Question about LG Computers & Internet
I have a lg ultraslim writer and cant get my movie from cp to a disc like I want ..it gives me error that windows cant recognize or read or something I ant figure out how to do it ...
  • 117 Answers
SOURCE: Drive is not reconized
Hello impurrfect,
Since you have completely removed the drive from the computer, remove the CMOS battery(big watch battery) on the motherboard for about 30 seconds then reinstall the battery, then reboot. This time however, when you press the power button to bootup, you need to start tapping F2 about 2-3 times per second to access the BIOS. If the F2 key does not work, try using F1 or maybe even the Delete key.
BIOS screenshot: yours may look a little different but the concept is the same.
http://drivers.softpedia.com/get/BIOS/Iwill/Iwill-XP4evo-Bios-105a.shtml
Once in the BIOS go to BOOT or BOOT DEVICE, something to that effect and see if the drive is listed. You will also have to reset the system time while in BIOS so now is a good time to do that as well.
Regardless If it IS or ISNT listed, go ahead and exit the BIOS and choose YES SAVING CHANGES. Your PC will now continue to boot into normal mode. Once in Normal Mode, go ahead and go through Shut Down and once shut down, reinstall the drive and hopefully the PC will recognize it as a new device. Then you can visit the manufacturers website for firmware updates.
Posted on Jul 10, 2009
billfox1966
  • 231 Answers
SOURCE: windows won't recognize dvd writer
email me and i will send the driver in an attachment file.please not though that the hp 740i burner is an internal I D E supported drive not a USB. as long as its a 740 model the driver should work, wether its usb or ide is up to the computer to associate it with.
billfox1966@yahoo.com
Posted on Jul 24, 2009
  • 145 Answers
SOURCE: lg DVD writer can not read DVD but CD . what's the
Dear,
This is a usual issue. You have to replace it. May be issue on DVD encording circute.
Get it replaced....
Posted on Oct 17, 2009
  • 1481 Answers
SOURCE: LG GH22 LS50 (Sata Dvd Writer) Will not write dvd discs
What software do u use to write DVDs on both PCs...
if they are different then that may be the issue....
dont spoil the DVDs....
try DVD RW disks...that way you can erase them later...
i too have the same DVD writer, not had any issue in either XP or Win7....i have dual boot and have made many movie DVDs using both OS...i use Nero and Power2Go of LG(the install disk that came with the LG DVD writer has this great software...."LG Power tool")
try this tool...it should work...
the inbuilt DVD creator in Win7 has some issues with DVD creation....due to non compatibility of graphics card and display drivers (WDDM)....+ you may not have the correct codec required to burn DVDs.....
get the FFDSHOW codec from google.... and install it...shutdown and restart and then try...
let me have a feedback pls...
reg
Posted on May 04, 2010
joecoolvette
  • 5660 Answers
SOURCE: LG GH22NS70 Super multi DVD Rewriter just used
Power cable attached, interface cable attached, (Dta cable), and the small audio cable attached, plus computer on, and Windows loaded.
Windows XP:
1) Click on Start
2) Right-click on My Computer
3) Left-click on Properties at the bottom of the list
4) Left-click on the Hardware tab
5) Left-click on Device Manager
6) When Device Manager loads, left-click on the + sign to the left of - DVD/CD-ROM drives
7) Right-click on the name of the optical drive.
8) Left-click on Uninstall
A Microsoft 'squawk box' will come up,
"Warning you are about to uninstall this device"
It's okay. Click on OK.
Close all windows, go back to your desktop screen.
Turn the computer off normally. (Start > Turn Off Computer > Turn Off)
Wait 1 minute. Turn the computer back on.
You should get a pop-up out of the system tray, "Found new hardware", and perhaps another one will follow, "Found XXXX DVD drive"
No? Doesn't work?
Try using another 4-pin standard Peripheral power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(The IDE harddrive shown, is just an example of a device that uses a 4-pin standard Peripheral power cable. Mistakenly referred to as a 'Molex' power cable)
Make sure the interface cable (Data cable) is plugged in tightly.
Regards,
joecoolvette
Posted on Jul 17, 2011
HP DVD writer 1140D doesn't recognize DVD's thinks drive is empty. Research on driver versions shows it's using Microsoft drivers. I would like to have the HP drivers to download that came with the DVD but...
all dvd writers have drivers on windows...and are installed automatically when windows is installed..If it started not to recognize dvd-es ...specially the ones burned in data format with multiple movies (avi ) ..even burned on it ...but sees the original ones..or sees the cd'es ..than the issue is with its lens ..and either you need a cleaning disk to clean it up ..or it is gone ...and need to be replaced..I personally have to do with something like this sand tried to update firmware ..installed original driver from the support site ,,and all the same ..Clean the lens and see how it is behaving ..and if it does the same ..just replace it ..cause they do have limited life time..otherwise you will end up with a lot of frustrations and no results...
Mar 18, 2011 | HP DVD1140i 22x Pata Multiformat Dvd...
reg
May 04, 2010 | LG GH22LS50 DVD-RAM Burner
I have just purchaced alg gh22lp20 dvd drive but
the computer should recognize it as a dvd-device though, if not windows is giving u trouble,
so try using any other
freeware burn program like nero or burnatonce to burn,
u necessarily need the original software.
to get anew copy of software email the manufacturer, then post send the cd in exchange for a newer one or look on th homepage if they have something fittng your drive- model and operation system ready to download...
good luck
Sep 01, 2009 | LG GH22LP20 DVD±RW Burner
Wont read dvd video discs
1st step; Acquire/buy a cd/dvd rom drive cleaning tool kit from your local pc store.
2nd step; Install a dvd coder/decoder software, try Power DVD player software it has a trial version
3rd step; After installing the DVD coder/decoder from Power DVD player try playing a dvd movie rom disc it should work/play... hope these tips help ;-)
May 24, 2009 | LG GMA-4020B Super-Multi...
CD drive doesnt recognize a dvd
Sorry to say, but a CD drive cannot read DVD's. You need a DVD reader. Thus, the CD drive will not recognize DVD media and tell you no valid disc is in the drive. I recommend buying a DVD RW (reader/writer), as they are inexpensive and enable you to burn DVDs as well as read them.
Jan 01, 2009 | Dell Dimension 3100 PC Desktop
Optiarc DVD RW AD-5170A ATA not writing DVDs
sounds like your file is to large by the time it writes in and out or the disks a not to great
Mar 02, 2008 | Computers & Internet
Hd writer 2.0E fro sx/sd
I had this same issue...I bet you're using DVD-R, am I correct?
Apparently you can't copy video from DVD-R to the HD Writer. Period. Just can't do it. (Would be nice if they mentioned this in the manual.)
You can only use DVD-RW and must format the disc to VR format, not Video format.
I'm using a program called Handbrake (free) which I think can convert your .vob files (from the Video_TS folder on your DVD) to quicktime files, or similar, so that you can actually do something with the video...
Best of luck, I'm really no expert, and I probably won't return to this page, so a reply to me is likely not going to be read by me...
Feb 07, 2008 | Panasonic HDC-SX5 DVD Camcorder
DVD writer not reading disks
change ide cable 1st ok get back with me thx nick
Feb 03, 2008 | Computers & Internet
LG V8824
the small 12 tooth gear on top of the slide motor could have a crack in it , this will lock the slide from working
Sep 21, 2007 | Sony SLV-D350P DVD Player/VCR
Sony DW-Q30A Problem
the dvd writer needs to be replaced,the laser is faulty or miisaligned, the cost of a repair is no longer viable because a new one would cost about $60 (£32.00)
May 30, 2007 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Computers & Internet Logo
187 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
