Question about Canon PIXMA iP1800 Printer
Printer is unresponsive. Power is on. USB cable double checked. I just replaced the two printer cartridges.Checked printer status and it said printer is not responding.
Drivers are fine and installed. I rebooted my Windows 7 Ultimate and I get the same status. I tried a different USB cable with the same results. The computer recognizes the printer but evidently no information is going to the printer. I went into printer properties (mgmt tab) and tried to turn off printer from there to see if the printer can receive instructions from the computer but no go. Please help! My name is Joe.
  • Michael Grey
    Michael Grey Apr 16, 2015
    Hi Joe Scuderi, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Was the printer working fine earlier?If so what changed?
  • 446 Answers
SOURCE: Printer doesn't respond to computer
there were many instances why the computer says "printer is not responding" either it is not configured correctly. for a start..
try this go to start- printer- right click the desired printer- open up properties- then click print test pages-
if it does print then it should work on all platforms, if it doesnt then you might have installed the wrong drivers.
try this first
Posted on Jul 24, 2008
SOURCE: Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
Posted on Jul 10, 2009
  • 235 Answers
SOURCE: USB device not recognized
try to connect your printer to other computer if still same result have your printer check to see what is the problem with the printer
Posted on Nov 21, 2009
Testimonial: "Should have thought of that. Thanks."
  • 4472 Answers
SOURCE: Canon Pixma ip5200 under Windows 7 - not responding
Did you download the latest drivers from the website? It looks like they were posted this month. I would report the issue. It is quite likely there is a compatibility issue. Have you contacted canon at all about this problem? Once I have more information I can try and assist you further.
Thank you,
Also check out my tip on how to save money using less ink:
Posted on Jan 27, 2010
  • 9 Answers
SOURCE: I wish to install a Canon LBP2900B printer under w...
somehow this is because Win 7 actually does not support all devices. try installing the device using win xp or vista, if it does work then it really has no support for win 7
Posted on Jun 28, 2010
My printer is a HP- 6210, Message: "remove and
Hello Cliff, welcome to FixYa.
Hard Reset the printer by doing the following:
  • Remove all the ink cartridges.
  • While the printer in ON, unplugged the power cable from the power source.
  • Disconnect the USB cable at the back of the printer (if your printer is connected through a USB cable)
  • Restart your computer.
  • Connect back the USB cable.
  • Plug the power cable to its power source.
  • Turn ON the printer if it does not turn ON automatically.
  • Install the ink cartridges.
  • If the printer prompts for an print head alignment, please do so.
If the problem persists, replace the ink cartridge. The cartridge might be defective since you already have tried to clean the contacts.
Keep me posted.
Sep 28, 2011 | HP Photosmart 2610 All-In-One InkJet...
Printer and status light flashing - feed not working. Have checked cables.
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Unplug and re-plug the printer into the power source to reset it.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper.
  11. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 26, 2011 | Lexmark X1240 All-In-One InkJet Printer
I can not get anything to print on my Epson NX420 using my IMAC. It says the printer is offline and I can't even print a test page. Can you help?
I'm assuming the printer worked previously from the iMac and now it does not. If you never had it connected, please add a comment to this effect, and include your OS version.
First, Open the Print Center (Printer Utility) and check the status of the printer. It may be listed as stopped. If so, delete any extra print jobs (additional attempts to print the page), then click the Start Jobs icon.
You can verify printer connectivity by clicking Add in the Printer List (if that is not visible, select Show Printer List from the View menu). Be sure to select either the USB or wireless network protocol connection. If the NX420 shows up, you have a good connection. In that case, click cancel and skip the next paragraph.
If you are printing via USB, check the cable (I sometimes forget to plug in my printer cable after downloading from my camera). If you are printing via your wireless network, check the status of the wireless connection from the printer.
Also, in the printer utility window, click the Supply Levels icon to verify that all of the ink cartridge levels are high enough to permit printing.
Are there any error messages on the printer display? A fault detection will take the printer offline.
Jun 22, 2011 | Epson Printer
"PAPER JAM" problem appears but there's any
check the printer for any piece of paper if there is remove if you cant find them remove the cartridge and you can use a low pressure vacuum or blower then in the computer in the task bar double click the printer icon and remove all the files then switch off the printer remove the usb cable and the power cable also restart the computer after restarting the computer connect the printer usb and power plug then go to click start settings and double click the printer you will see the name of the printer make the printer default then right click properties then click print a test page
May 01, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I Have HP Photosmart 6350 and replaced the three colors ink. I'm now getting error code 9a0036 which tells me to turn off printer and then start again. It doesn't solve problem. Have checked documentation...
First follow these simple instructions:
Remove all the cartridges, clean the contact points on the cartridges and on the printer using soft brush/cotton dipped in alcohol/acetone /spirit.
While the cartridges are kept for drying, do the following:
Turn it off > Disconnect usb cable, power cord, inthernet cable; >remove the papers from the tray >open the back panel door (the rear door where you clear paper jam). Also turn of the main switch which the dc adapter plugged in. After keeping it Off for about 5 minutes, turn on again with only the power cord connected, and again leave it on for few minutes > turn it off > connect all the cables > again turn it On and keep pressing the power button while it boots up. Now you can install the cartridges. Check the status message. Hopefully it should be gone by now.
If the problem persists, there must be internal hardware/firmware problem and will be needed to call for service.
Good luck.
Thanks for using FixYa.
Aug 19, 2010 | HP Office Equipment & Supplies
I have a Canon Pixma MX330 color printer. It gets used only occasionally, usually to print brochures and the like. I recently switched it to copy mode by pressing the "copy" button on the front; now it...
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 05, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Continues to say the "check your color cartridge" despite new cartridge and double checked reinsertion.
Please rest your Machine... to do this follow the instructions below;
First of all, Remove the cartridges, and clean the contact points on the cartridges and on the printer.
  • - Turn off your printer, disconnect usb cable, power chord etc.. open the back door, press the power button several times.....
  • - Now connect the power chord and power the machine while you keep pressing the power button (don't hold down), and let me boot up, leave it On for few minutes.
  • - Turn it Off and install the cartridges, reconnect the usb cable, etc.. and reboot the machine. You'll see how it works. If you have problem even after this, please let me know.
Good luck.
Jun 15, 2010 | HP PSC 950 All-In-One InkJet Printer
Dell photo 924 is completely unresponsive. Power
Pitch it. There does not appear to be a firmware update. That would be the only thing that would have a chance of fixing this. Otherwise, the controller board is shot. The cost of repair is more than the printer, buy a new one.
Oct 26, 2009 | Dell 924 All-in-One InkJet Printer
My HP Officejet J4540 All-in-one printer is showing Offline. I have checked all connections and all appears ok. Could you tell me how to change that status to Ready?
It shows offline if the printer is not communicating. Initially open printers folder and right click the printer icon and check if "use offline" option is not ticked.if its ticked then un-tick it. if everything looks fine then:
1)first try unplugging printer from main power cord for a minute and then plug back in and check after refreshing if it becomes ready.
2)other thing to do is to remove the usb cable from behind the printer and plug back in after 45 seconds.
3)it is also quite possible that the usb port or cable might have gone that case try replacing usb cable and check.
thanks ,keep updated and accept the solution.
Sep 02, 2009 | Office Equipment & Supplies
Canon PIXMA  iP1800 Printer Logo
54 people viewed this question
old marine
old marine
