a Phillips screwdriver. Unscrew the plastic surrounding the glass and then remove the glass covering.
    3.Plug the scanner back in and wait for the scanner to move left and then unplug it before it starts moving to the right. Repeat this until scanner bulb is all the way on the left of the machine.
    -an alternative method-
    with the glass covering removed, use a pair of pliers to move the small belt that moves the scanner bulb. keep moving it until the scanner bulb is all the way on the left of the machine.
    4.With the scanner bulb assembly in reach, grab a Q-tip and gently clean the mirror that is just to the right of the bulb. You might want a flashlight to see the dirt and dust.
    5. Put the glass covering back on.
    6. Plug in the scanner.
    At first to me it seemed like it wouldn't work, but it does.
    Hope it helps. Reply back if it does.
    Jul 14, 2008 | HP LaserJet 3330 All-In-One Printer
    Minka aire concept II ceiling fan bulb replacement
    The glass dome is tightened firmly in the factory, so removal is difficult. When removal is attempted to, the metal housing to which the dome is attached will spin with it, making removal impossible. To see what I'm talking about, look in the small space between the dome and the bottom of the blade housing - it looks like a metal flange, but this is only the bottom of the reflective metal canister that holds the light. Note that there are 4 "dimples" around the circumference of this housing, facing inward. These dimples are what hold the glass dome in place. The trick is to use a rigid piece of wood or metal about the size of a 12" ruler and place the corner of that ruler in one of those dimples - FIRMLY. Then, a second person can get some leverage on the glass dome and "unscrew" it from the housing (counter-clockwise). The purpose of holding the ruler-sized material against the dimple is to keep the housing from spinning with the dome. This is easier said than done, but it will work.
    Mar 30, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
    Hampton Bay Torchiere with reading lamp(brushed nickel finish)
    Did your fan come with some little round things with three silver metal pieces on them? With some of these fans, you have to hold the glass shades in place, then place one of these round things (sorry, I don't know what they're called) over the bulb holder inside, and screw them down until they're tight against the shade. Or you may have the kind of light kit where there are three screws on the end of the arms where the glass shades go. Just unscrew these a little bit more so your glass can fit, then retighten each one. This is what holds the glass shades in place. Good luck!
    Sep 24, 2007 | Hampton Bay 24002 Ceiling Fan
    Dryers Logo
    69 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
