Question about Jeep 1999 Grand Cherokee Laredo
Changed engine in 99 jeep grand cherokee larado 4.0 engine now no spark
  • Jeep Master
  • 20,706 Answers
Wow first guesser asks you to replace most expensive EFI part in car,
dang man. check fuses first.
what nice advice. that is. (not)
sorry no, that is last ,fella. its dead last.
(read the FSM yet it says just that and for good reasons)
(and same book warning not to put i new ECU with outputs shorted)
(electronics, 101?)
most posters say replace all sensors first. that too is crazy.
are you growing money on trees"?
lets do the real list, not guessing,,,,, ok? (take a ASE course?)
  1. check fuses first.
  2. is the ASD relay dropping off line (opens) while cranking? BINGO ! if YES. the PCM will tell you why, if you just listen 100% true, every TIME. (DTC errors will dump)
  3. I then connect any scan tool made.(works on 93 and up) and crank for 5 seconds, the PCM cuts the ASD, and the PCm tells you why it did, no looking, is MAX pain for you. (i promise)
  4. never tuned up this decade? a full 60k mile listed one engine, lost the list? (sure all spark parts that dont last forever)
  5. Scan shows, CMP or CKP dead?, well it is. (5seconds cranked)
  6. The PCM will tell you they are bad, even 1 missing pulse in 10 for sure. all it takes is a scan tool , any one. made. works. this year. (old car) even $10 tools (ask)
  7. if the coil primary is dead, or the ignitor, the PCM also throws codes for that, cranked for 5 seconds. (i add 2 sec, to the 3 second rule in pcm for ASD, see why? I do that?)
  8. if say all the above is good, then the coil is bad. if spark is dead on ALL cylinders , you never said all, are bad, so..... bad inputs from you there, sorry. never check just one spark plug.
  9. that is it on spark, how did it do... real diagnosis and not one guess, ever. (tuneups are not guessing)
links
http://www.fixkick.com/Jeeps/ASD.html
WJ jeep 99
the I6 has a coil pack, for all 6 cylinders
makes spark testing harder, not impossible, but a PITA to work.
not scanning this car, is a FAILURE TO see facts.
all those P03xx errors? P0350?
even P0351 to 6. P0301 up?
but here it is
watch Youtube, are all dead.
if yes, the PCM will tell you at 90% of time.
if not the pack is bad.
the pcm reports inputs to PCM bad or reports coil pack sucks too much current then its what its telling you. believe it.
the PCM is the ignitor side to coil pack coils.
the Pcm monitors this side, fully.
Posted on Mar 31, 2015
  • 4 more comments
  • _-__-___-_
    _-__-___-_ Mar 31, 2015
    https://www.youtube.com/watch?v=Sk_8TKMw...
  • _-__-___-_
    sorry forgot the video of how to do this correctly , pack check.
  • _-__-___-_
    past that in URL window of any browser made.
  • _-__-___-_
    paste.
  •  johnny rebel
    johnny rebel Mar 31, 2015
    THANK YOU CADAVER FOR THE COMMENT,NOT NICE,I GUESS I WILL FOOLOW YOU AND CRITISIZE YOU FOR AWHILE,WHERE IN "Changed engine in 99 jeep grand cherokee larado 4.0 engine now no spark"" DOES THE POSTER STATE THAT IT WAS THE SAME MOTOR??HE DOESNT,I HAVE 4 JEEPS,I SWITCHED MOTORS IN 2 OF THEM,I NEEDED THE ECM BECAUSE THEY WERE DIFFERENT SIZE MOTORS,SO,WHEN I DONT HAVE MUCH INFO I GO WITH WHAT I KNOW,IF IT WOULDVE STATED SAME 4.0,THEN THAT IS A DIFFERENT STORY,I WOULDVE SAID CHECK THE FUSES,ALSO WHEN YOU GET A SWAPPED MOTOR YOU GET THE ECM WITH IT,THANK YOU AGAIN,I CANT WAIT TO HUMILIATE YOU!!
  •  johnny rebel
    nice name change jambalaya!! you might want to check terms of use of fixya cadaver
    Top Expert:
  • Jeep Master
  • 10,875 Answers
Did you replace the computer that goes to that motor?? you need to
  • 9 more comments
  • shannon stewart Mar 31, 2015
    no. it turns over just no spark
  •  johnny rebel
    you need the onboard computer or it will never run
    what is the onbored comp
  •  johnny rebel
    http://www.ebay.com/itm/1999-Jeep-Cherok...
  •  johnny rebel
    go to url
    oh i didnt know u had to change that when you changed engine bc i changed motors without haven to. is it just this engine u have to do this
  •  johnny rebel
    all motors that are controlled with a computer,especially if it is a different size motor
    same motor same kinda jeep i changed a motor in a grand am last month and in a aztek 3months ago and didnt change comp
  •  johnny rebel
    check coils and control plate under coils
  • coady
    coady Mar 31, 2015
    take it to someone with a diagnostic computer to read the codes. it will save you alot from wasting time and money.
    my husbands grandpa has a hand held one like auto zone will that work
  • 27 Answers
SOURCE: HOW DO I CHANGE THE WATER PUMP ON A 99 JEEP GRAND CHEROKEE ?
At least you have the 4 liter 6. Once you get all the **** out of the way its like replacing a W/P on an "old school" engine, very much like a Ford or Chevy straight 6. 1) Remove radiator top retainer (the metal U that looks like its the top of the radiator (#13 or 14mm sockets I think). 2) To completely get if off you also have to remove the grill (4-6 phillips screws), then 3) unbolt it from the tubular bumper retainers underneath the grill. 4) DO NOT remove the latch cable - no need. 5) Remove the top bolts holding down the fan shroud. Lift the shroud off its bottom "tabs" and push over the fan. 6) Using #10mm socket remove fan from fan clutch, then remove bolts holding fan clutch onto water pump pulley. 7) Pull out shroud, then fan, then fan clutch. Be very patient, lots of wiggling may be needed. 8) Locate belt tensioner on idler puller below the Power steering pump. Losen very little the pulleys center bolt (10mm), then use a 10mm w/entension to losen the pulley's tension (use counter clockwise/normal rotation to losen). 9) Draw a diagram of the belt routing - you will Never remember it correctly otherwise. 10) Tap the w/p pully and pull if off - do not hit radiator fins! 11) Drain the radiator (clockwise/right rotation opens petoc from factory radiators - counterclock used on aftermaket rads). 12) Remove lower raditor hose at radiator, then at pump (it will be a challenge). 13) Remove upper radiator hose from rad and from thermostat housing. 14) losen the Rubber heater hose from the metal hose screwed into the W/P. 15) Remove 4 bolts from W/P (13 or 14mm I think). The one at the 4oclock position is longer than the others. One is hidden at 6oclock.
16) Remove 2 bolts (14-15mm??) on bottom of Power Steering mount - these go through the W/P case to the block. You may also need to losen the top PS bolts so the PS Bracket can be loose at the W/P case. 17) Wiggle the W/P out from under the PS bracket. and pull off. (16b if needed, remove the upper idler pulley near the A/C unit.) 18) Remove the Thermostat (upper hose return) housing. Scrape off old gasket. Replace with 160deg or 190deg thermostat. Use silicone on gasket. 19) Carefully use a 17 or 19mm box wrench to remove the metal heater hose return line from the upper part of the old water pump. Coat threads with spark plug thread antiseize and screw onto new W/P. 20) Install new W/P gasket w/silcone, be careful to Not block the water holes. 21) Slide W/P under the P/S bracket and jiggle into place. Hand thread one of the top bolts to hold the W/P in place. 22) Insert the P/S bracket bolts and lightly tighten. 23) Jiggle W/P around and insert other bolts, start with the 6oc hidden bolt. Add remaining bolts and tighten to 25 or 250?ftlb (about 3/4 past socket-snug). 24) Tighten ALL P/S bolts. 25) Adjust metal heater pipe. Reinstall rubber heater hose. 26) Reinstall W/P pulley and Fan clutch, and upper idler if it was removed. 27) Thread NEW Belt on pulleys. 28) Tighten tension on idler. Tighten idler axle bolt. 29) Install lower rad hose. 30) Slide shroud over pulleys. 31) Install fan on clutch. 32) Clip shroud retainer bolt mounts back on top of radiator. 33) Install shroud. 34) Connect upper hose. 35) Reinstall radiator retainer. 36) Bolt retainer to Tubular bumper mounts. 37) Reinstall grill. 38) Wonder where the extra bolts etc are supposed to go. 39) Cuss - pray -cuss - pray. 40 ) sip some beer. 41) carefully inspect everything to ensure its back to the way it looked before (several pictures from a digital camera taken during the disassembly will help). 42) Close the rad petok. 43) Add 1 gallons of antifreeze. 44) Start engine and add another gallon of A/F. 45) Turn heater controls to HOT inside (no need for fan). 46) Water guage should show 180 to 210F. 47) Add 1 gallon of water. 48) Install New 18PSI rad cap. 49) Turn off engine and add water or A/F to overflow tank. 50) 1 hour later open Cap to see if level has settled. Add Water as needed to fill rad.
Posted on Dec 31, 2008
SOURCE: 1996 Jeep grand Cherokee Larado, rear door stuck
go throu licence plate pannel pull up on bar and on the inside under ur pannel the nut fell off the mechanism so just put on a new nut
Posted on Feb 03, 2009
  • 136 Answers
SOURCE: Changing spark plug wires on 2001 Jeep Grand cherokee
yah direct ignition coil pack does away for the need a a distributer cap and rotor.much higher energy ignition system where the computer tell when to fire.if that helps.not hard to change.as long as you change them one at a time so you don't screw up the order.
Posted on Nov 28, 2009
  • 6982 Answers
SOURCE: Where is the camshaft sensor located on my 99 Jeep Grand Cherokee
If you still have a cap rotor and ignition wires, it's inside the distributor. If not, it is the part where the distributor used to be (center rear of the engine behind the intake manifold)
Posted on Feb 19, 2010
  • 2926 Answers
SOURCE: 99 jeep grand cherokee no start 4.0L no power to
Check the auto shut down (ASD) relay located in the power distribution box.
Posted on Jul 23, 2010
How to change thermostat on 4.7 2000 jeep grand cherokee larado
Passenger side, front of engine, where the lower hose comes out of the engine, its behind the black plastic thermostat housing that is bolted to the aluminum front timing chain cover. Two bolts hold it on, 8mm socket gets them off.
Jul 13, 2014 | 2000 Jeep Grand Cherokee
My 99 jeep grand cherokee larado is misfiring
may be you should make a diagnostic and you can do it in a garage or you can do it by yourself if you want to do it by yourself you need some tools and you can find some good ones here: xcardiag.com
Feb 26, 2013 | 1997 Jeep Grand Cherokee
How much transmission fluid goes in my 1997 Jeep Grand Cherokee Larado V6 and where do I fill it?
Hi there:
Check this information about your 1997 Jeep Grand Cherokee 4WD 4.0L MFI 6cyl...
- 42RE transmissionService change only - 4 quarts. Total refill - 11 quarts.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 21, 2012 | 1997 Jeep Grand Cherokee
I have a jeep grand cherokee will turn over but wont run
I suspect the crankshaft position sensor, giving the info you provided.
Jun 13, 2010 | 1995 Jeep Grand Cherokee
Where in the engine can i find the crankshaft position sensor in a 99 jeep grand cherokee larado 6 cl
Right side of the engine block. A little off center towards the back. Should be sticking out the side of the engine with a plastic plug on a shaft about the thickness as a shovel handle.
Mar 16, 2010 | 1999 Jeep Grand Cherokee
2001 jeep gd. cherokee larado 4.0 4wd auto. when
Have you run an engine control system fault code test? If not do that first.
Jun 08, 2017 | 2001 Jeep Grand Cherokee
Where are my spark plugs on grand cherokee larado fuel injection model located as there is no distributor either?
what engine? on the 4.0l they are on pass side of engine under a long plastic cover with 5 15mm bolts and a plug at back for the coil packs and all come off in one piece so after all the bolts are out gently work the thing up a little at a time working your way down until it world free,easy job to do just be careful of any wires you might pull on and heater hoses need to be held out of the way.
Sep 26, 2009 | 2003 Jeep Grand Cherokee
Aug 09, 2008 | 1996 Jeep Grand Cherokee
Jeep 1999 Grand Cherokee Laredo Logo
131 people viewed this question
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Stan Ford
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
