Question about Measuring Tools & Sensors
What is the hoursepower of my sears 143-186022 vertical shaft enging?
  • 2,963 Answers
Owner's manual no manual, try manualslib.com
Or google make model possibly serial or ebay for a replacement engine. Ebay usually has complete specifications for a replacement engine.
Posted on Mar 31, 2015
I have a Digidoor garage door that closes halfway and the opens again however when you apply a little pressure to the door the door closes completely The entire shaft was cleaned and lubricated but still...
There probably is a dent along the shaft either in the remaining region or the already occupied region. You should open it completely and verify that the shaft is uniform. There could also be a deformed roll in the part of the door that enters the vertical part of the shaft around the time the door stops closing.
Nov 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
Engine turns over but doesn't fire.
check it for spark then check if it is getting fuel cuz that might be the problem
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Manual for #103.0205 circ. saw
Earlier comment 103.0205 Table Saws does not need lubrication is simply wrong.
The103.0202, 103.0203, 103.0305 Craftsman Companion Table Saws main Arbor axle DOES have to lubricated or else the axle bearing will quickly loosen side-to-side or vertically and fail to provide accurate saw cuts.
FWIW, Sears no longer sells Arbor Axle replacement parts... The Table Saw Arbor axle and Bearing Housing cannot use sealed bearings unless the saw case is re-milled and extensively modified. There are 2 Oil Hole Plugs (part# 475-32) that need to be opened and oil applied so the Arbor axle shaft does not get scored or worn.
I use 30wt motor oil to relube the Arbor Axle Shaft depending on amount of use, temperature, and axle rotation stiffness.
Remember, the higher the RPM speed of the table saw motor and/or the longer the use, the more frequently you may need to relube the Arbor Axle Bearing!
Nov 19, 2009 | Sears Saws
My Sears riding mower chokes itself out after warmed up,
Careful with the high octane.. That can burn a hole in the piston..
It might be fludding.. At the bottom of the carb should be a bowl.. One bolt at the bottom.. Take it off and clean it.. Spray some carb cleaner up in there where the float is..
If that dont do it --
Maybe the float is bad & taking in fluid..
If it has sat for long piriods of time - the carb might need to be cleaned & rebuilt..
When gass sits in there for a long time it shalacks and wont work correctly..
Pop off the carb & take to your local small eng shop. Shouldnt cost to much..
Jul 09, 2009 | Briggs & Stratton Briggs Stratton Intek V...
4HP Tecumseh flat-head head-bolt torque?
check the numbers on the motor and you can contact Tecumseh or check their website for info, they are usually very good with their help
Jun 29, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Hoursepower
A 2006 Kawasaki Vulcan 750 is rated at 60 HP.
Nov 10, 2008 | 2005 kawasaki VN 750 Vulcan
Measuring Tools & Sensors Logo
164 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
